UDP_ECHO
UDP_ECHO
2,228件の閲覧回数
shankarislavath
hi,
iam using the udp_echo from sdk2.0, signals are not comming out of the processor wen i make a full run .
ans i had made all the changes said in the read me file.
2,037件の閲覧回数
shankarislavath
even though problem is not solve ,we are using LAN8710A but in freedom board they used KSZ8081 PHY whether this creates any issue .
2,037件の閲覧回数
ivadorazinova
Hello SHANKAR ISLAVATH,
I apologize for my late response.
I tried whole procedure also with Hercules and Wireshark and all works.
Please, are you sure that you correctly set IP Addresses ?
and
In Wireshark is also working without problems:
needs to be correctly set network card
I hope this helps you.
Iva
