f_utime() from ff.c seems to be volatile
5,982 次查看
markeckerberg
I can set the date/time of a file with f_utime() and the function returns success, then I can read the date/time with f_stat() and I see the new date/time, then I can detach and re-attach the flash drive and f_stat() still shows the old date/time as does a PC.  Is there another step required to make it non-volatile?
4 回复数
5,685 次查看
danielchen
Hi Mark:
Could you please let me know your KSDK version ? how can I reproduce your issue, on a TWR-BOARD?
5,679 次查看
markeckerberg
Yes, thank you.
I am using a FRDM-K22F with MCUXpresso IDE v10.0.2 and SDK_2.2_FRDM-K22F.
I am working with frdmk22f_usb_examples_usb_host_msd_fatfs_bm.
Mark
5,679 次查看
danielchen
Hi Mark:
Sorry I still can't  reproduce your issue on my end. I tested this demo on Frdm-K22F board.  With this demo, one file f_1.dat was created, time-stampe is 2016-1-1,  then change the timestamp to 2015-10-1, and next rename this file to f_2.dat, delete it. The console output is:
To reproduce your issue, I modified this demo a little, just not delete this file, then check this u-disk  and verify this file with my PC, I can see the timestamp is still 2015-10-1, it seems the time stamp has changed successfully , please see below picture.  would you please double check it?
5,679 次查看
markeckerberg
Thank you for running this test. Your test also changes read only attributes and renames the file so I tried adding that and that seems to make the time date stick. When I remove changing the read only flag, again it doesn’t stick. Do I need to set and then remove read only every time I change the time date? For my application I only want to change the time date.
Mark
