Pin configurator tool
4,222 次查看
martinfiset
Hello, A few weeks ago I had found an online tool that helped configured Kinetis MCU prior to software development. Unfortunately, I am unable to find it again. The tool allowed to configure pins and select the different peripherals. I am starting a design with a K22 Kinetis MCU. I am using KDS v3. And KDSK v2 for the K22 And I am searching for a tool that will help pins configuration. (since I cannot use processor expert with the KDSK v2). Thanks
2,326 次查看
BlackNight
Hi Martin,
the Pins tool (i.MX and Kinetis) is available here:
New Kinetis Expert Pins Tool V1.0 Available!
https://community.nxp.com/videos/5971
I hope this helps,
Erich
2,326 次查看
ivadorazinova
Hello Martin,
Maybe you had in your mind pin mux tool with i.MX -  Interactive i.MX Pin Mux Tool
This tool is unfortunately not available for Kinetis right now.
But pin muxing configuration tool will be available soon - you can forward to new tools coming in 2016:
Kinetis SDK 2.0 Transition Guide Page 9 of 13 : New features will be added over time to the Kinetis Expert Tool to allow for pin muxing selection and generation, clock configuration, and low power estimation.
I hope this helps you.
Have a great day!
Iva
