USB msd throughput test unit
2,389件の閲覧回数
Hiroki
I'm trying to measure the USB msd throughput on FRDM-K64F.
I would like to know the unit of this result. KB/s or kbps?
Could you share me this information?
Hiroki
タグ(2)
3 返答(返信)
2,236件の閲覧回数
ivadorazinova
Hi Hiroki Maruoka,
please, do you use the emulated memory or SD card?
Iva
2,236件の閲覧回数
Hiroki
Hi Iva,
I used a USB memory stick.
I read the code and calculated the read/write data size. It is 100MByte. So it seems to be KB/s.
Is is correct?
Hiroki
2,236件の閲覧回数
ivadorazinova
Hi Hiroki Maruoka,
so if you write/read 100MB data and writing takes some time, you can express write speed in MB/s or KB/s.
If you need from the value kbps, multiply by 8. So KB/s*8.
Iva
