SCTimer implement traffic signal
Overview
     The State Configurable Timer (SCTimer/PWM) is a peripheral that is unique to NXP Semiconductors. It can operate like most traditional timers, but also adds a state machine to give it a higher degree of configurability and control, in another word, the SCTimer/PWM can be considered as consist of Stand Timer and State/Event Logic (Fig 1). This allows the SCT to be configured as multiple PWMs, a PWM with dead-time control, and a PWM with reset capability, in addition to many other configurations that can’t be duplicated with traditional timers. Once the SCTimer/PWM has been configured, it can run autonomously from the microcontroller core, unless the SCTimer/PWM interrupt has been enabled which requires the core to service the interrupt.
Fig 1
      The first time you look at the SCTimer/PWM, it may appear to be a very complex peripheral, but you will see that it is actually not that difficult to use. Understanding the Event and State is critical to understanding the SCTimer/PWM.
       Event:
       The following conditions define possible events: a counter match condition, an input (or output) condition, a combination of a match and/or an input/output condition in a specified state, and the count direction. Events can control outputs, interrupts, DMA requests and the SCTimer/PWM states. They can also cause timer limit, halt, start, or stop conditions to occur.
       State:
        The state variable is the main feature that distinguishes the SCTimer/PWM from other counter/timer/PWM blocks. Events can be made to occur only in certain states. Events, in turn, can perform the following actions:
a)    Set and clear outputs;
b)   Limit, stop, and start the counter;
c)    Cause interrupts;
d)   Modify the state variable;
        Regarding the event and state mechanism (Fig 2 show a basic example), The SCT allows the user to group and filter events, thereby selecting some events to be enabled together while others are disabled. A group of enabled and disabled events can be described as a state, and several states with different sets of enabled and disabled events are allowed. Changing from one state to another is event driven as well and can happen without software intervention. Formally, the SCTimer/PWM can be programmed as state machine generator. The ability to perform switching between groups of events provides the SCT the unique capability to be utilized as a highly complex State Machine engine. Events identify the occurrence of conditions that warrant state changes and determine the next state to move to. This provides an extremely powerful control tool - particularly when the SCT inputs and outputs are connected to other on-chip resources (comparators, ADC triggers, other timers etc.) in addition to general-purpose I/O.
Fig 2
Traffic signal implementation
            Fig 3 illustrates the application of the SCT to simulate the traffic signal.
Fig 3
v Demo create
        LPCOpen is an extensive collection of free software libraries (drivers and middleware) and example programs that enable developers to create multifunctional products based on LPC microcontrollers. In this article, I will illustrate the steps of creating a new demo in the LPCOpen, for instance, create a demo by using the IAR IDE. Since the selected hardware board is the LPCXpresso824, the creating work is based on the corresponding LPCOpen.
  1.              Creates a new project
Fig 4
2.    Create the example and lib groups, then add the startup and board initialization files under the example group and add the library files: board_nxp_lpcxpresso_824.a and chip_82x_lib.a under the lib group. Next, create a main.c file: traffic_signal_demo.c.
Fig 5
3.     Add the corresponding paths
$PROJ_DIR$\..\..\..\..\..\..\software\lpc_core\lpc_chip\chip_8xx\config_82x
$PROJ_DIR$\..\..\..\..\..\..\software\lpc_core\lpc_chip\chip_common
$PROJ_DIR$\..\..\..\..\..\..\software\lpc_core\lpc_board\board_common
$PROJ_DIR$\..\..\..\..\..\..\software\lpc_core\lpc_board\boards_8xx\nxp_lpcxpresso_824
               $PROJ_DIR$\..\..\..\..\..\..\software\CMSIS\CMSIS\Include
4.     Miscellaneous settings
For instance, target selecting, adds the linker file, add other c files (Fig 6),etc.
Fig 6
v Crucial code
                                                         Table 1 main.c
 * @brief             Application main program
 * @return          Nothing (This function will not return)
int main(void)
                /* Generic Initialization */
                SystemCoreClockUpdate();
                /*Set system clock div as 30*/
                Chip_Clock_SetSysClockDiv(30);
                /*Assign SCT_out to board LED pin*/
                Chip_SWM_MovablePinAssign(SWM_SCT_OUT1_O, 13); // assign SCTOUT_0 to P0_13 YELLOW_LED
                Chip_SWM_MovablePinAssign(SWM_SCT_OUT2_O, 27); // assign SCTOUT_0 to P0_27 GREEN_LED
                Chip_SWM_MovablePinAssign(SWM_SCT_OUT0_O, 17); // assign SCTOUT_0 to P0_17 RED_LED
                /* Initialize the SCT clock and reset the SCT */
                Chip_Clock_EnablePeriphClock(SYSCTL_CLOCK_SCT);
                Chip_SYSCTL_PeriphReset(RESET_SCT);
                /*Initialize SCT*/
                sct_fsm_init();
                /* Start the SCT counter by clearing Halt_L in the SCT control register */
                Chip_SCT_ClearControl(LPC_SCT, SCT_CTRL_HALT_L);
             /* Enter sleep mode */
                while (1) {
                                __WFI();
                                                    Table 2 sct_fsm_init(void)
void sct_fsm_init (void)
/*The SCT operates as a unified 32-bit counter*/
LPC_SCT->CONFIG = (LPC_SCT->CONFIG & ~0x00060001) | 0x00000001; /* UNIFIED */
/* MATCH/CAPTURE registers */
LPC_SCT->REGMODE_L = 0x00000000;
LPC_SCT->MATCH[0].U = entry_mat;             /* entry_match */
LPC_SCT->MATCHREL[0].U = entry_mat;
LPC_SCT->MATCH[1].U = flash;                       /* flash_mat0 */
LPC_SCT->MATCHREL[1].U = flash;
LPC_SCT->MATCH[2].U = flash1;                    /* flash_mat1 */
LPC_SCT->MATCHREL[2].U = flash1;
LPC_SCT->MATCH[3].U = delay;                     /* match0 */
LPC_SCT->MATCHREL[3].U = delay;
LPC_SCT->MATCH[4].U = yel_delay;              /* yel_delay_mat */
LPC_SCT->MATCHREL[4].U = yel_delay;
LPC_SCT->MATCH[5].U = yel_flash;               /* yel_flash_mat */
LPC_SCT->MATCHREL[5].U = yel_flash;
/* OUTPUT registers */
/*Event 1 set the output*/
LPC_SCT->OUT[5].SET = 0x00000002;        /* out_track */
/*Event 3 clear the output*/
LPC_SCT->OUT[5].CLR = 0x00000008;
/*Event 0 and 3 set the output*/
LPC_SCT->OUT[2].SET = 0x00000009;        /* turn_green */
/*Event 7 clear the output*/
LPC_SCT->OUT[2].CLR = 0x00000080;
LPC_SCT->OUT[0].SET = 0x00000002;        /* turn_red */
/*Event 0 and 6 clear the output*/
LPC_SCT->OUT[0].CLR = 0x00000041;
/*Event 0, 2, 4, 5, 6 and 7 set the output*/
LPC_SCT->OUT[1].SET = 0x000000F5;        /* turn_yellow */
/*Event 1, 3, 4, 5 set the output*/
LPC_SCT->OUT[1].CLR = 0x0000003A;
  /* Unused outputs must not be affected by any event */
LPC_SCT->OUT[3].SET = 0;
LPC_SCT->OUT[3].CLR = 0;
LPC_SCT->OUT[4].SET = 0;
LPC_SCT->OUT[4].CLR = 0;
/* Conflict resolution register */
LPC_SCT->RES = (LPC_SCT->RES & ~0x0000000C) | 0x0000000C;
 Set COMBMODE = 0x1. Event 0 uses match condition only.
