Hi guys and gals,
there seems to be a small error in the FLEXCAN_DRV_Send documentation in fsl_flexcan_driver.h.
* @param timeout_ms A timeout for the transfer in microseconds.
should be
* @param timeout_ms A timeout for the transfer in milliseconds.
as is evident by the name itself (ms commonly being the acronym for milliseconds) and by checking the source code, which calls
OSA_SemaWait(&state->txIrqSync, timeout_ms);
which in turn declares "The parameter timeout indicates how long should wait in milliseconds." [sic].
I don't know if there's a (public) issue tracker for KDSK, so please feel free to add it to your list. Thanks.
Martin
 ivadorazinova
			ivadorazinova
		Hi Martin Rentschler,
Yes, you are right. It should be milliseconds.
It is a good point! Thank you for your report. I will transmit the information to KSDK development team.
Iva
