KSDK V1.2.0 USB compile errors
Chiz
I built a usb cdc application using the USB KSDK V1.2.0 stack. I am having compile errors (using KDS 3.0.0).
I have compiled the example project "virtual_com" for USB cdc application, and it compiles fine. I don't see the compile errors.
I copied that project, renamed it and created some functions, however the USB application code is the same. My project compiles with USB errors associated with usb_device_stack_interface.h
The compiler can't find where data types are defined. Data types such as "uint8_t, uint16_t, uint32_t"...
usb_device_stack_interface.h does not include types.h or usb_types.h.
types.h seems to have a problem with the construct:
typedef unsigned long bool
It throws an error saying: "both 'long' and '_Bool' in declaration specifiers"
Does anyone know how to get around these errors associated with the USB stack?
Chiz
DavidS
Hi Chiz,
I've been using the virtual com demo in KSDK_1.3 successfully.
You might want to upgrade http://www.freescale.com/ksdk
David
Chiz
These are the errors from the build:
10:33:14 **** Incremental Build of configuration debug for project lipss_bm_frdmkl27z ****
make -k all
Building file: C:/Freescale/KSDK_1.3.0/platform/utilities/src/fsl_debug_console.c
Invoking: Cross ARM C Compiler
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"utilities/fsl_debug_console.d" -MT"utilities/fsl_debug_console.o" -c -o "utilities/fsl_debug_console.o" "C:/Freescale/KSDK_1.3.0/platform/utilities/src/fsl_debug_console.c"
Finished building: C:/Freescale/KSDK_1.3.0/platform/utilities/src/fsl_debug_console.c
Building file: C:/Freescale/KSDK_1.3.0/platform/utilities/src/fsl_misc_utilities.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"utilities/fsl_misc_utilities.d" -MT"utilities/fsl_misc_utilities.o" -c -o "utilities/fsl_misc_utilities.o" "C:/Freescale/KSDK_1.3.0/platform/utilities/src/fsl_misc_utilities.c"
Finished building: C:/Freescale/KSDK_1.3.0/platform/utilities/src/fsl_misc_utilities.c
Building file: C:/Freescale/KSDK_1.3.0/platform/utilities/src/print_scan.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"utilities/print_scan.d" -MT"utilities/print_scan.o" -c -o "utilities/print_scan.o" "C:/Freescale/KSDK_1.3.0/platform/utilities/src/print_scan.c"
Finished building: C:/Freescale/KSDK_1.3.0/platform/utilities/src/print_scan.c
Building file: C:/Freescale/KSDK_1.3.0/platform/devices/startup.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"startup/startup.d" -MT"startup/startup.o" -c -o "startup/startup.o" "C:/Freescale/KSDK_1.3.0/platform/devices/startup.c"
Finished building: C:/Freescale/KSDK_1.3.0/platform/devices/startup.c
Building file: C:/Freescale/KSDK_1.3.0/platform/devices/MKL27Z644/startup/gcc/startup_MKL27Z644.S
Invoking: Cross ARM GNU Assembler
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -x assembler-with-cpp -DDEBUG -fno-common  -ffunction-sections  -fdata-sections  -ffreestanding  -fno-builtin  -Os  -mapcs  -std=gnu99 -MMD -MP -MF"startup/startup_MKL27Z644.d" -MT"startup/startup_MKL27Z644.o" -c -o "startup/startup_MKL27Z644.o" "C:/Freescale/KSDK_1.3.0/platform/devices/MKL27Z644/startup/gcc/startup_MKL27Z644.S"
Finished building: C:/Freescale/KSDK_1.3.0/platform/devices/MKL27Z644/startup/gcc/startup_MKL27Z644.S
Building file: C:/Freescale/KSDK_1.3.0/platform/devices/MKL27Z644/startup/system_MKL27Z644.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"startup/system_MKL27Z644.d" -MT"startup/system_MKL27Z644.o" -c -o "startup/system_MKL27Z644.o" "C:/Freescale/KSDK_1.3.0/platform/devices/MKL27Z644/startup/system_MKL27Z644.c"
Finished building: C:/Freescale/KSDK_1.3.0/platform/devices/MKL27Z644/startup/system_MKL27Z644.c
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Cpu.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/Cpu.d" -MT"sources/Cpu.o" -c -o "sources/Cpu.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Cpu.c"
In file included from C:\Freescale\KSDK_1.3.0\platform\system\inc/fsl_clock_manager.h:35:0,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Cpu.h:72,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Cpu.c:68:
C:\Freescale\KSDK_1.3.0\usb\usb_core\include/types.h:65:23: error: both 'long' and '_Bool' in declaration specifiers
typedef unsigned long bool; /* Machine representation of a bool */
In file included from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Events.h:42:0,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Cpu.c:69:
C:\Freescale\KSDK_1.3.0\usb\usb_core\include/types.h:65:1: warning: useless type name in empty declaration [enabled by default]
sources/subdir.mk:66: recipe for target 'sources/Cpu.o' failed
make: *** [sources/Cpu.o] Error 1
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/DbgCs1.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/DbgCs1.d" -MT"sources/DbgCs1.o" -c -o "sources/DbgCs1.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/DbgCs1.c"