 Set MATCHSEL = 0x0. Select match value of match register 0.
The match value of MAT0 is associated with event 0
Set STATEV bits to 1 and the STATED bit to 1. Event 0 changes the
state to state 1
LPC_SCT->EV[0].CTRL = 0x0000D000;     /* U: --> state RED */
LPC_SCT->EV[0].STATE = 0x00000001;
 Set COMBMODE = 0x1. Event 1 uses match condition only.
 Set MATCHSEL = 0x3. Select match value of match register 3.
The match value of MAT3 is associated with event 1
Set STATEV bits to 2 and the STATED bit to 1. Event 1 changes the
state to state 2
LPC_SCT->EV[1].CTRL = 0x00015003;     /* U: --> state YELLOW */
LPC_SCT->EV[1].STATE = 0x00000002;
 Set MATCHSEL = 0x4. Select match value of match register 4.
The match value of MAT4 is associated with event 2
Set STATEV bits to 4 and the STATED bit to 1. Event 1 changes the
state to state 4
LPC_SCT->EV[2].CTRL = 0x00025004;     /* U: --> state YELLOW_FLASH */
LPC_SCT->EV[2].STATE = 0x00000004;
The match value of MAT3 is associated with event3
state to state 2
LPC_SCT->EV[3].CTRL = 0x00015003;     /* U: --> state YELLOW */
LPC_SCT->EV[3].STATE = 0x00000008;
 Set COMBMODE = 0x3. Event 6 uses when match and I/O condition occur.
 Set MATCHSEL = 0x5. Select match value of match register 5.
Set OUTSEL = 1. Select output.
Set IOSEL = 5. Select output 5.
Set IOCOND = 0x0. Output 0 is Low
The match value of MAT5 is associated with event 6
Set STATEV bits to 1 and the STATED bit to 1. Event 1 changes the
state to state 1
LPC_SCT->EV[6].CTRL = 0x0000F165;     /* U: --> state RED */
LPC_SCT->EV[6].STATE = 0x00000010;
Set IOCOND = 0x3. Output 0 is High
The match value of MAT5 is associated with event 7
Set STATEV bits to 3 and the STATED bit to 1. Event 7 changes the
state to state 3
LPC_SCT->EV[7].CTRL = 0x0001FD65;     /* U: --> state GREEN */
LPC_SCT->EV[7].STATE = 0x00000010;
 Set MATCHSEL = 0x1. Select match value of match register 1.
The match value of MAT1 is associated with event4
state to state 4
LPC_SCT->EV[4].CTRL = 0x00025001;     /* U: --> state YELLOW_FLASH */
LPC_SCT->EV[4].STATE = 0x00000010;
 Set MATCHSEL = 0x2. Select match value of match register 2.
The match value of MAT2 is associated with event5
state to state 4
LPC_SCT->EV[5].CTRL = 0x00025002;     /* U: --> state YELLOW_FLASH */
LPC_SCT->EV[5].STATE = 0x00000010;
/* STATE registers */
LPC_SCT->STATE_L = 0;
/* state names assignment: */
  /* State U 0: U_ENTRY */
  /* State U 1: RED */
  /* State U 2: YELLOW */
  /* State U 3: GREEN */
  /* State U 4: YELLOW_FLASH */
/* CORE registers */
LPC_SCT->START_L = 0x00000000;
LPC_SCT->STOP_L =  0x00000000;
LPC_SCT->HALT_L =  0x00000000;
/* Event0, 1, 2, 3, 6 and 7 reset the counter register */
LPC_SCT->LIMIT_L = 0x000000CF;
LPC_SCT->EVEN =    0x00000000;
LPC_SCT->DMAREQ0 = 0x00000000;
LPC_SCT->DMAREQ1 = 0x00000000;
v Result demonstrate
         The demo runs on the LPCXpresso824-MAX board, and using the Blue led replaces the Yellow led, and the video shows the demo working.
Fig 7 LPCXpresso824-MAX board
Video's link:
SCTimer implement traffic signal - YouTube
附件
评论
I'm new to this kind of programming and this environment. I do understand  that you are assigning GPIO pins to the SWM_CTL_OUT, but how do you get these hex values to talk to the actual pins? Because I'm working on an LPC824 and I try to toggle GPIO_17 on event 0, and this seems to fail.
%3CLINGO-SUB%20id%3D%22lingo-sub-1105508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESCTimer%20%E5%AE%9E%E7%8E%B0%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%2024.0pt%3B%22%3ESCTimer%20%E5%AE%9E%E7%8E%B0%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%3C%2FSTRONG%3E%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-380638743%22%20id%3D%22toc-hId-1303201715%22%3EOverview%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E7%8A%B6%E6%80%81%E5%8F%AF%E9%85%8D%E7%BD%AE%E5%AE%9A%E6%97%B6%E5%99%A8%20(SCTimer%2FPWM)%20%E6%98%AF%E6%81%A9%E6%99%BA%E6%B5%A6%E5%8D%8A%E5%AF%BC%E4%BD%93%E7%8B%AC%E6%9C%89%E7%9A%84%E5%A4%96%E8%AE%BE%E3%80%82%E5%AE%83%E5%8F%AF%E4%BB%A5%E5%83%8F%E5%A4%A7%E5%A4%9A%E6%95%B0%E4%BC%A0%E7%BB%9F%E8%AE%A1%E6%97%B6%E5%99%A8%E4%B8%80%E6%A0%B7%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%BD%86%E8%BF%98%E6%B7%BB%E5%8A%A0%E4%BA%86%E7%8A%B6%E6%80%81%E6%9C%BA%E4%BB%A5%E8%B5%8B%E4%BA%88%E5%85%B6%E6%9B%B4%E9%AB%98%E7%A8%8B%E5%BA%A6%E7%9A%84%E5%8F%AF%E9%85%8D%E7%BD%AE%E6%80%A7%E5%92%8C%E6%8E%A7%E5%88%B6%E6%80%A7%EF%BC%8C%E6%8D%A2%E5%8F%A5%E8%AF%9D%E8%AF%B4%EF%BC%8CSCTimer%2FPWM%20%E5%8F%AF%E4%BB%A5%E8%A2%AB%E8%A7%86%E4%B8%BA%E7%94%B1%E6%A0%87%E5%87%86%E8%AE%A1%E6%97%B6%E5%99%A8%E5%92%8C%E7%8A%B6%E6%80%81%2F%E4%BA%8B%E4%BB%B6%E9%80%BB%E8%BE%91%E7%BB%84%E6%88%90%EF%BC%88%E5%9B%BE%201%EF%BC%89%E3%80%82%E8%BF%99%E5%85%81%E8%AE%B8%E5%B0%86%20SCT%20%E9%85%8D%E7%BD%AE%E4%B8%BA%E5%A4%9A%E4%B8%AA%20PWM%E3%80%81%E5%85%B7%E6%9C%89%E6%AD%BB%E5%8C%BA%E6%8E%A7%E5%88%B6%E7%9A%84%20PWM%20%E5%92%8C%E5%85%B7%E6%9C%89%E5%A4%8D%E4%BD%8D%E5%8A%9F%E8%83%BD%E7%9A%84%20PWM%EF%BC%8C%E6%AD%A4%E5%A4%96%E8%BF%98%E6%9C%89%E8%AE%B8%E5%A4%9A%E5%85%B6%E4%BB%96%E6%97%A0%E6%B3%95%E7%94%A8%E4%BC%A0%E7%BB%9F%E8%AE%A1%E6%97%B6%E5%99%A8%E5%A4%8D%E5%88%B6%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%E4%B8%80%E6%97%A6%E9%85%8D%E7%BD%AE%E4%BA%86%20SCTimer%2FPWM%EF%BC%8C%E5%AE%83%E5%B0%B1%E5%8F%AF%E4%BB%A5%E8%84%B1%E7%A6%BB%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E6%A0%B8%E5%BF%83%E8%87%AA%E4%B8%BB%E8%BF%90%E8%A1%8C%EF%BC%8C%E9%99%A4%E9%9D%9E%E5%B7%B2%E5%90%AF%E7%94%A8%20SCTimer%2FPWM%20%E4%B8%AD%E6%96%AD%EF%BC%8C%E8%BF%99%E9%9C%80%E8%A6%81%E6%A0%B8%E5%BF%83%E6%9D%A5%E5%A4%84%E7%90%86%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20577px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F3042iE8B664220B6F695B