iRTC vs RTC
iRTC vs RTC
2,644 次查看
randyhermes
What is the difference between iRTC and RTC modules?  Which API should I use with MK22FX512VLQ12?
Datasheet calls it an independent RTC, but module section is for RTC.
The SDK documentation mixes in iRTC functions in the RTC section.
I'm a bit confused.
2,457 次查看
randyhermes
I believe I have found the answer.
Based on MKMxxZxxCxx5RM.pdf the IRTC has separate year, month, day, hour, minute and second counters.   The RTC has a single 32 bit seconds counter.
The K22 processors have an RTC.
Randy
2,457 次查看
ivadorazinova
Hello Randy,
it is a very good question.
According to Enabling the IRTC Module - AN4023.pdf it looks there are no huge differences.
However, please, give me short time to gather more details for you.
I will answer as soon as possible.
Iva
2,458 次查看
randyhermes
Randy
2,457 次查看
randyhermes
Thank you Iva.
Appreciate the info.  I'll look over the app note.
Randy
