Secure Bootloader AES help
4,397件の閲覧回数
marcobologna
Hello!
I would like to use on kinetis KV11Z and MK22FX the bootloader with security aes.
When I try to compile, it asks me for the file aes_security.h and I can't find it.
Can anyone help me?
Is there a step by step tutorial that helps to implement security aes in bootloader 2.5?
Thanks in advance.
Marco
4,237件の閲覧回数
jingpan
MCUboot has been integrated into SDK. You can find this file in SDK_2.6.0_TWR-K22F120M\middleware\mcu-boot\tools\tools\elftosb\common
Jing
4 返答(返信)
4,237件の閲覧回数
jingpan
Hi Macro,
aes_security.h and aes_security.c use MMCAU. This is a special hardware that KV11 and K22 haven't.You can only use software encryption and decryption. The code is in aes128_key_wrap_unwrap.c
Jing
4,237件の閲覧回数
marcobologna
Dear Jing
Thanks for your reply.
The aes128_key_wrap_unwrap.c is missing in the MCU-BOOT v 2.5  source code. How I can find it and how I can insert it? How use it?
Marco
4,238件の閲覧回数
jingpan
Jing
4,237件の閲覧回数
marcobologna
Hi Jing,
Thanks for your help. We solved the problem.
Marco
