how to create new project ?
mesdouaabderraz
hello, i have a problem whith board type " Frdm-k82f ", when i generate a new project whith "KSDK_Project_Generator_x64 or x86 ", It does not create the " .wsd " in ksd file.
marek-trmac
.wsd file is no more needed for SDK 2.x, because there is just one project generated. Use "File - Import... - General - Existing Projects into Workspace" to import generated project into KDS.
Marek
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