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%9B%BE1%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E7%AC%AC%E4%B8%80%E6%AC%A1%E7%9C%8B%E5%88%B0%20SCTimer%2FPWM%20%E6%97%B6%EF%BC%8C%E5%AE%83%E5%8F%AF%E8%83%BD%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%98%AF%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E5%A4%8D%E6%9D%82%E7%9A%84%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%EF%BC%8C%E4%BD%86%E6%82%A8%E4%BC%9A%E5%8F%91%E7%8E%B0%E5%AE%83%E5%AE%9E%E9%99%85%E4%B8%8A%E5%B9%B6%E4%B8%8D%E9%9A%BE%E4%BD%BF%E7%94%A8%E3%80%82%E7%90%86%E8%A7%A3%E4%BA%8B%E4%BB%B6%E5%92%8C%E7%8A%B6%E6%80%81%E5%AF%B9%E4%BA%8E%E7%90%86%E8%A7%A3%20SCTimer%2FPWM%20%E8%87%B3%E5%85%B3%E9%87%8D%E8%A6%81%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22margin-top%3A%200in%3B%22%20id%3D%22toc-hId-1071200217%22%20id%3D%22toc-hId-1993763189%22%3E%E4%BA%8B%E4%BB%B6%EF%BC%9A%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%BB%A5%E4%B8%8B%E6%9D%A1%E4%BB%B6%E5%AE%9A%E4%B9%89%E4%BA%86%E5%8F%AF%E8%83%BD%E5%8F%91%E7%94%9F%E7%9A%84%E4%BA%8B%E4%BB%B6%EF%BC%9A%E8%AE%A1%E6%95%B0%E5%99%A8%E5%8C%B9%E9%85%8D%E6%9D%A1%E4%BB%B6%E3%80%81%E8%BE%93%E5%85%A5%EF%BC%88%E6%88%96%E8%BE%93%E5%87%BA%EF%BC%89%E6%9D%A1%E4%BB%B6%E3%80%81%E6%8C%87%E5%AE%9A%E7%8A%B6%E6%80%81%E4%B8%8B%E7%9A%84%E5%8C%B9%E9%85%8D%E5%92%8C%2F%E6%88%96%E8%BE%93%E5%85%A5%2F%E8%BE%93%E5%87%BA%E6%9D%A1%E4%BB%B6%E7%9A%84%E7%BB%84%E5%90%88%E4%BB%A5%E5%8F%8A%E8%AE%A1%E6%95%B0%E6%96%B9%E5%90%91%E3%80%82%E4%BA%8B%E4%BB%B6%E5%8F%AF%E4%BB%A5%E6%8E%A7%E5%88%B6%E8%BE%93%E5%87%BA%E3%80%81%E4%B8%AD%E6%96%AD%E3%80%81DMA%20%E8%AF%B7%E6%B1%82%E5%92%8C%20SCTimer%2FPWM%20%E7%8A%B6%E6%80%81%E3%80%82%E5%AE%83%E4%BB%AC%E8%BF%98%E5%8F%AF%E8%83%BD%E5%AF%BC%E8%87%B4%E8%AE%A1%E6%97%B6%E5%99%A8%E9%99%90%E5%88%B6%E3%80%81%E6%9A%82%E5%81%9C%E3%80%81%E5%90%AF%E5%8A%A8%E6%88%96%E5%81%9C%E6%AD%A2%E6%9D%A1%E4%BB%B6%E7%9A%84%E5%8F%91%E7%94%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH2%20style%3D%22margin-top%3A%200in%3B%22%20id%3D%22toc-hId--736254246%22%20id%3D%22toc-hId-186308726%22%3E%E7%8A%B6%E6%80%81%EF%BC%9A%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E7%8A%B6%E6%80%81%E5%8F%98%E9%87%8F%E6%98%AF%20SCTimer%2FPWM%20%E4%B8%8E%E5%85%B6%E4%BB%96%E8%AE%A1%E6%95%B0%E5%99%A8%2F%E5%AE%9A%E6%97%B6%E5%99%A8%2FPWM%20%E5%9D%97%E7%9A%84%E4%B8%BB%E8%A6%81%E5%8C%BA%E5%88%AB%E7%89%B9%E5%BE%81%E3%80%82%E5%8F%AF%E4%BB%A5%E4%BD%BF%E4%BA%8B%E4%BB%B6%E4%BB%85%E5%9C%A8%E6%9F%90%E4%BA%9B%E7%8A%B6%E6%80%81%E4%B8%8B%E5%8F%91%E7%94%9F%E3%80%82%E5%8F%8D%E8%BF%87%E6%9D%A5%EF%BC%8C%E4%BA%8B%E4%BB%B6%E5%8F%AF%E4%BB%A5%E6%89%A7%E8%A1%8C%E4%BB%A5%E4%B8%8B%E6%93%8D%E4%BD%9C%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId--45692772%22%20id%3D%22toc-hId-876870200%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3Ea)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E8%AE%BE%E7%BD%AE%E5%92%8C%E6%B8%85%E9%99%A4%E8%BE%93%E5%87%BA%EF%BC%9B%3C%2FSPAN%3E%3C%2FH3%3E%3CH3%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId--1853147235%22%20id%3D%22toc-hId--930584263%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3Eb)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E9%99%90%E5%88%B6%E3%80%81%E5%81%9C%E6%AD%A2%E5%92%8C%E5%90%AF%E5%8A%A8%E8%AE%A1%E6%95%B0%E5%99%A8%EF%BC%9B%3C%2FSPAN%3E%3C%2FH3%3E%3CH3%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId-634365598%22%20id%3D%22toc-hId-1556928570%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3Ec)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E9%80%A0%E6%88%90%E4%B8%AD%E6%96%AD%EF%BC%9B%3C%2FSPAN%3E%3C%2FH3%3E%3CH3%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId--1173088865%22%20id%3D%22toc-hId--250525893%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3Ed)%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%20color%3A%20windowtext%3B%22%3E%E4%BF%AE%E6%94%B9%E7%8A%B6%E6%80%81%E5%8F%98%E9%87%8F%EF%BC%9B%3C%2FSPAN%3E%3C%2FH3%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%85%B3%E4%BA%8E%E4%BA%8B%E4%BB%B6%E5%92%8C%E7%8A%B6%E6%80%81%E6%9C%BA%E5%88%B6%EF%BC%88%E5%9B%BE%202%20%E6%98%BE%E7%A4%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E5%9F%BA%E6%9C%AC%E7%A4%BA%E4%BE%8B%EF%BC%89%EF%BC%8CSCT%20%E5%85%81%E8%AE%B8%E7%94%A8%E6%88%B7%E5%AF%B9%E4%BA%8B%E4%BB%B6%E8%BF%9B%E8%A1%8C%E5%88%86%E7%BB%84%E5%92%8C%E8%BF%87%E6%BB%A4%EF%BC%8C%E4%BB%8E%E8%80%8C%E9%80%89%E6%8B%A9%E4%B8%80%E4%BA%9B%E4%BA%8B%E4%BB%B6%E4%B8%80%E8%B5%B7%E5%90%AF%E7%94%A8%EF%BC%8C%E8%80%8C%E5%85%B6%E4%BB%96%E4%BA%8B%E4%BB%B6%E5%88%99%E7%A6%81%E7%94%A8%E3%80%82%E4%B8%80%E7%BB%84%E5%90%AF%E7%94%A8%E5%92%8C%E7%A6%81%E7%94%A8%E4%BA%8B%E4%BB%B6%E5%8F%AF%E4%BB%A5%E6%8F%8F%E8%BF%B0%E4%B8%BA%E4%B8%80%E7%A7%8D%E7%8A%B6%E6%80%81%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%85%81%E8%AE%B8%E5%85%B7%E6%9C%89%E4%B8%8D%E5%90%8C%E7%BB%84%E5%90%AF%E7%94%A8%E5%92%8C%E7%A6%81%E7%94%A8%E4%BA%8B%E4%BB%B6%E7%9A%84%E5%A4%9A%E4%B8%AA%E7%8A%B6%E6%80%81%E3%80%82%E4%BB%8E%E4%B8%80%E7%A7%8D%E7%8A%B6%E6%80%81%E5%88%B0%E5%8F%A6%E4%B8%80%E7%A7%8D%E7%8A%B6%E6%80%81%E7%9A%84%E6%94%B9%E5%8F%98%E4%B9%9F%E6%98%AF%E7%94%B1%E4%BA%8B%E4%BB%B6%E9%A9%B1%E5%8A%A8%E7%9A%84%EF%BC%8C%E5%B9%B6%E4%B8%94%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%97%A0%E9%9C%80%E8%BD%AF%E4%BB%B6%E5%B9%B2%E9%A2%84%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%8F%91%E7%94%9F%E3%80%82%E6%AD%A3%E5%BC%8F%E5%9C%B0%EF%BC%8CSCTimer%2FPWM%20%E5%8F%AF%E4%BB%A5%E8%A2%AB%E7%BC%96%E7%A8%8B%E4%B8%BA%E7%8A%B6%E6%80%81%E6%9C%BA%E7%94%9F%E6%88%90%E5%99%A8%E3%80%82%E5%9C%A8%E4%BA%8B%E4%BB%B6%E7%BB%84%E4%B9%8B%E9%97%B4%E6%89%A7%E8%A1%8C%E5%88%87%E6%8D%A2%E7%9A%84%E8%83%BD%E5%8A%9B%E4%B8%BA%20SCT%20%E6%8F%90%E4%BE%9B%E4%BA%86%E7%94%A8%E4%BD%9C%E9%AB%98%E5%BA%A6%E5%A4%8D%E6%9D%82%E7%9A%84%E7%8A%B6%E6%80%