USB msd throughput test unit
2,383 次查看
Hiroki
I'm trying to measure the USB msd throughput on FRDM-K64F.
I would like to know the unit of this result. KB/s or kbps?
Could you share me this information?
Hiroki
标记 (2)
2,230 次查看
ivadorazinova
Hi Hiroki Maruoka,
please, do you use the emulated memory or SD card?
Iva
2,230 次查看
Hiroki
Hi Iva,
I used a USB memory stick.
I read the code and calculated the read/write data size. It is 100MByte. So it seems to be KB/s.
Is is correct?
Hiroki
2,230 次查看
ivadorazinova
Hi Hiroki Maruoka,
so if you write/read 100MB data and writing takes some time, you can express write speed in MB/s or KB/s.
If you need from the value kbps, multiply by 8. So KB/s*8.
Iva
