keil can not accsee memory
1,139件の閲覧回数
soyshell
i used keilv5 debug mk20fn1m. but, keil give me a message"can not access memory". please tell why?
and NXP can not give me a ksdk for mk20fn1m.
1,070件の閲覧回数
Hello liu,
Have you install the related Cortex Microcontroller Software Interface Standard (CMSIS) device packs ?
These packs include things such as memory map information, register definitions and flash programming algorithms.
About the detail information  please refer to the DOC:Getting Started with Kinetis SDK (KSDK) v.1.3.pdf
( it under : KSDK_1.3.0\doc ) , the chapter 4 Run a demo using Keil MDK/uVision.
Please refer to this  DOC step by step, you can first build one demo under the KSDK , then create one project
by yourself .
If still have problem , please let me know.
Hope it helps !
Alice