81%E6%9C%BA%E5%BC%95%E6%93%8E%E7%9A%84%E7%8B%AC%E7%89%B9%E8%83%BD%E5%8A%9B%E3%80%82%E4%BA%8B%E4%BB%B6%E8%AF%86%E5%88%AB%E5%AF%BC%E8%87%B4%E7%8A%B6%E6%80%81%E6%94%B9%E5%8F%98%E7%9A%84%E6%9D%A1%E4%BB%B6%E7%9A%84%E5%8F%91%E7%94%9F%E5%B9%B6%E7%A1%AE%E5%AE%9A%E8%A6%81%E8%BD%AC%E7%A7%BB%E5%88%B0%E7%9A%84%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%8A%B6%E6%80%81%E3%80%82%E8%BF%99%E6%8F%90%E4%BE%9B%E4%BA%86%E4%B8%80%E4%B8%AA%E6%9E%81%E5%85%B6%E5%BC%BA%E5%A4%A7%E7%9A%84%E6%8E%A7%E5%88%B6%E5%B7%A5%E5%85%B7%20-%20%E7%89%B9%E5%88%AB%E6%98%AF%E5%BD%93%20SCT%20%E8%BE%93%E5%85%A5%E5%92%8C%E8%BE%93%E5%87%BA%E9%99%A4%E4%BA%86%E9%80%9A%E7%94%A8%20I%2FO%20%E4%B9%8B%E5%A4%96%E8%BF%98%E8%BF%9E%E6%8E%A5%E5%88%B0%E5%85%B6%E4%BB%96%E7%89%87%E4%B8%8A%E8%B5%84%E6%BA%90%EF%BC%88%E6%AF%94%E8%BE%83%E5%99%A8%E3%80%81ADC%20%E8%A7%A6%E5%8F%91%E5%99%A8%E3%80%81%E5%85%B6%E4%BB%96%E8%AE%A1%E6%97%B6%E5%99%A8%E7%AD%89%EF%BC%89%E6%97%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_6.png%22%20style%3D%22width%3A%20988px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111687i87D39EC2AFBCC826%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_6.png%22%20alt%3D%22pastedImage_6.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%BE2%3C%2FP%3E%3CH1%20style%3D%22margin-left%3A%20.5in%3B%20text-indent%3A%20-.25in%3B%22%20id%3D%22toc-hId-613359390%22%20id%3D%22toc-hId-1535922362%22%3E%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%E5%AE%9E%E6%96%BD%3C%2FH1%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%9B%BE3%E8%AF%B4%E6%98%8E%E4%BA%86SCT%E5%9C%A8%E6%A8%A1%E6%8B%9F%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%E4%B8%AD%E7%9A%84%E5%BA%94%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20873px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111686i6F23EF30668C3A09%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%BE3%3C%2FP%3E%3CH2%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId-1303920864%22%20id%3D%22toc-hId--2068483460%22%3Ev%20%E6%BC%94%E7%A4%BA%E5%88%9B%E5%BB%BA%3C%2FH2%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3ELPCOpen%20%E6%98%AF%E4%B8%80%E4%B8%AA%E5%85%8D%E8%B4%B9%E8%BD%AF%E4%BB%B6%E5%BA%93%EF%BC%88%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%92%8C%E4%B8%AD%E9%97%B4%E4%BB%B6%EF%BC%89%E5%92%8C%E7%A4%BA%E4%BE%8B%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%B9%BF%E6%B3%9B%E9%9B%86%E5%90%88%EF%BC%8C%E4%BD%BF%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E8%83%BD%E5%A4%9F%E5%9F%BA%E4%BA%8E%20LPC%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E5%88%9B%E5%BB%BA%E5%A4%9A%E5%8A%9F%E8%83%BD%E4%BA%A7%E5%93%81%E3%80%82%E5%9C%A8%E6%9C%AC%E6%96%87%E4%B8%AD%EF%BC%8C%E6%88%91%E5%B0%86%E8%AF%B4%E6%98%8E%E5%9C%A8%20LPCOpen%20%E4%B8%AD%E5%88%9B%E5%BB%BA%E6%96%B0%E6%BC%94%E7%A4%BA%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%8C%E4%BD%BF%E7%94%A8%20IAR%20IDE%20%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%BC%94%E7%A4%BA%E3%80%82%E7%94%B1%E4%BA%8E%E6%89%80%E9%80%89%E7%9A%84%E7%A1%AC%E4%BB%B6%E6%9D%BF%E6%98%AF%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fproducts%2Fsoftware-and-tools%2Fhardware-development-tools%2Flpcxpresso-boards%2Flpcxpresso824-max-board-for-lpc82x-family-mcus%3AOM13071%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%3CSPAN%20style%3D%22color%3A%20windowtext%3B%20text-decoration%3A%20none%3B%22%3ELPCXpresso824%3C%2FSPAN%3E%3C%2FA%3E%20%EF%BC%8C%E5%9B%A0%E6%AD%A4%E5%88%9B%E5%BB%BA%E5%B7%A5%E4%BD%9C%E5%9F%BA%E4%BA%8E%E7%9B%B8%E5%BA%94%E7%9A%84LPCOpen%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3COL%3E%3CLI%20style%3D%22text-indent%3A%20-.5in%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%88%9B%E5%BB%BA%E6%96%B0%E9%A1%B9%E7%9B%AE%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_19.png%22%20style%3D%22width%3A%20316px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111685i348148EBC4A3C9C0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_19.png%22%20alt%3D%22pastedImage_19.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%BE4%3C%2FP%3E%3CH2%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId--503533599%22%20id%3D%22toc-hId-419029373%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E2.%20%E5%88%9B%E5%BB%BA%20example%20%E5%92%8C%20lib%20%E7%BB%84%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%20example%20%E7%BB%84%E4%B8%8B%E6%B7%BB%E5%8A%A0%E5%90%AF%E5%8A%A8%E6%96%87%E4%BB%B6%E5%92%8C%E6%9D%BF%E7%BA%A7%E5%88%9D%E5%A7%8B%E5%8C%96%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E5%9C%A8%20lib%20%E7%BB%84%E4%B8%8B%E6%B7%BB%E5%8A%A0%E5%BA%93%E6%96%87%E4%BB%B6%EF%BC%9Aboard_nxp_lpcxpresso_824.a%20%E5%92%8C%20chip_82x_lib.a%E3%80%82%E6%8E%A5%E4%B8%8B%E6%9D%A5%EF%BC%8C%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%20main.c%20%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FSPAN%3E%20%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3Etraffic_signal_demo.c%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_22.png%22%20style%3D%22width%3A%20413px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F111684iBF86A700906FC467%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_22.png%22%20alt%3D%22pastedImage_22.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%BE5%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E3.