SD CARD ON MK66FN2M0VLQ18
1,309件の閲覧回数
gamma
Hi!
I'm working with the MK66FN2M0VLQ18 MCU on KDS 3.2 and Processor Expert, and I need to use SD storage... but the FATFSmemSDHC component isn't compatible with the project because I need to use KSDK...
So, I used the fsl_sdhc component, following this tuto:
 FRDM K64F Data Logger using FatFs with KSDK 1.2.0 | Centaurian
but! the SD has an unpredictable behavior, sometimes it works, but sometimes it fails...
finally, here is my question:
¿does anyone know how to work with micro SD in this MCU, or any tutorial or way to use the SD?
Thanks!
1,209件の閲覧回数
xiangjun_rong
Hi, Gamaliel,
This is a training doc for SD card, hope it can help you.
https://community.nxp.com/docs/DOC-330958
Hope it can help you
Xiangjun Rong