Finished building: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/DbgCs1.c
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Events.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/Events.d" -MT"sources/Events.o" -c -o "sources/Events.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Events.c"
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/clockMan1.h:177,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/osa1.h:96,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Events.h:35,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/Events.c:30:
sources/subdir.mk:80: recipe for target 'sources/Events.o' failed
make: *** [sources/Events.o] Error 1
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssCom.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/LipssCom.d" -MT"sources/LipssCom.o" -c -o "sources/LipssCom.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssCom.c"
In file included from C:\Freescale\KSDK_1.3.0\platform\osa\inc/fsl_os_abstraction.h:34:0,
                 from C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk/adapter_sdk.h:36,
                 from C:\Freescale\KSDK_1.3.0\usb\adapter\sources/adapter.h:43,
                 from C:\Freescale\KSDK_1.3.0\usb\usb_core\include/usb.h:34,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssCom.c:9:
In file included from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssLog.h:12:0,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssCom.c:11:
sources/subdir.mk:87: recipe for target 'sources/LipssCom.o' failed
make: *** [sources/LipssCom.o] Error 1
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssLog.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/LipssLog.d" -MT"sources/LipssLog.o" -c -o "sources/LipssLog.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssLog.c"
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssLog.c:8:
C:\Freescale\KSDK_1.3.0\usb\usb_core\include/types.h:47:20: error: expected declaration specifiers or '...' before '*' token
#define _CODE_PTR_ *
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class.h:91:21: note: in expansion of macro '_CODE_PTR_'
typedef usb_status (_CODE_PTR_ device_class_init_call) (uint8_t controller_id, void* class_config_ptr, class_handle_t* class_handle_ptr);
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class.h:93:21: note: in expansion of macro '_CODE_PTR_'
typedef usb_status (_CODE_PTR_ device_class_deinit_call) (class_handle_t handle);
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class.h:97:21: note: in expansion of macro '_CODE_PTR_'
typedef usb_status (_CODE_PTR_ device_class_request_callback) (usb_setup_struct_t* setup_packet, uint8_t **data, uint32_t * size, void* arg);
In file included from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssUSBDescriptor.h:181:0,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssCom.h:11,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssLog.c:9:
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class_cdc.h:134:5: error: unknown type name 'usb_application_callback_struct_t'
     usb_application_callback_struct_t        cdc_application_callback;        /*!< application callback function to handle the Device status related event*/
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class_cdc.h:135:5: error: unknown type name 'usb_vendor_req_callback_struct_t'
     usb_vendor_req_callback_struct_t         vendor_req_callback;             /*!< application callback function to handle the vendor request related event, reserved for future use*/
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class_cdc.h:137:5: error: unknown type name 'usb_desc_request_notify_struct_t'
     usb_desc_request_notify_struct_t*        desc_callback_ptr;               /*!< descriptor related callback function data structure*/
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class_cdc.h:138:5: error: unknown type name 'usb_board_init_callback_struct_t'
     usb_board_init_callback_struct_t         board_init_callback;             /*!< application callback function to handle board init*/
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class_cdc.h:183:1: error: unknown type name 'usb_status'
extern usb_status USB_Class_CDC_Init
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class_cdc.h:199:1: error: unknown type name 'usb_status'
extern usb_status USB_Class_CDC_Deinit
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class_cdc.h:239:1: error: unknown type name 'usb_status'
extern usb_status USB_Class_CDC_Send_Data
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class_cdc.h:257:1: error: unknown type name 'usb_status'
extern usb_status USB_Class_CDC_Recv_Data
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class_cdc.h:279:1: error: unknown type name 'usb_status'
extern usb_status USB_Class_CDC_Get_Speed