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E6%B7%BB%E5%8A%A0%E7%9B%B8%E5%BA%94%E8%B7%AF%E5%BE%84%3C%2FSPAN%3E%3C%2FP%3E%3CTABLE%20style%3D%22border%3A%20none%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23404040%201.0pt%3B%20background%3A%20silver%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%22%20width%3D%22590%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5Clpc_core%5Clpc_chip%5Cchip_8xx%5Cconfig_82x%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5Clpc_core%5Clpc_chip%5Cchip_common%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5Clpc_core%5Clpc_chip%5Cchip_8xx%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5Clpc_core%5Clpc_board%5Cboard_common%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5Clpc_core%5Clpc_board%5Cboards_8xx%5Cnxp_lpcxpresso_824%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin%3A%200in%3B%20margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22font-size%3A%208.0pt%3B%22%3E%24PROJ_DIR%24%5C..%5C..%5C..%5C..%5C..%5C..%5Csoftware%5CCMSIS%5CCMSIS%5CInclude%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E4.%3C%2FSPAN%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%85%B6%E4%BB%96%E8%AE%BE%E7%BD%AE%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E4%BE%8B%E5%A6%82%E9%80%89%E6%8B%A9%E7%9B%AE%E6%A0%87%E3%80%81%E6%B7%BB%E5%8A%A0%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E3%80%81%E6%B7%BB%E5%8A%A0%E5%85%B6%E4%BB%96c%E6%96%87%E4%BB%B6%EF%BC%88%E5%9B%BE6%EF%BC%89%E7%AD%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_40.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_40.png%22%20style%3D%22width%3A%20255px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F24866iEAFD234BF5B020CC%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_40.png%22%20alt%3D%22pastedImage_40.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20style%3D%22font-size%3A%2012.0pt%3B%22%3E%E5%9B%BE6%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CH2%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId--637218323%22%20id%3D%22toc-hId-285344649%22%3Ev%20%E5%85%B3%E9%94%AE%E4%BB%A3%E7%A0%81%3C%2FH2%3E%3CP%3E%E8%A1%A81%20main.c%3C%2FP%3E%3CTABLE%20style%3D%22border%3A%20none%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23404040%201.0pt%3B%20background%3A%20silver%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%22%20width%3D%22590%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F**%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E*%20%40brief%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%BB%E7%A8%8B%E5%BA%8F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E*%20%40return%20Nothing%EF%BC%88%E8%AF%A5%E5%87%BD%E6%95%B0%E4%B8%8D%E4%BC%9A%E8%BF%94%E5%9B%9E%EF%BC%89%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3Eint%20main(void)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E9%80%9A%E7%94%A8%E5%88%9D%E5%A7%8B%E5%8C%96%20*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20SystemCoreClockUpdate()%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E8%AE%BE%E7%BD%AE%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%92%9F%E5%88%86%E9%A2%91%E4%B8%BA30*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Chip_Clock_SetSysClockDiv(30)%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E5%B0%86%20SCT_out%20%E5%88%86%E9%85%8D%E7%BB%99%E7%94%B5%E8%B7%AF%E6%9D%BF%20LED%20%E5%BC%95%E8%84%9A*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SWM_MovablePinAssign(SWM_SCT_OUT1_O%2C%2013)%3B%20%2F%2F%E5%B0%86%20SCTOUT_0%20%E5%88%86%E9%85%8D%E7%BB%99%20P0_13%20YELLOW_LED%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SWM_MovablePinAssign(SWM_SCT_OUT2_O%2C%2027)%3B%20%2F%2F%20%E5%B0%86%20SCTOUT_0%20%E5%88%86%E9%85%8D%E7%BB%99%20P0_27%20GREEN_LED%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SWM_MovablePinAssign(SWM_SCT_OUT0_O%2C%2017)%3B%20%2F%2F%E5%B0%86%20SCTOUT_0%20%E5%88%86%E9%85%8D%E7%BB%99%20P0_17%20RED_LED%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96SCT%E6%97%B6%E9%92%9F%E5%B9%B6%E9%87%8D%E7%BD%AESCT%20*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%E8%8A%AF%E7%89%87%E6%97%B6%E9%92%9F%E5%90%AF%E7%94%A8%E5%A4%96%E8%AE%BE%E6%97%B6%E9%92%9F%EF%BC%88SYSCTL_CLOCK_SCT%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SYSCTL_PeriphReset%EF%BC%88RESET_SCT%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E5%88%9D%E5%A7%8B%E5%8C%96SCT*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20sct_fsm_init()%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%3CSPAN%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E9%80%9A%E8%BF%87%E6%B8%85%E9%99%A4SCT%E6%8E%A7%E5%88%B6%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84Halt_L%E6%9D%A5%E5%90%AF%E5%8A%A8SCT%E8%AE%A1%E6%95%B0%E5%99%A8*%2F%3C%2FSPAN%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3EChip_SCT_ClearControl%EF%BC%88LPC_SCT%EF%BC%8CSCT_CTRL_HALT_L%EF%BC%89%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E8%BF%9B%E5%85%A5%E7%9D%A1%E7%9C%A0%E6%A8%A1%E5%BC%8F%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%E8%80%8C%EF%BC%881%EF%BC%89%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20__WFI()%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Table%202%20sct_fsm_init(void)%3C%2FP%3E%3CTABLE%20style%3D%22border%3A%20none%3B%22%3E%3CTBODY%3E%3CTR%3E%3CTD%20style%3D%22border%3A%20solid%20%23404040%201.0pt%3B%20background%3A%20silver%3B%20padding%3A%200in%205.4pt%200in%205.4pt%3B%22%20width%3D%22590%22%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3Evoid%20sct_fsm_init%20(void)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*SCT%E4%BD%9C%E4%B8%BA%E7%BB%9F%E4%B8%80%E7%9A%8432%E4%BD%8D%E8%AE%A1%E6%95%B0%E5%99%A8%E8%BF%90%E8%A1%8C*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BCONFIG%20%3D%20(LPC_SCT-%26gt%3BCONFIG%20%26amp%3B%20~0x00060001)%20%7C%200x00000001%3B%20%2F*%20%E7%BB%9F%E4%B8%80%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E5%8C%B9%E9%85%8D%2F%E6%8D%95%E8%8E%B7%E5%AF%84%E5%AD%98%E5%99%A8%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BREGMODE_L%20%3D%200x00000000%3B%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B0%5D.U%20%3D%20entry_mat%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