usb hub problem on k22
1,969 次查看
vikashkumar
HI All,
I'm using kinetis 1.3 USB Host Bare metal stack in quantum framework.I enabled hub in the stack, when i insert usb in hub sometime i'm getting USB Attached as well as Detached in same time. It is working perfectly without hub.
Looking for help.
Thanks in advance
1,876 次查看
jingpan
Hi vikash
Please download SDK from https://mcuxpresso.nxp.com.  Click SDK Builder button and follow it step by step. You will get it.
1,876 次查看
jingpan
Hi vikash,
I suggest you move your project to SDK2.2 if your project is just start or have enough time to immigrate. Because the USB driver in SDK2.2 is better than in SDK1.3.
1,876 次查看
vikashkumar
Hi Jing,
Could you please send the link for SDK2.2 because I searcher but i didn't get any link for SDK2.2.
vikash
