SDK 2.0 KEx Tools problem SDHC
1,162件の閲覧回数
danielecortella
Hello i have a problem with the KEx Tools 2.0 with the micro MK22FX512AVLL12. I have to set the SDHC clock to 25Mhz but i don't understand why i have this error:
i have set this configuration:
Clocks Report
ClockFastClockNormal
Description
ConfigurationRun ModeRUNRUN
MCG ModePEE (PLL Engaged External)PEE (PLL Engaged External)
Clock sourcesOSC (System Oscillator)8 MHz8 MHz
RTC32kHz32.768 kHz32.768 kHz
FAST_IRCLKInactiveInactive
SLOW_IRCLKInactiveInactive
LPO1 kHz1 kHz
USB clock inputInactiveInactive
Clock outputsCore clock120 MHz30 MHz
System clock120 MHz30 MHz
Bus clock60 MHz30 MHz
FlexBus clock40 MHz30 MHz
Flash clock24 MHz15 MHz
MCGIRCLKInactiveInactive
MCGFFCLK250 kHz250 kHz
OSCERCLK8 MHz8 MHz
ERCLK32KInactiveInactive
RTC_CLKOUTInactiveInactive
MCG PLL/FLL clock120 MHzInactive
LPO clock1 kHz1 kHz
USB FS clock48 MHzInactive
Trace clock inputInactiveInactive
SDHC clock120 MHzInactive
CLKOUT (FB_CLK)InactiveInactive
タグ(3)
0 返答(返信)
