kl26z simple program eeprom
1,925件の閲覧回数
oswaldo-153
Hello all
someone has an example, using an eeprom memory 24FC512 with the MCU kl26z?
some document or information to use the eeprom memory from the kl26z
I am using the IAR compiler, I thank you very much
タグ(2)
1,849件の閲覧回数
danielchen
Hi Oswaldo:
KL doesn't have the EEPROM module, if you want to use it, you can use flash to emulate it.
About the KL EEPROM emulation, pleasae refer to below post
EEPROM emulation on KL25 using C90TFS
I hope it helps.