%2F*%20entry_match%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCHREL%5B0%5D.U%20%3D%20entry_mat%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B1%5D.U%20%3D%20flash%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*%20flash_mat0%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCHREL%5B1%5D.U%20%3D%20%E9%97%AA%E5%AD%98%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B2%5D.U%20%3D%20flash1%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2F*%20flash_mat1%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCHREL%5B2%5D.U%20%3D%20flash1%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B3%5D.U%20%3D%20%E5%BB%B6%E8%BF%9F%EF%BC%9B%2F*%E5%8C%B9%E9%85%8D0*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCHREL%5B3%5D.U%20%3D%20%E5%BB%B6%E8%BF%9F%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B4%5D.U%20%3D%20yel_delay%3B%20%2F*%20yel_delay_mat%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCHREL%5B4%5D.U%20%3D%20yel_delay%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCH%5B5%5D.U%20%3D%20yel_flash%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%2F*%20yel_flash_mat%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BMATCHREL%5B5%5D.U%20%3D%20yel_flash%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E8%BE%93%E5%87%BA%E5%AF%84%E5%AD%98%E5%99%A8%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E4%BA%8B%E4%BB%B61%E8%AE%BE%E7%BD%AE%E8%BE%93%E5%87%BA*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B5%5D.SET%20%3D%200x00000002%3B%20%2F*%20%E8%BE%93%E5%87%BA%E8%BD%A8%E9%81%93%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E4%BA%8B%E4%BB%B6%203%20%E6%B8%85%E9%99%A4%E8%BE%93%E5%87%BA*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B5%5D.CLR%20%3D%200x00000008%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E4%BA%8B%E4%BB%B6%200%20%E5%92%8C%203%20%E8%AE%BE%E7%BD%AE%E8%BE%93%E5%87%BA*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B2%5D.SET%20%3D%200x00000009%3B%20%2F*%20turn_green%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E4%BA%8B%E4%BB%B6%207%20%E6%B8%85%E9%99%A4%E8%BE%93%E5%87%BA*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B2%5D.CLR%20%3D%200x00000080%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E4%BA%8B%E4%BB%B61%E8%AE%BE%E7%BD%AE%E8%BE%93%E5%87%BA*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B0%5D.SET%20%3D%200x00000002%3B%20%2F*%20turn_red%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E4%BA%8B%E4%BB%B6%200%20%E5%92%8C%206%20%E6%B8%85%E9%99%A4%E8%BE%93%E5%87%BA*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B0%5D.CLR%20%3D%200x00000041%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E4%BA%8B%E4%BB%B6%200%E3%80%812%E3%80%814%E3%80%815%E3%80%816%20%E5%92%8C%207%20%E8%AE%BE%E7%BD%AE%E8%BE%93%E5%87%BA*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B1%5D.SET%20%3D%200x000000F5%3B%20%2F*%20%E8%BD%AC%E9%BB%84%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%E4%BA%8B%E4%BB%B61%E3%80%813%E3%80%814%E3%80%815%E8%AE%BE%E7%BD%AE%E8%BE%93%E5%87%BA*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B1%5D.CLR%20%3D%200x0000003A%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E6%9C%AA%E4%BD%BF%E7%94%A8%E7%9A%84%E8%BE%93%E5%87%BA%E4%B8%8D%E5%BE%97%E5%8F%97%E5%88%B0%E4%BB%BB%E4%BD%95%E4%BA%8B%E4%BB%B6%E7%9A%84%E5%BD%B1%E5%93%8D%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B3%5D.%E8%AE%BE%E7%BD%AE%3D0%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B3%5D.CLR%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B4%5D.%E8%AE%BE%E7%BD%AE%3D0%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BOUT%5B4%5D.CLR%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E5%86%B2%E7%AA%81%E8%A7%A3%E5%86%B3%E5%AF%84%E5%AD%98%E5%99%A8%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BRES%20%3D%20(LPC_SCT-%26gt%3BRES%20%26amp%3B%20~0x0000000C)%20%7C%200x0000000C%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AECOMBMODE%20%3D%200x1%E3%80%82%E4%BA%8B%E4%BB%B6%200%20%E4%BB%85%E4%BD%BF%E7%94%A8%E5%8C%B9%E9%85%8D%E6%9D%A1%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20MATCHSEL%20%3D%200x0%E3%80%82%E9%80%89%E6%8B%A9%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A8%200%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E3%80%82%3CBR%20%2F%3E%20MAT0%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E4%B8%8E%E4%BA%8B%E4%BB%B6%200%20%E5%85%B3%E8%81%94%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E5%B0%86%20STATEV%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%EF%BC%8C%E5%B0%86%20STATED%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%E3%80%82%E4%BA%8B%E4%BB%B6%200%20%E4%BC%9A%E6%94%B9%E5%8F%98%3CBR%20%2F%3E%E5%B7%9E%E9%99%85%201%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B0%5D.CTRL%20%3D%200x0000D000%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%80%81%E7%BA%A2%E8%89%B2%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B0%5D.%E7%8A%B6%E6%80%81%20%3D%200x00000001%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AECOMBMODE%20%3D%200x1%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E4%BB%85%E4%BD%BF%E7%94%A8%E5%8C%B9%E9%85%8D%E6%9D%A1%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20MATCHSEL%20%3D%200x3%E3%80%82%E9%80%89%E6%8B%A9%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A83%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E3%80%82%3CBR%20%2F%3E%20MAT3%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E4%B8%8E%E4%BA%8B%E4%BB%B6%201%20%E5%85%B3%E8%81%94%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E5%B0%86%20STATEV%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%202%EF%BC%8C%E5%B0%86%20STATED%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E6%94%B9%E5%8F%98%3CBR%20%2F%3E%E5%B7%9E%E9%99%85%202%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B1%5D.CTRL%20%3D%200x00015003%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%80%81%E9%BB%84%E8%89%B2%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B1%5D.