SDK Project Generator Tool in Win 7 32-bit
1,338 次查看
BillHoyt
Fresh Out Contributor
After downloading this:
     Kinetis SDK Project Generator Tool (REV 2)
and attempting to run the "Windows" version (KSDK_Project_Generator.exe) on Windows 7 (32-bit) PC, this error occurs:
"The version of this file is not compatible with the version of Windows you're running.  Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher"
My guess is this app is only for 64-bit Windows.
1,216 次查看
ivadorazinova
Hi Bill,
thank you for pointing out this!
Unfortunately I can confirm this issue also on my side.
I reported the bug, http://sw-jira.freescale.net/browse/PGKSDK-258
I will keep you informed about this.
Thank you.
Iva
