SGI with multiprocessing
938件の閲覧回数
khaledali
Hello all
I'm trying to run the test code generated in side the SDK multicore_test , it based on a Software Generated Interrupt  concept by changing the .
my problem is that the code itself doesn't work properly as only the software interrupt can be targeted from cpu 1 to
cpu 0 only
I also tried to generate the first interrupt by cpu2 and target it to CPU1 , the cpu1 also didn't serve the interrupt
to sum up what i really wants to do :
I need for proper steps for generating a Software interrupt from core0 targeting core1 and core1 handle the request.
0 返答(返信)
