document for Fatfs middleware for K66
Weining
I want to implement USB MSD function with K66 and KSDK 1.3 version; I don’t want to a RTOS.
Does anybody know if the fatfs work without RTOS? Where can I find the documents for the fatfs stack?
Thank you,
Weining Li
isaacavila
Hello Weining,
Indeed, there are some examples for USB + fatfs on KSDK 1.3 version that do not use any RTOS (they are BareMetal). You can give a look to these examples at: <KSDK_1_3_PATH>\examples\<BOARD>\demo_apps\usb\<DEVICE_OR_HOST>\msd\BM\<IDE>.
Here you can find Fatfs documentation: FatFs - Generic FAT File System Module
And also, here is a document for USB + Fatfs + Processor Expert reference that might be helpful for you: USB Host Project with KSDK 1.3 and Processor Expert
Hope this helps!
Isaac
isaacavila
Hello Weining,
Hope this helps!
Isaac
Weining
Hi Isaac,
Thanks a lot for your help, I really appreciate it.
I tested the project you mentioned last week. it works for my application.
Weining
