How long can short-circuit output current flow before damaging the microcontroller?
1,852 次查看
lpcware-support
Senior Contributor I
In the datasheet, there is a footnote regarding the short circuit which must be followed. There is no restriction on the time. Short circuit is allowed as long as the current doesn't exceed the max current (see limiting value) allowed by the device
标签 (2)
标记 (2)
0 回复数
