SIM_HAL_Get_____Id() not includet in KSDK2.0
1,245 次查看
manfredschnell
we use NXP K64 with KSDK2.0.
I can't find functions to get the processor internal informations.
In KSDK1.3 they where includet with
SIM_HAL_GetFamilyId(SIM);
SIM_HAL_GetSubFamilyId(SIM);
SIM_HAL_GetSeriesId(SIM);
SIM_HAL_GetRevId(SIM);
SIM_HAL_GetDieId(SIM);
SIM_HAL_GetFamId(SIM);
SIM_HAL_GetPinCntId(SIM);
Will these functions be included in next release KSDS2.x?
Manfred
963 次查看
DavidS
Hi Manfred,
Not sure if the exact API calls will be added to KSDK_v2 in the future or not.  But you can get access to the data with what is present in KSDK_v2.  I modified the hello_world example for frdm-k64f Freedom board as follows:
    PRINTF("hello world.\r\n");
#if 1 //DES 1=test (access to SIM registers), 0=default code
    uint32_t my_sim_sdid, FamilyID, SubFamilyID, SeriesID, RevID, DieID, FamID, PinID;
  SIM_Type *my_sim_ptr = (SIM_Type*)(SIM_BASE);
  my_sim_sdid = my_sim_ptr->SDID;
  FamilyID = SIM_SDID_FAMILYID_MASK&(my_sim_sdid);
  SubFamilyID = SIM_SDID_SUBFAMID_MASK&(my_sim_sdid);
  SeriesID = SIM_SDID_SERIESID_MASK&(my_sim_sdid);
  RevID = SIM_SDID_REVID_MASK&(my_sim_sdid);
  DieID = SIM_SDID_DIEID_MASK&(my_sim_sdid);
  FamID = SIM_SDID_FAMID_MASK&(my_sim_sdid);
  PinID = SIM_SDID_PINID_MASK&(my_sim_sdid);
#if 1 //DES 1=change output format, 0=default code
  FamilyID >>= SIM_SDID_FAMILYID_SHIFT;
  SubFamilyID >>= SIM_SDID_SUBFAMID_SHIFT;
  SeriesID >>= SIM_SDID_SERIESID_SHIFT;
  RevID >>= SIM_SDID_REVID_SHIFT;
  DieID >>= SIM_SDID_DIEID_SHIFT;
  FamID >>= SIM_SDID_FAMID_SHIFT;
  PinID >>= SIM_SDID_PINID_SHIFT;
#endif
  PRINTF("\n FamilyID = %x\n SubFamilyID = %x\n SeriesFamilyID = %x\n RevID = %x\n DieID = %x\n FamID = %x\n PinID = %x",\
  FamilyID, SubFamilyID, SeriesID, RevID, DieID, FamID, PinID);
#endif
David
964 次查看
DavidS
Hi Manfred,
#endif
#endif
David