In file included from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssSystem.h:15:0,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssCom.h:12,
C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk/adapter_sdk.h:105:34: error: unknown type name 'os_msgq_handle'
extern uint32_t OS_MsgQ_Is_Empty(os_msgq_handle msgq, void* msg);
sources/subdir.mk:94: recipe for target 'sources/LipssLog.o' failed
make: *** [sources/LipssLog.o] Error 1
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssStateMachine.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/LipssStateMachine.d" -MT"sources/LipssStateMachine.o" -c -o "sources/LipssStateMachine.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssStateMachine.c"
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/osa1.h:97,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/clockMan1.h:176,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/gpio.h:71,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssSystem.h:11,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssStateMachine.c:8:
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssSystem.h:14,
sources/subdir.mk:101: recipe for target 'sources/LipssStateMachine.o' failed
make: *** [sources/LipssStateMachine.o] Error 1
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssSystem.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/LipssSystem.d" -MT"sources/LipssSystem.o" -c -o "sources/LipssSystem.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssSystem.c"
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssSystem.c:8:
sources/subdir.mk:108: recipe for target 'sources/LipssSystem.o' failed
make: *** [sources/LipssSystem.o] Error 1
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssUSBDescriptor.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/LipssUSBDescriptor.d" -MT"sources/LipssUSBDescriptor.o" -c -o "sources/LipssUSBDescriptor.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssUSBDescriptor.c"
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssUSBDescriptor.c:177:
In file included from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssUSBDescriptor.h:182:0,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssUSBDescriptor.c:179:
sources/subdir.mk:115: recipe for target 'sources/LipssUSBDescriptor.o' failed
make: *** [sources/LipssUSBDescriptor.o] Error 1
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/adConv.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/adConv.d" -MT"sources/adConv.o" -c -o "sources/adConv.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/adConv.c"
Finished building: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/adConv.c
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/clockMan1.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/clockMan1.d" -MT"sources/clockMan1.o" -c -o "sources/clockMan1.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/clockMan1.c"
Finished building: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/clockMan1.c
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/gpio.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/gpio.d" -MT"sources/gpio.o" -c -o "sources/gpio.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/gpio.c"
Finished building: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/gpio.c
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/hardware_init.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/hardware_init.d" -MT"sources/hardware_init.o" -c -o "sources/hardware_init.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/hardware_init.c"
Finished building: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/hardware_init.c
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/main.c
Invoking: Cross ARM C Compiler
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/main.d" -MT"sources/main.o" -c -o "sources/main.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/main.c"
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/main.c:31:
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/main.c:33:
In file included from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/LipssUSBDescriptor.h:180:0,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/main.c:42:
C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include/usb_class.h:97:64: error: unknown type name 'usb_setup_struct_t'
sources/subdir.mk:150: recipe for target 'sources/main.o' failed
make: *** [sources/main.o] Error 1
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/osa1.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/osa1.d" -MT"sources/osa1.o" -c -o "sources/osa1.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/osa1.c"
Finished building: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/osa1.c
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/pin_mux.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/pin_mux.d" -MT"sources/pin_mux.o" -c -o "sources/pin_mux.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/pin_mux.c"