%E7%8A%B6%E6%80%81%20%3D%200x00000002%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AECOMBMODE%20%3D%200x1%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E4%BB%85%E4%BD%BF%E7%94%A8%E5%8C%B9%E9%85%8D%E6%9D%A1%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20MATCHSEL%20%3D%200x4%E3%80%82%E9%80%89%E6%8B%A9%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A84%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E3%80%82%3CBR%20%2F%3E%20MAT4%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E4%B8%8E%E4%BA%8B%E4%BB%B6%202%20%E5%85%B3%E8%81%94%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E5%B0%86%20STATEV%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%204%EF%BC%8C%E5%B0%86%20STATED%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E6%94%B9%E5%8F%98%3CBR%20%2F%3E%E5%B7%9E%E9%99%85%204%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B2%5D.CTRL%20%3D%200x00025004%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%80%81%20YELLOW_FLASH%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B2%5D.%E7%8A%B6%E6%80%81%20%3D%200x00000004%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AECOMBMODE%20%3D%200x1%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E4%BB%85%E4%BD%BF%E7%94%A8%E5%8C%B9%E9%85%8D%E6%9D%A1%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20MATCHSEL%20%3D%200x3%E3%80%82%E9%80%89%E6%8B%A9%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A83%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E3%80%82%3CBR%20%2F%3E%20MAT3%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E4%B8%8E%20event3%20%E5%85%B3%E8%81%94%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E5%B0%86%20STATEV%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%202%EF%BC%8C%E5%B0%86%20STATED%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E6%94%B9%E5%8F%98%3CBR%20%2F%3E%E5%B7%9E%E9%99%85%202%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B3%5D.CTRL%20%3D%200x00015003%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%80%81%E9%BB%84%E8%89%B2%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B3%5D.%E7%8A%B6%E6%80%81%20%3D%200x00000008%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AECOMBMODE%20%3D%200x3%E3%80%82%E4%BA%8B%E4%BB%B6%206%20%E5%9C%A8%E5%8C%B9%E9%85%8D%E5%92%8C%20I%2FO%20%E6%9D%A1%E4%BB%B6%E5%8F%91%E7%94%9F%E6%97%B6%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20MATCHSEL%20%3D%200x5%E3%80%82%E9%80%89%E6%8B%A9%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A85%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AE%20OUTSEL%20%3D%201%E3%80%82%E9%80%89%E6%8B%A9%E8%BE%93%E5%87%BA%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AEIOSEL%20%3D%205%E3%80%82%E9%80%89%E6%8B%A9%E8%BE%93%E5%87%BA%205%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20IOCOND%20%3D%200x0%E3%80%82%E8%BE%93%E5%87%BA%200%20%E4%B8%BA%E4%BD%8E%3CBR%20%2F%3EMAT5%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E4%B8%8E%E4%BA%8B%E4%BB%B6%206%20%E5%85%B3%E8%81%94%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E5%B0%86%20STATEV%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%EF%BC%8C%E5%B0%86%20STATED%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E6%94%B9%E5%8F%98%3CBR%20%2F%3E%E5%B7%9E%E9%99%85%201%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B6%5D.CTRL%20%3D%200x0000F165%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%80%81%E7%BA%A2%E8%89%B2%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B6%5D.%E7%8A%B6%E6%80%81%20%3D%200x00000010%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AECOMBMODE%20%3D%200x3%E3%80%82%E4%BA%8B%E4%BB%B6%206%20%E5%9C%A8%E5%8C%B9%E9%85%8D%E5%92%8C%20I%2FO%20%E6%9D%A1%E4%BB%B6%E5%8F%91%E7%94%9F%E6%97%B6%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20MATCHSEL%20%3D%200x5%E3%80%82%E9%80%89%E6%8B%A9%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A85%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AE%20OUTSEL%20%3D%201%E3%80%82%E9%80%89%E6%8B%A9%E8%BE%93%E5%87%BA%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AEIOSEL%20%3D%205%E3%80%82%E9%80%89%E6%8B%A9%E8%BE%93%E5%87%BA%205%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20IOCOND%20%3D%200x3%E3%80%82%E8%BE%93%E5%87%BA%200%20%E4%B8%BA%E9%AB%98%3CBR%20%2F%3EMAT5%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E4%B8%8E%E4%BA%8B%E4%BB%B6%207%20%E7%9B%B8%E5%85%B3%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E5%B0%86%20STATEV%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%203%EF%BC%8C%E5%B0%86%20STATED%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%E3%80%82%E4%BA%8B%E4%BB%B6%207%20%E4%BC%9A%E6%94%B9%E5%8F%98%3CBR%20%2F%3E%E5%B7%9E%E9%99%85%203%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B7%5D.CTRL%20%3D%200x0001FD65%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%80%81%E7%BB%BF%E8%89%B2%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B7%5D.%E7%8A%B6%E6%80%81%20%3D%200x00000010%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AECOMBMODE%20%3D%200x1%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E4%BB%85%E4%BD%BF%E7%94%A8%E5%8C%B9%E9%85%8D%E6%9D%A1%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20MATCHSEL%20%3D%200x1%E3%80%82%E9%80%89%E6%8B%A9%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A8%201%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E3%80%82%3CBR%20%2F%3EMAT1%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E4%B8%8E%E4%BA%8B%E4%BB%B6%204%20%E5%85%B3%E8%81%94%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E5%B0%86%20STATEV%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%204%EF%BC%8C%E5%B0%86%20STATED%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E6%94%B9%E5%8F%98%3CBR%20%2F%3E%E5%B7%9E%E9%99%85%204%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B4%5D.CTRL%20%3D%200x00025001%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%80%81%20YELLOW_FLASH%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B4%5D.