Finished building: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/pin_mux.c
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/pitTimer1.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/pitTimer1.d" -MT"sources/pitTimer1.o" -c -o "sources/pitTimer1.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/pitTimer1.c"
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/pitTimer1.h:75,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/pitTimer1.c:54:
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/pitTimer1.c:55:
sources/subdir.mk:171: recipe for target 'sources/pitTimer1.o' failed
make: *** [sources/pitTimer1.o] Error 1
Building file: C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/spiPort0.c
arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -Os -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -Wall  -g -D_DEBUG=1 -DCPU_MKL27Z64VLH4 -DFRDM_KL27Z -DFREEDOM -I"C:\Freescale\KSDK_1.3.0\platform\utilities\inc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\platform\devices" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\startup" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\composite" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\hal" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\platform\CMSIS\Include" -I"C:\Freescale\KSDK_1.3.0\platform\devices\MKL27Z644\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\include\MKL27Z644" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\audio" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\common" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\hid" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\include\config" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\device\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\include" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\cdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\hub" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\msd" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\classes\phdc" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller\khci" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\host\sources\controller" -I"C:\Freescale\KSDK_1.3.0\usb\usb_core\include" -I"C:\Freescale\KSDK_1.3.0\platform\hal\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\gpio" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\pit" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\dma" -I"C:\Freescale\KSDK_1.3.0\platform\system\inc" -I"C:\Freescale\KSDK_1.3.0\platform\drivers\src\uart" -I"C:\Freescale\KSDK_1.3.0\platform\osa\inc" -I"C:\Freescale\KSDK_1.3.0\rtos" -I"C:\Freescale\KSDK_1.3.0\usb\adapter" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources" -I"C:\Freescale\KSDK_1.3.0\usb\adapter\sources\sdk" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com" -I"C:\Users\cchikwendu\Desktop\WorkingFolder\LIPSS\FRDM-KL27Z\cdc\lipss_com\bm\kds" -std=gnu99 -fno-strict-aliasing -Wno-format  -fno-common  -ffreestanding  -fno-builtin  -mapcs -MMD -MP -MF"sources/spiPort0.d" -MT"sources/spiPort0.o" -c -o "sources/spiPort0.o" "C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/spiPort0.c"
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/spiPort0.h:73,
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/spiPort0.c:54:
                 from C:/Users/cchikwendu/Desktop/WorkingFolder/LIPSS/FRDM-KL27Z/cdc/lipss_com/spiPort0.c:55:
sources/subdir.mk:178: recipe for target 'sources/spiPort0.o' failed
make: *** [sources/spiPort0.o] Error 1
make: Target 'all' not remade because of errors.
10:33:20 Build Finished (took 5s.668ms)
DavidS
Hi Chiz,
Two things to try.
1- Solving the 8192 Character Command Line Limit on Windows | MCU on Eclipse
2- Please shorted the path to your active workspace.  I simply have my workspace in the KSD_1.3.0 root folder.
I did test C:\Freescale\KSDK_1.3.0\examples\frdmkl27z\demo_apps\usb\device\cdc\virtual_com\bm\kds on frdm-kl27z successfully.
David
Chiz
Hi David,
I will try KSDK_1.3 and I'll let you know if it works.
Chiz
Hi David,
I did try KSDK_1.3.0, and I'm getting the same compile errors.
I created a new project trying to use KSDK 1.3, and I still get the same compile errors.
I am always able to compile the "virtual_com" project, however, I can't seem to compile mine successfully. My project uses the files from "virtual_com" with minimal change, in addition to other functions I created.
The compile errors are associated with the "USB files" from the KSDK. Notably "usb_device_interface.h".
I'm willing to try any suggestions you or anyone else might have.
Thanks a lot for your help.
Chiz
michaelhuslig
I was just having the same problem.
I added the lines
#include "usb_device_config.h"
#include "usb.h"
before the line
#include "usb_device_stack_interface.h"
and the problem went away