%E7%8A%B6%E6%80%81%20%3D%200x00000010%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E8%AE%BE%E7%BD%AECOMBMODE%20%3D%200x1%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E4%BB%85%E4%BD%BF%E7%94%A8%E5%8C%B9%E9%85%8D%E6%9D%A1%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E8%AE%BE%E7%BD%AE%20MATCHSEL%20%3D%200x2%E3%80%82%E9%80%89%E6%8B%A9%E5%8C%B9%E9%85%8D%E5%AF%84%E5%AD%98%E5%99%A82%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E3%80%82%3CBR%20%2F%3E%20MAT2%20%E7%9A%84%E5%8C%B9%E9%85%8D%E5%80%BC%E4%B8%8E%E4%BA%8B%E4%BB%B6%205%20%E5%85%B3%E8%81%94%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%E5%B0%86%20STATEV%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%204%EF%BC%8C%E5%B0%86%20STATED%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E4%B8%BA%201%E3%80%82%E4%BA%8B%E4%BB%B6%201%20%E6%94%B9%E5%8F%98%3CBR%20%2F%3E%E5%B7%9E%E9%99%85%204%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B5%5D.CTRL%20%3D%200x00025002%3B%20%2F*%20U%3A%20--%26gt%3B%20%E7%8A%B6%E6%80%81%20YELLOW_FLASH%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEV%5B5%5D.%E7%8A%B6%E6%80%81%20%3D%200x00000010%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3B%E7%8A%B6%E6%80%81_L%20%3D%200%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E7%8A%B6%E6%80%81%E5%90%8D%E7%A7%B0%E5%88%86%E9%85%8D%EF%BC%9A%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E7%8A%B6%E6%80%81%20U%200%3A%20U_ENTRY%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E7%8A%B6%E6%80%81%20U%201%EF%BC%9A%E7%BA%A2%E8%89%B2%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E7%8A%B6%E6%80%81%20U%202%EF%BC%9A%E9%BB%84%E8%89%B2%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E7%8A%B6%E6%80%81%20U%203%EF%BC%9A%E7%BB%BF%E8%89%B2%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%2F*%20%E7%8A%B6%E6%80%81%20U%204%EF%BC%9A%E9%BB%84%E8%89%B2%E9%97%AA%E7%83%81%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E6%A0%B8%E5%BF%83%E5%AF%84%E5%AD%98%E5%99%A8%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BSTART_L%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BSTOP_L%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BHALT_L%20%3D%200x00000000%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%20style%3D%22color%3A%20%2335a543%3B%22%3E%2F*%20%E4%BA%8B%E4%BB%B6%200%E3%80%811%E3%80%812%E3%80%813%E3%80%816%20%E5%92%8C%207%20%E9%87%8D%E7%BD%AE%E8%AE%A1%E6%95%B0%E5%99%A8%E5%AF%84%E5%AD%98%E5%99%A8%20*%2F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BLIMIT_L%20%3D%200x000000CF%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BEVEN%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BDMAREQ0%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3ELPC_SCT-%26gt%3BDMAREQ1%20%3D%200x00000000%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%26nbsp%3B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22margin-bottom%3A%20.0001pt%3B%22%3E%3CSTRONG%3E%7D%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3CH2%20style%3D%22text-indent%3A%20-.25in%3B%20margin%3A%200in%200in%20.0001pt%20.5in%3B%22%20id%3D%22toc-hId-1850294510%22%20id%3D%22toc-hId--1522109814%22%3Ev%20%E7%BB%93%E6%9E%9C%E8%AF%81%E6%98%8E%3C%2FH2%3E%3CP%3E%E8%AF%A5%E6%BC%94%E7%A4%BA%E5%9C%A8%20LPCXpresso824-MAX%20%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%E8%93%9D%E8%89%B2%20LED%20%E6%9B%BF%E6%8D%A2%E9%BB%84%E8%89%B2%20LED%EF%BC%8C%E8%A7%86%E9%A2%91%E6%98%BE%E7%A4%BA%E6%BC%94%E7%A4%BA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_43.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_43.png%22%20style%3D%22width%3A%20413px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F3090i75265F03EEF9DBB9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_43.png%22%20alt%3D%22pastedImage_43.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E5%9B%BE7%20LPCXpresso824-MAX%E6%9D%BF%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%E8%A7%86%E9%A2%91%E9%93%BE%E6%8E%A5%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fyoutu.be%2Fwr4VJDaa_OY%22%20title%3D%22https%3A%2F%2Fyoutu.be%2Fwr4VJDaa_OY%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3ESCTimer%20%E5%AE%9E%E7%8E%B0%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%20-%20YouTube%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1105509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9ASCTimer%20%E5%AE%9E%E7%8E%B0%E4%BA%A4%E9%80%9A%E4%BF%A1%E5%8F%B7%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1105509%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%AF%B9%E8%BF%99%E7%A7%8D%E7%BC%96%E7%A8%8B%E5%92%8C%E7%8E%AF%E5%A2%83%E8%BF%98%E4%B8%8D%E7%86%9F%E6%82%89%E3%80%82%E6%88%91%E7%A1%AE%E5%AE%9E%E7%9F%A5%E9%81%93%E6%82%A8%E6%AD%A3%E5%9C%A8%E5%B0%86%20GPIO%20%E5%BC%95%E8%84%9A%E5%88%86%E9%85%8D%E7%BB%99%20SWM_CTL_OUT%EF%BC%8C%E4%BD%86%E6%98%AF%E5%A6%82%E4%BD%95%E8%AE%A9%E8%BF%99%E4%BA%9B%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E5%80%BC%E4%B8%8E%E5%AE%9E%E9%99%85%E5%BC%95%E8%84%9A%E9%80%9A%E4%BF%A1%EF%BC%9F%E5%9B%A0%E4%B8%BA%E6%88%91%E6%AD%A3%E5%9C%A8%E7%A0%94%E7%A9%B6%20LPC824%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%E4%BA%8B%E4%BB%B6%200%20%E4%B8%8A%E5%88%87%E6%8D%A2%20GPIO_17%EF%BC%8C%E4%BD%86%E8%BF%99%E4%BC%BC%E4%B9%8E%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎10-07-2016 11:55 PM
更新人:
