KSDK Linker Error - Command line too long
21,939 次查看
larrykoos
I'm using KDS 1.1.1 with MQX_KSDK 1.0.0. I've built a project with Processor Expert targeting a K64 part. After using the project successfully for several weeks, I have reached a point where I get a linker error such as:
arm-none-eabi-g++: error: C:/Freescale/KDS_1.1.1/eclipse//../toolchain/arm-none-eabi/lib/m4fp/v4-sp-d16/libm.a: No such file or directory
Through experimentation, I have determined this error is caused by a linker command line that exceeds a maximum threshold. Here is an example of the command line auto-generated by the tool:
arm-none-eabi-g++ -mcpu=cortex-m4 -mthumb -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O0 -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections  -g3 -T "C:/Users/Larry/git/asr_v1/asr_v1/Project_Settings/Linker_Files/ProcessorExpert.ld" -Xlinker --gc-sections -L"C:/Users/Larry/git/asr_v1/asr_v1/Project_Settings/Linker_Files" -L"C:\Users\Larry\workspace.kds\xbee\Debug" -Wl,-Map,"asr_v1.map" -nostartfiles -nodefaultlibs -nostdlib -Xlinker -z -Xlinker muldefs -Xlinker -static -o "asr_v1.elf"  ./Static_Code/System/PE_low_level_init.o  ./Sources/xbee/xbee_platform_posix.o ./Sources/xbee/xbee_serial_mqx.o  ./Sources/Events.o ./Sources/asrMessaging.o ./Sources/main.o ./Sources/mqx_tasks.o ./Sources/telit.o ./Sources/uart_handler.o  ./SDK/rtos/mqx/mqx_stdlib/source/strings/strings.o  ./SDK/rtos/mqx/mqx_stdlib/source/stdio/buf_prv.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/err.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fclose.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fflush.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fopen.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fp_prv.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fread.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/fwrite.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/get.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/pos.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/print.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/print_prv.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/put.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/scan.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/scan_prv.o ./SDK/rtos/mqx/mqx_stdlib/source/stdio/stdio.o  ./SDK/rtos/mqx/mqx/source/string/str_utos.o ./SDK/rtos/mqx/mqx/source/string/strnlen.o ./SDK/rtos/mqx/mqx/source/string/unicode.o  ./SDK/rtos/mqx/mqx/source/psp/cortex_m/core/M4/boot.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/core/M4/dispatch.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/core/M4/support.o  ./SDK/rtos/mqx/mqx/source/psp/cortex_m/compiler/gcc_arm/comp.o  ./SDK/rtos/mqx/mqx/source/psp/cortex_m/cortex.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_gkis.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_inst.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_kisr.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_pvta.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_unx.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_vtab.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/int_xcpt.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/ipsum.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/mem_copy.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/mem_zero.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/nvic.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_dati.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_gelms.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_hoti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_iinit.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_mat1.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_mat2.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_mat3.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_miti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_msti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_mstiq.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_nsti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_psti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_seti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_supp.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tiad.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tida.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tihr.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_timn.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tims.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tinm.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tins.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tiol.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tipr.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tips.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tise.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tisu.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tius.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_tkti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/psp_usti.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/sc_irdyq.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/stack_bu.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/stack_de.o ./SDK/rtos/mqx/mqx/source/psp/cortex_m/stack_st.o  ./SDK/rtos/mqx/mqx/source/nio/src/errno.o ./SDK/rtos/mqx/mqx/source/nio/src/nio.o  ./SDK/rtos/mqx/mqx/source/nio/fs/fs_supp.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_tty/src/nio_tty.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_tfs/src/nio_tfs.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_serial/src/nio_serial.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_pipe/src/nio_pipe.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_null/src/nio_null.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_mem/src/nio_mem.o  ./SDK/rtos/mqx/mqx/source/nio/drivers/nio_dummy/src/nio_dummy.o  ./SDK/rtos/mqx/mqx/source/kernel/event.o ./SDK/rtos/mqx/mqx/source/kernel/idletask.o ./SDK/rtos/mqx/mqx/source/kernel/inittask.o ./SDK/rtos/mqx/mqx/source/kernel/int.o ./SDK/rtos/mqx/mqx/source/kernel/klog.o ./SDK/rtos/mqx/mqx/source/kernel/log.o ./SDK/rtos/mqx/mqx/source/kernel/lwevent.o ./SDK/rtos/mqx/mqx/source/kernel/lwlog.o ./SDK/rtos/mqx/mqx/source/kernel/lwmem.o ./SDK/rtos/mqx/mqx/source/kernel/lwmsgq.o ./SDK/rtos/mqx/mqx/source/kernel/lwsem.o ./SDK/rtos/mqx/mqx/source/kernel/lwtimer.o ./SDK/rtos/mqx/mqx/source/kernel/mem.o ./SDK/rtos/mqx/mqx/source/kernel/mqx.o ./SDK/rtos/mqx/mqx/source/kernel/msg.o ./SDK/rtos/mqx/mqx/source/kernel/msgpool.o ./SDK/rtos/mqx/mqx/source/kernel/msgq.o ./SDK/rtos/mqx/mqx/source/kernel/mutex.o ./SDK/rtos/mqx/mqx/source/kernel/name.o ./SDK/rtos/mqx/mqx/source/kernel/partition.o ./SDK/rtos/mqx/mqx/source/kernel/queue.o ./SDK/rtos/mqx/mqx/source/kernel/sched.o ./SDK/rtos/mqx/mqx/source/kernel/sem.o ./SDK/rtos/mqx/mqx/source/kernel/task.o ./SDK/rtos/mqx/mqx/source/kernel/taskq.o ./SDK/rtos/mqx/mqx/source/kernel/time.o ./SDK/rtos/mqx/mqx/source/kernel/timer.o ./SDK/rtos/mqx/mqx/source/kernel/watchdog.o  ./SDK/rtos/mqx/mqx/source/bsp/K64F12/vectors.o  ./SDK/rtos/mqx/mqx/source/bsp/init_bsp.o ./SDK/rtos/mqx/mqx/source/bsp/init_hardware.o ./SDK/rtos/mqx/mqx/source/bsp/init_nio_serial.o ./SDK/rtos/mqx/mqx/source/bsp/mqx_init.o  ./SDK/rtos/mqx/config/app_mqx.o  ./SDK/platform/utilities/src/fsl_misc_utilities.o  ./SDK/platform/system/interrupt/src/fsl_interrupt_manager.o  ./SDK/platform/system/hwtimer/src/fsl_hwtimer.o ./SDK/platform/system/hwtimer/src/fsl_hwtimer_systick.o  ./SDK/platform/system/clock/MK64F12/fsl_clock_K64F12.o  ./SDK/platform/system/clock/fsl_clock_manager.o  ./SDK/platform/startup/MK64F12/system_MK64F12.o  ./SDK/platform/osa/src/fsl_os_abstraction_mqx.o  ./SDK/platform/hal/uart/fsl_uart_hal.o  ./SDK/platform/hal/sim/MK64F12/fsl_sim_hal_K64F12.o  ./SDK/platform/hal/sim/fsl_sim_hal.o  ./SDK/platform/hal/sdhc/fsl_sdhc_hal.o  ./SDK/platform/hal/port/fsl_port_hal.o  ./SDK/platform/hal/osc/fsl_osc_hal.o  ./SDK/platform/hal/mpu/fsl_mpu_hal.o  ./SDK/platform/hal/mcg/fsl_mcg_hal.o ./SDK/platform/hal/mcg/fsl_mcg_hal_modes.o  ./SDK/platform/hal/lptmr/fsl_lptmr_hal.o  ./SDK/platform/hal/gpio/fsl_gpio_hal.o  ./SDK/platform/drivers/uart/src/fsl_uart_driver.o  ./SDK/platform/drivers/uart/common/fsl_uart_common.o  ./SDK/platform/drivers/uart/fsl_uart_irq.o  ./SDK/platform/drivers/sdhc/src/fsl_sdhc_driver.o  ./SDK/platform/drivers/sdhc/common/fsl_sdhc_common.o  ./SDK/platform/drivers/sdhc/fsl_sdhc_irq.o  ./SDK/platform/drivers/mpu/src/fsl_mpu_driver.o  ./SDK/platform/drivers/mpu/common/fsl_mpu_common.o  ./SDK/platform/drivers/gpio/src/fsl_gpio_driver.o  ./SDK/platform/drivers/gpio/common/fsl_gpio_common.o  ./SDK/platform/drivers/gpio/fsl_gpio_irq.o  ./Generated_Code/Cpu.o ./Generated_Code/fsl_hwtimer1.o ./Generated_Code/fsl_mpu1.o ./Generated_Code/fsl_uart1.o ./Generated_Code/gpio_pins.o ./Generated_Code/hardware_init.o ./Generated_Code/mqx_ksdk.o ./Generated_Code/pin_init.o ./Generated_Code/sdCard1.o ./Generated_Code/uartCom0.o ./Generated_Code/uartCom3.o  C:/Freescale/KDS_1.1.1/eclipse//../toolchain/lib/gcc/arm-none-eabi/4.8.0/m4/fp/v4-sp-d16/libgcc.a C:/Freescale/KDS_1.1.1/eclipse//../toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libc.a C:/Freescale/KDS_1.1.1/eclipse//../toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libsupc++.a C:/Freescale/KDS_1.1.1/eclipse//../toolchain/arm-none-eabi/lib/m4/fp/v4-sp-d16/libm.a -lxbee
Clearly, the right way to fix this is to make a library of MQX and link in the library to the application, but I can't figure out how to do this without breaking the Processor Expert environment. Can anyone tell me the correct process?
Thanks.
标记 (3)
19,100 次查看
larrykoos
Here is a good work-around to this problem.
First, create a textfile called makefile.defs in the project's root directory. This file is referenced in the autogenerated makefile in an include statement as shown and is provided for the developer to influence an auto-generated make.
ifneq ($(strip $(S_UPPER_DEPS)),)
-include $(S_UPPER_DEPS)
endif
endif
-include ../makefile.defs
# Add inputs and outputs from these tool invocations to the build variables
# All Target
Use this file, makefile.defs, to copy all the compiled object files and libraries into a file which we called ObjectList. The makefile script we used is:
$(shell rm ObjectList)
$(foreach obj, $(OBJS), $(shell echo $(obj) >> ObjectList))
$(shell echo $(USER_OBJS) >> ObjectList)
There is probably a more efficient script than this but I'm not a script wiz.
Finally, edit the project linker settings' Command Line Pattern to remove the reference to $(INPUTS) and replace it with @ObjectList
Hope this helps.
29 回复数
13,844 次查看
giacomopetrini
tried:
new project, added ksdk_platform_lib.a to the linker path.
added (manually) all the KSDK/platform files (only the .h) putting all in the same folder ( Hal and Driver), so the includes are less. In the C and C++ compiler settings I added all the necessary path but when i compile cpp files a get an error like this:
In file included from C:\Users\jack\Dropbox\MBD\Progetti\TwingTec\Firmware\workspace\firmware\Sources\Includes\Hal/fsl_pit_hal.h:33:0,
                 from C:\Users\jack\Dropbox\MBD\Progetti\TwingTec\Firmware\workspace\firmware\Sources\Init/Cpu.h:82,
                 from C:\Users\jack\Dropbox\MBD\Progetti\TwingTec\Firmware\workspace\firmware\Sources\Init/UART3.h:69,
                 from ../Sources/SBUS.h:24,
                 from ../Sources/Futaba_sbus/FUTABA_SBUS.h:4,
                 from ../Sources/Futaba_sbus/FUTABA_SBUS.cpp:1:
C:\Users\jack\Dropbox\MBD\Progetti\TwingTec\Firmware\workspace\firmware\Sources\Includes\Hal/fsl_pit_hal.h: In function 'bool PIT_HAL_GetIntCmd(uint32_t, uint32_t)':
C:\Users\jack\Dropbox\MBD\Progetti\TwingTec\Firmware\workspace\firmware\Sources\Includes\Hal/fsl_pit_hal.h:287:22: error: 'FSL_FEATURE_PIT_TIMER_COUNT' was not declared in this scope
     assert(channel < FSL_FEATURE_PIT_TIMER_COUNT);
so it seems that it can't find the FSL_FEATURE_PIT_TIMER_COUNT #define that is in fsl_pit_features.h THAT IS IN SAME DIRECTORY AS fsl_pit_hal.h.
Any ideas?
13,846 次查看
giacomopetrini
Ok, found. I forgot to add the CPU type to the C++ preprocessor... ("CPU_MK64FN1M0VMD12").
3,827 次查看
larrykoos
Erich,
As far as I know, its not possible to build MQX as a library and continue to use PE. Is this correct or is there a way to do it?
Also, is there a way to get the tool to auto-generate the file used to pass a list of files to the linker?
3,229 次查看
arwedspringer
I have the same problem since yesterday.
Is there any known solution yet?
Thanks for any help.
3,229 次查看
larrykoos
No. We determined yesterday that it is not as simple as the command line being too long. We have another project that produces a longer command line but it links correctly. This morning we will try to verify that the problem is machine independent by building the problem on another laptop. Please let me know if you learn anything as well. Thanks.
3,229 次查看
arwedspringer
I figured out that exactly ONE character is removed from the command line string, which is always at the same position!
I added three dummy characters to the path string which was not found anymore. In the result the position where the character is missing has moved by three!
So I added a long empty entry in     property setting > Cross ARM C++ Link > Miscellaneous   just before the library which isn't found and now the linking works fine again.
(see the picture)
I know, this is just a quick hack but it works for the moment until the bug is fixed.
3,229 次查看
giacomopetrini
:smileyshocked:
ok, good to know.
Bye Giacomo
3,229 次查看
arwedspringer
I just had a look at the command line.
The missing character is exactly at position 8192 of the parameter string (whithout the command "arm-none-eabi-g++")
So it seams that there is a problem if the created parameter string is greater than 8k bytes...
Bye Springer
3,229 次查看
larrykoos
This hack works on my project as well. Hopefully someone with more knowledge with the tool can help out here and give us a real fix.
Really good catch. Thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-380908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKSDK%20%E9%93%BE%E6%8E%A5%E5%99%A8%E9%94%99%E8%AF%AF%20-%20%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%A4%AA%E9%95%BF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20KDS%201.1.1%20%E5%92%8C%20MQX_KSDK%201.0.0%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E5%92%8C%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%E4%B8%80%E8%B5%B7%E6%9E%84%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E4%BB%A5%20K64%20%E9%83%A8%E4%BB%B6%E4%B8%BA%E7%9B%AE%E6%A0%87%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%E5%9C%A8%E6%88%90%E5%8A%9F%E4%BD%BF%E7%94%A8%E8%AF%A5%E9%A1%B9%E7%9B%AE%E5%87%A0%E5%91%A8%E5%90%8E%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%93%BE%E6%8E%A5%E5%99%A8%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BE%8B%E5%A6%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Earm-none-eabi-g%2B%2B%EF%BC%9A%E9%94%99%E8%AF%AF%EF%BC%9AC%3A%20%2FFreescale%2FKDS_1.1.1%2FEclipse%2F%2F..%2Ftoolchain%2Farm-none-eabi%2Flib%2Fm4fp%2Fv4-sp-d16%2Flibm.a%EF%BC%9A%E6%97%A0%E6%AD%A4%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%E5%AE%9E%E9%AA%8C%EF%BC%8C%E6%88%91%E7%A1%AE%E5%AE%9A%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E6%98%AF%E7%94%B1%E9%93%BE%E6%8E%A5%E5%99%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E8%B6%85%E8%BF%87%E6%9C%80%E5%A4%A7%E9%98%88%E5%80%BC%E9%80%A0%E6%88%90%E7%9A%84%E3%80%82%E4%B8%8B%E9%9D%A2%E6%98%AF%E8%AF%A5%E5%B7%A5%E5%85%B7%E8%87%AA%E5%8A%A8%E7%94%9F%E6%88%90%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E7%A4%BA%E4%BE%8B%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3Earm-none-eabi-g%2B%2B-mcpu%3Dcortex-m4-mthumb-mfloat-abi%3Dhard-mfpu%3Dfpv4-sp-d16-O0-fsigned-char-ffunction-sections-function-sections-gits-gintions-gits-gintions-gits%2Flins%20%22%20C%3A%20%2FUsers%2Flinr_git%2Fasr_v1%2Fproject_settings%2Flins%20ker_files%2Fprocessorexpert.ld%20%22-Xlinker%20--gc-sections%20-L%22C%3A%2FUsers%2FLarry%2Fgit%2Fasr_v1%2Fasr_v1%2FProject_Settings%2FLinker_Files%22%20-L%22C%3A%5CUsers%5CLarry%5Cworkspace.kds%5Cxbee%5CDebug%22-Wl%2C-Map%EF%BC%8C%22asr_v1.map%22-nostartfiles%20-nodefaultlibs%20-nostdlib%20-Xlinker%20-z%20-Xlinker%20muldefs%20-Xlinker%20-static%20-o%22asr_v1.elf%22%20.%2FStatic_Code%2FSystem%2FPE_low_level_init.o%20.%2FSources%2Fxbee%2Fxbee_platform_posix.o.%2FSources%2Fxbee%2Fxbee_serial_mqx.o%20.%2FSources%2FEvents.o.%2FSources%2FasrMessaging.o%20.%2FSources%2Fmain.o.%2FSources%2Fmqx_tasks.o%20.%2FSources%2Ftelit.o%20.%2FSources%2Fuart_handler.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstrings%2Fstrings.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fbuf_prv.o.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ferr.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffclose.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffflush.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffopen..%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffp_prv.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffread.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Ffwrite.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fget.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fpos.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fprint.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fprint_prv.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fput..%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fscan.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fscan_prv.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx_stdlib%2Fsource%2Fstdio%2Fstdio.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fstring%2Fstr_utos.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fstrnlen.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fstring%2FUnicode.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2FCortex_m%2FCore%2FM%2FCore%2FM4%2F%E5%90%AF%E5%8A%A8.O.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fcore%2FM4%2Fdispatch.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fcore%2FM4%2Fsupport.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fcompiler%2Fgcc_arm%2Fcomp.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fcortex.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_gkis.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_inst.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_kisr.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_pvta..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_unx.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_vtab.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fint_xcpt.o%20.%2F.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fmem_copy.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fmem_zero.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fnvic.o%20..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_dati.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_gelms.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_hoti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_iinit..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_mat1.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_mat2.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_mat3.o%20..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_miti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_msti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_mstiq.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_nsti..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_psti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_seti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_supp.o%20..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tiad.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tida.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tihr.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_timn.o%20..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tims.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tinm.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tins.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tiol..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tipr.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tips.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tise.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tisu..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tius.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_tkti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fpsp_usti.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fsc_irdyq..%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fstack_bu.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fstack_de.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fpsp%2Fcortex_m%2Fstack_st.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fsrc%2Ferrno.o.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fsrc%2Fnio.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Ffs%2Ffs_supp.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_tty%2Fsrc%2Fnio_tty.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_tfs%2Fsrc%2Fnio_tfs.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_serial%2Fsrc%2Fnio_serial.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_pipe%2Fsrc%2Fnio_pipe.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_null%2Fsrc%2Fnio_null.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_mem%2Fsrc%2Fnio_mem.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fnio%2Fdrivers%2Fnio_dummy%2Fsrc%2Fnio_dummy.o%20.%2FSDK%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fevent.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FIdletask.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Finittask.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fint.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FKLOG.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flog.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwevent.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwlog.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwmem.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Flwmsgq.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FLWSEM.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FLWTIMER.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmem.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmqx.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FMSG.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmsgpool.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fmsgq.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FMutex.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fname.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fpartition.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fqueue.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FSched.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Fsem.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FTask.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2Ftaskq.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FTime.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FTimer.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fkernel%2FWatchdog.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2Fk64f12%2FVectors.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2Finit_bsp.o%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2Finit_Hardware.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2Finit_NIO_Serial.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fmqx%2Fsource%2Fbsp%2Fmqx_init.O%E3%80%82%2Fsdk%2Frtos%2Fmqx%2Fconfig%2Fapp_mqx.O.%2FSDK%2Fplatform%2Futilities%2Fsrc%2Ffsl_misc_utilities.o%20.%2FSDK%2Fplatform%2Fsystem%2Finterrupt%2Fsrc%2Ffsl_interrupt_manager.o%20.%2FSDK%2Fplatform%2Fsystem%2Fhwtimer%2Fsrc%2Ffsl_hwtimer.o.%2FSDK%2Fplatform%2Fsystem%2Fhwtimer%2Fsrc%2Ffsl_hwtimer_systick.o%20.%2FSDK%2Fplatform%2Fsystem%2Fclock%2FMK64F12%2Ffsl_clock_K64F12.o%20.%2FSDK%2Fplatform%2Fsystem%2Fclock%2Ffsl_clock_manager.o%20.%2FSDK%2Fplatform%2Fstartup%2FMK64F12%2Fsystem_MK64F12.o%20.%2FSDK%2Fplatform%2Fosa%2Fsrc%2Ffsl_os_abstraction_mqx.o%20.%2FSDK%2Fplatform%2Fhal%2Fuart%2Ffsl_uart_hal.o%20.%2FSDK%2Fplatform%2Fhal%2Fsim%2FMK64F12%2Ffsl_sim_hal_K64F12.o%20.%2FSDK%2Fplatform%2Fhal%2Fsim%2Ffsl_sim_hal.o%20.%2FSDK%2Fplatform%2Fhal%2Fsdhc%2Ffsl_sdhc_hal.o%20.%2FSDK%2Fplatform%2Fhal%2Fport%2Ffsl_port_hal.o%20.%2FSDK%2Fplatform%2Fhal%2Fosc%2Ffsl_osc_hal.o%20.%2FSDK%2Fplatform%2Fhal%2Fmpu%2Ffsl_mpu_hal.o%20.%2FSDK%2Fplatform%2Fhal%2Fmcg%2Ffsl_mcg_hal.o.%2FSDK%2Fplatform%2Fhal%2Fmcg%2Ffsl_mcg_hal_modes.o%20.%2FSDK%2Fplatform%2Fhal%2Flptmr%2Ffsl_lptmr_hal.o%20.%2FSDK%2Fplatform%2Fhal%2Fgpio%2Ffsl_gpio_hal.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fuart%2Fsrc%2Ffsl_uart_driver.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fuart%2Fcommon%2Ffsl_uart_common.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fuart%2Ffsl_uart_irq.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fsdhc%2Fsrc%2Ffsl_sdhc_driver.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fsdhc%2Fcommon%2Ffsl_sdhc_common.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fsdhc%2Ffsl_sdhc_irq.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fmpu%2Fsrc%2Ffsl_mpu_driver.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fmpu%2Fcommon%2Ffsl_mpu_common.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fgpio%2Fsrc%2Ffsl_gpio_driver.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fgpio%2Fcommon%2Ffsl_gpio_common.o%20.%2FSDK%2Fplatform%2Fdrivers%2Fgpio%2Ffsl_gpio_irq.o%20%E3%80%82%2Fgenerated_code%2FCPU.O%E3%80%82%2Fgenerated_code%2Ffsl_HWTimer1.o%E3%80%82%2Fgenerated_code%2Ffsl_mpu1.o%E3%80%82%2Fgenerated_code%2Ffsl_UART1.o%E3%80%82%2Fgenerated_code%2FGPIO_PINS.O%E3%80%82%2Fgenerated_code%2FHardware_init.O%E3%80%82%2Fgenerated_code%2Fmqx_KSDK.o%E3%80%82%2Fgenerated_code%2Fpin_init.O%E3%80%82%2Fgenerated_code%2FSDcard1.o%E3%80%82%2Fgenerated_code%2FUARTCOM0.o%E3%80%82%2Fgenerated_code%2Fuartcom3.O%20C%3A%20%2FFreescale%2Fkds_1.1.1%2Feclipse%2Fclipse%2F%2F..%2Ftoolchain%2Flib%2Fgcc%2Farm-none-eabi%2F4.8.0%2Fm4%2Ffp%2Fv4-sp-d16%2Flibgcc.a%20C%3A%20%2FFreescale%2Fkds_1.1.1%2Feclipse%2F%2F...%2Ftoolchain%2Farm-none-eabi%2Flib%2Fm4%2Ffp%2Fv4-sp-d16%2Flibc.aC%3A%20%2F%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%2FKDS_1.1.1%2FEclipse%2F%2F..%2Ftoolchain%2Farm-none-eabi%2Flib%2Fm4%2Ffp%2Fv4-sp-d16%2Flibsupc%2B%2B.aC%3A%20%2F%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%2FKDS_1.1.1%2FEclipse%2F%2F..%2Ftoolchain%2Farm-none-eabi%2Flib%2Fm4%2Ffp%2Fv4-sp-d16%2Flibm.a-lxbee%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%98%BE%E7%84%B6%EF%BC%8C%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E6%AD%A3%E7%A1%AE%E6%96%B9%E6%B3%95%E6%98%AF%E5%88%B6%E4%BD%9C%E4%B8%80%E4%B8%AA%20MQX%20%E5%BA%93%EF%BC%8C%E5%B9%B6%E5%B0%86%E8%AF%A5%E5%BA%93%E9%93%BE%E6%8E%A5%E5%88%B0%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%9C%A8%E4%B8%8D%E7%A0%B4%E5%9D%8F%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%E7%8E%AF%E5%A2%83%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%81%9A%E5%88%B0%E8%BF%99%E4%B8%80%E7%82%B9%E3%80%82%E8%B0%81%E8%83%BD%E5%91%8A%E8%AF%89%E6%88%91%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%B5%81%E7%A8%8B%EF%BC%9F%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-380908%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358301%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358301%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELongPathTool%20%E8%A7%A3%E5%86%B3%E4%BA%86%E7%94%B1%E4%BA%8E%E9%93%BE%E6%8E%A5%E5%99%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E8%BF%87%E9%95%BF%E8%B6%85%E8%BF%87%20Windows%20%E7%89%88%E6%9C%AC%E9%99%90%E5%88%B6%E8%80%8C%E5%AF%BC%E8%87%B4%E7%9A%84%20KSDK%20%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2358296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2358296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ELongPathTool%20%E5%8F%AF%E5%A4%84%E7%90%86%E5%9C%A8%E7%BC%96%E8%AF%91%E8%BF%87%E7%A8%8B%E4%B8%AD%E6%89%A9%E5%B1%95%20SDK%20%E5%BA%93%E8%B6%85%E8%BF%87%E5%91%BD%E4%BB%A4%E8%A1%8C%E9%95%BF%E5%BA%A6%E9%99%90%E5%88%B6%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1504124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1504124%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E5%BB%BA%E8%AE%AE%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%EF%BC%8C%E6%B2%A1%E6%9C%89foreach%20%E5%BE%AA%E7%8E%AF%E4%B9%9F%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E8%BF%99%E5%A4%A7%E5%A4%A7%E5%8A%A0%E5%BF%AB%E4%BA%86%E8%84%9A%E6%9C%AC%E7%9A%84%E8%BF%90%E8%A1%8C%E9%80%9F%E5%BA%A6%E3%80%82%E6%88%91%E8%BF%98%E6%8A%8A%20shell%20%E8%BE%93%E5%87%BA%E9%87%8D%E5%AE%9A%E5%90%91%E5%88%B0%E4%B8%80%E4%B8%AA%E8%99%9A%E6%8B%9F%E5%8F%98%E9%87%8F%EF%BC%8C%E5%90%A6%E5%88%99%20make%20%E4%BC%9A%E6%8A%B1%E6%80%A8%EF%BC%9A%3C%2FP%3E%3CP%3Emakefile.defs%EF%BC%9A%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22courier%20new%2Ccourier%22%3EDUMMY%20%3A%3D%20%24(shell%20echo%20%24(OBJS)%26gt%3B%20ObjectList)%3CBR%20%2F%3EDUMMY%20%3A%3D%20%24(shell%20echo%20%24(USER_OBJS)%26gt%3B%26gt%3B%20ObjectList)%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380934%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%9C%A8%E4%BD%BF%E7%94%A8%20Code%20Warrior%2010.1%20%E4%B8%BA%20HCS08%20%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E7%BC%96%E5%86%99%E8%BD%AF%E4%BB%B6%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E7%BC%96%E5%86%99%E4%B8%80%E4%B8%AA%20Python%20%E5%B0%8F%E8%84%9A%E6%9C%AC%EF%BC%8C%E5%B0%86%E6%89%80%E6%9C%89%E5%B7%B2%E7%BC%96%E8%AF%91%E7%9A%84%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%E5%86%99%E5%85%A5%E5%8F%A6%E4%B8%80%E4%B8%AA%E6%96%87%E4%BB%B6%EF%BC%8C%E7%84%B6%E5%90%8E%E7%94%B1%E9%93%BE%E6%8E%A5%E5%99%A8%E8%AF%BB%E5%8F%96%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%3CSTRONG%3E%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%E4%BB%A5%E4%B8%8B%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E5%9C%A8%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E6%9C%89%E4%BA%9B%E5%86%85%E5%AE%B9%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%B8%8E%E5%85%B6%E4%BB%96%E9%A1%B9%E7%9B%AE%E3%80%81%E7%9B%AE%E6%A0%87%E3%80%81%E7%BC%96%E8%AF%91%E5%99%A8%E7%AD%89%E9%85%8D%E5%90%88%E4%BD%BF%E7%94%A8%E3%80%82%3CBR%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%3C%2FSTRONG%3E%3C%2FSPAN%3E%E6%82%A8%E9%9C%80%E8%A6%81%E5%AE%89%E8%A3%85%20Python%20for%20Windows%20%E6%89%8D%E8%83%BD%E8%BF%90%E8%A1%8C%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%82%A8%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E5%9C%A8%E7%B3%BB%E7%BB%9F%E7%9A%84%20PATH%20%E5%8F%98%E9%87%8F%E4%B8%AD%E5%8A%A0%E5%85%A5%20python%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId-1680607215%22%20id%3D%22toc-hId-1680607215%22%20id%3D%22toc-hId--466815791%22%3EPython%20%E8%84%9A%E6%9C%AC%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22python%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_1455019790209529%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%22175.5_8_1216_464%22%20jivemacro_uid%3D%22_1455019790209529%22%3E%3CP%3E%E5%AF%BC%E5%85%A5%E7%B3%BB%E7%BB%9F%3C%2FP%3E%3CP%3E%E5%AF%BC%E5%85%A5%20os%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Edef%20main(argv%20%3D%20None)%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%E5%A6%82%E6%9E%9C%20(not%20len(argv)%20%3D%3D%203)%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20myname%20%3D%20os.path.basename(argv%5B0%5D)%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20sys.exit(%22usage%EF%BC%9A%7B%7D%3COBJECT%20file%3D%22%22%20name%3D%22%22%3E%3CLINKER%20args%3D%22%22%20file%3D%22%22%3E%20%22%20.format(myname))%3C%2FLINKER%3E%3C%2FOBJECT%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%20%20%20%20obj_arg%20%3D%22-Add(%7B%7D)%22.format(argv%5B1%5D)%3C%2FP%3E%3CP%3E%20%20%20%20args_file_name%20%3D%20argv%5B2%5D%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%20%20%20%20%E8%AF%95%E8%AF%95%E7%9C%8B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%E5%A6%82%E6%9E%9C%20os.path.isfile(args_file_name)%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20with%20open(args_file_name%2C%20'r')%20as%20args_file%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20args%20%3D%20args_file.read()%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20if%20not%20obj_arg%20in%20args%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20with%20open(args_file_name%2C%20'a')%20as%20args_file%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20args_file.write(obj_arg)%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20elif%20not%20os.path.exists(args_file_name)%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20with%20open(args_file_name%2C%20'w%2B')%20as%20args_file%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20args_file.write(obj_arg)%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%E5%90%A6%E5%88%99%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20sys.exit(%22%E8%B7%AF%E5%BE%84'%7B%7D'%E5%AD%98%E5%9C%A8%EF%BC%8C%E4%BD%86%E4%B8%8D%E6%98%AF%E6%96%87%E4%BB%B6%E3%80%82%22.format(args_file_name))%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%20%20%20%20except%20OSError%20as%20err%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20sys.exit(%22%E9%94%99%E8%AF%AF%EF%BC%9A%22%20%2B%20err.strerror())%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Eif__name__%20%3D%3D%22__main__%20%22%20%EF%BC%9A%3C%2FP%3E%3CP%3E%20%20%20%20main(sys.argv)%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3C%2FP%3E%3CH2%20id%3D%22toc-hId--871549746%22%20id%3D%22toc-hId--871549746%22%20id%3D%22toc-hId-2020697042%22%3E%E5%AF%B9%E7%89%88%E6%9C%AC%E7%B3%BB%E7%BB%9F%E7%9A%84%E6%9B%B4%E6%94%B9%3C%2FH2%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%8F%B3%E4%BE%A7%20%22%20C%2FC%2B%2B%20%E7%89%88%E6%9C%AC%20%22%2F%22%20%E8%AE%BE%E7%BD%AE%20%22%20%E4%B8%8B%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B1%9E%E6%80%A7%E4%B8%AD%EF%BC%8C%E6%88%91%E5%AF%B9%E9%93%BE%E6%8E%A5%E5%99%A8%E3%80%81%E7%BC%96%E8%AF%91%E5%99%A8%E5%92%8C%E6%B1%87%E7%BC%96%E5%99%A8%E7%9A%84%E8%B0%83%E7%94%A8%E8%BF%9B%E8%A1%8C%E4%BA%86%E5%A6%82%E4%B8%8B%E6%9B%B4%E6%94%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%22%E4%B8%8B%20%E9%93%BE%E6%8E%A5%E5%99%A8%22%20--%26gt%3B%20%22%20%E5%91%BD%E4%BB%A4%E8%A1%8C%E6%A8%A1%E5%BC%8F%22%20%EF%BC%88%E5%8F%B3%E4%BE%A7%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14550200562276173%20jive_text_macro%22%20data-renderedposition%3D%22774.5_8_1216_16%22%20jivemacro_uid%3D%22_14550200562276173%22%20modifiedtitle%3D%22true%22%3E%3CP%3Epython%20..%2Fscripts%2Fappend_object.py%22%22%20%22%20%24(MCUToolsBaseDirEnv)%5Clib%5Chc08c%5Clib%5Cansis.lib%22%22%22objlist.args%26amp%3B%20%24%7BCOMMAND%7D%20-ArgFile%22objlist.args%22%24%7BFLAGS%7D%20%24%7BOUTPUT_FLAG%7D%24%7BOUTPUT_PREFIX%7D%24%7BOUTPUT%7D%3C%2FP%3E%3C%2FPRE%3E%3CP%3E--%26gt%3B%20%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%E6%88%91%E9%9C%80%E8%A6%81%E5%B0%86%20ansis.lib%20%E9%93%BE%E6%8E%A5%E5%88%B0%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E6%8A%8A%E5%AE%83%E6%94%BE%E5%9C%A8%E4%BA%86%E8%BF%99%E9%87%8C%E3%80%82%E5%AF%B9%E4%BA%8E%E5%85%B6%E4%BB%96%E5%BA%94%E7%94%A8%EF%BC%8C%E6%83%85%E5%86%B5%E5%8F%AF%E8%83%BD%E6%9C%89%E6%89%80%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E--%26gt%3B%20%E6%96%87%E4%BB%B6%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eobjlist.args%3C%2FSPAN%3E%E5%8C%85%E5%90%AB%E4%BD%9C%E4%B8%BA%E9%93%BE%E6%8E%A5%E5%99%A8%E5%8F%82%E6%95%B0%E7%9A%84%E6%89%80%E6%9C%89%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9C%A8%22HCS08%20%E7%BC%96%E8%AF%91%E5%99%A8%E4%B8%8B%22%20--%26gt%3B%20%22%20%E5%91%BD%E4%BB%A4%E8%A1%8C%E6%A8%A1%E5%BC%8F%22%20%EF%BC%88%E5%8F%B3%E4%BE%A7%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14550203273542625%20jive_text_macro%22%20data-renderedposition%3D%22878.5_8_1216_16%22%20jivemacro_uid%3D%22_14550203273542625%22%20modifiedtitle%3D%22true%22%3E%3CP%3E%24%7BOUTPUT_FLAG%7Dpython%20..%2Fscripts%2Fappend_object.py%22%22%20%22%20%24%7BOUTPUT%7D%20%22%20%22%20%22%20objlist.args%26amp%3B%20%24%7BCOMMAND%7D%20%24%7BFLAGS%7D%20%24%7BOUTPUT_PREFIX%7D%20%24%7BOUTPUT%7D%20%24%7BINPUTS%7D%3C%2FP%3E%3C%2FPRE%3E%3CP%3E--%26gt%3B%20%E5%B0%86%E4%BB%8E%20C%20%E6%96%87%E4%BB%B6%E7%BC%96%E8%AF%91%E7%9A%84%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%E5%90%8D%E5%86%99%E5%85%A5%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eobjlist.args%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%22HCS08%20%E6%B1%87%E7%BC%96%E7%A8%8B%E5%BA%8F%E4%B8%8B%22%20--%26gt%3B%20%22%20%E5%91%BD%E4%BB%A4%E8%A1%8C%E6%A8%A1%E5%BC%8F%22%20%EF%BC%88%E5%8F%B3%E4%BE%A7%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CPRE%20__default_attr%3D%22plain%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14550204149448873%22%20data-renderedposition%3D%22960.5_8_1216_16%22%20jivemacro_uid%3D%22_14550204149448873%22%20modifiedtitle%3D%22true%22%3E%3CP%3Epython%20..%2Fscripts%2Fappend_object.py%22%22%20%22%20%24%7BOUTPUT%7D%20%22%20%22%20%22%20objlist.args%26amp%3B%20%24%7BCOMMAND%7D%20%24%7BFLAGS%7D%20-Objn%24%7BOUTPUT_PREFIX%7D%24%7BOUTPUT%7D%20%24%7BINPUTS%7D%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E--%26gt%3B%20%E5%B0%86%E6%B1%87%E7%BC%96%E6%96%87%E4%BB%B6%E7%BC%96%E8%AF%91%E7%9A%84%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%E5%90%8D%E5%86%99%E5%85%A5%3CSPAN%20style%3D%22font-family%3A%20courier%20new%2Ccourier%3B%22%3Eobjlist.args%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-family%3A%20arial%2Chelvetica%2Csans-serif%3B%22%3E%3CSPAN%20style%3D%22color%3A%20%23e23d39%3B%22%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%EF%BC%9A%3C%2FSTRONG%3E%3C%2FSPAN%3E%E6%88%91%E9%81%87%E5%88%B0%E7%9A%84%E5%94%AF%E4%B8%80%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E6%9C%89%E6%97%B6%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%E6%B8%85%E7%90%86%E4%BD%86%E5%88%A0%E9%99%A4%E4%BA%86%E6%BA%90%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%88%97%E5%87%BA%E6%97%A7%E7%9A%84%E7%9B%AE%E6%A0%87%E6%96%87%E4%BB%B6%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E8%A6%81%E4%B9%88%E6%89%A7%E8%A1%8C%20%22%20clean%20%22%20%E8%A6%81%E4%B9%88%E5%88%A0%E9%99%A4%E6%9E%84%E5%BB%BA%E7%9B%AE%E5%BD%95%E6%9D%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380933%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%20%E5%9C%A8%E4%B8%80%E4%B8%AA%E5%95%86%E4%B8%9A%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%E4%BA%86%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E4%B8%8D%E5%BE%97%E4%B8%8D%E6%80%80%E7%96%91%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E4%B8%BA%E4%BB%80%E4%B9%88%E6%B2%A1%E6%9C%89%E5%8F%91%E7%8E%B0%E8%BF%99%E6%A0%B7%E4%B8%80%E4%B8%AA%E6%A0%B9%E6%9C%AC%E6%80%A7%E7%9A%84%E9%99%90%E5%88%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380932%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E6%88%91%E6%83%B3%E4%BD%A0%E4%B9%9F%E5%8F%AF%E4%BB%A5%E8%BF%99%E6%A0%B7%E5%81%9A%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380931%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%20KDS%20%E7%9A%84%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B9%9F%E8%83%BD%E5%8A%A0%E5%85%A5%E8%BF%99%E4%B8%AA%E5%8A%9F%E8%83%BD...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E6%B6%88%E6%81%AF%EF%BC%9A%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E8%A7%A3%E5%86%B3%20Windows%20%E5%91%BD%E4%BB%A4%E8%A1%8C%EF%BC%88%E9%93%BE%E6%8E%A5%E5%99%A8%EF%BC%89%E9%95%BF%E5%BA%A6%E9%97%AE%E9%A2%98%E7%9A%84%E5%8A%9E%E6%B3%95%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2015%2F03%2F29%2Fsolving-the-8192-character-command-line-limit-on-windows%2F%22%20title%3D%22http%3A%2F%2Fmcuoneclipse.com%2F2015%2F03%2F29%2Fsolving-the-8192-character-command-line-limit-on-windows%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fmcuoneclipse.com%2F2015%2F03%2F29%2Fsolving-the-8192-character-command-line-limit-on-windows%2F%3C%2FA%3E%3C%2FP%3E%3CP%3E%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E8%BF%9B%E8%A1%8C%E5%B9%BF%E6%B3%9B%E7%9A%84%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%BD%86%E6%88%91%E6%89%80%E6%9C%89%E4%BB%A5%E5%89%8D%E5%A4%B1%E8%B4%A5%E7%9A%84%E9%A1%B9%E7%9B%AE%E7%8E%B0%E5%9C%A8%E9%83%BD%E8%83%BD%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E4%BA%86%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%9F%83%E9%87%8C%E5%B8%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%A6%96%E5%85%88%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%81%E4%BD%86%E6%88%91%E6%83%B3%E8%A1%A5%E5%85%85%E4%B8%89%E7%82%B9%EF%BC%8C%E4%BB%A5%E6%B1%82%E6%94%B9%E8%BF%9B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E1.%E6%88%91%E7%9A%84%E7%8E%AF%E5%A2%83%E6%98%AF%20Windows%207%E3%80%81KDS%202.0.0%20%E5%92%8C%20KSDK%201.1.0%E3%80%82%E5%BD%93%E6%88%91%E8%BF%90%E8%A1%8C%E8%84%9A%E6%9C%AC%E6%97%B6%EF%BC%8C%E6%80%BB%E6%98%AF%E5%A4%9A%E5%87%BA%E4%B8%80%E8%A1%8C%22ECHO%20is%20off.%22%20%EF%BC%8C%E5%AF%BC%E8%87%B4%E8%BF%9E%E6%8E%A5%E7%A8%8B%E5%BA%8F%E6%97%A0%E6%B3%95%E5%AE%8C%E6%88%90%E3%80%82%E5%9C%A8%20echo%20%E5%91%BD%E4%BB%A4%E4%B8%AD%E6%B7%BB%E5%8A%A0%E5%8F%A5%E5%8F%B7%20(.)%20%E5%B0%B1%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E2.%E5%9C%A8%E8%8E%B7%E5%BE%97%E5%B9%B2%E5%87%80%E7%9A%84%20ObjectList%20%E6%96%87%E4%BB%B6%E5%90%8E%EF%BC%8C%E9%93%BE%E6%8E%A5%E5%99%A8%E4%B8%8D%E4%BC%9A%E5%8C%85%E5%90%AB%E6%AD%A3%E5%B8%B8%E7%9A%84%E5%BA%93%E3%80%82%E4%B9%9F%E8%AE%B8%E6%9C%89%E6%9B%B4%E5%A5%BD%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%8C%E4%BD%86%E6%88%91%E6%9C%80%E7%BB%88%E8%BF%98%E6%98%AF%E5%9C%A8%20ObjectList%20%E6%96%87%E4%BB%B6%E6%9C%AB%E5%B0%BE%E6%B7%BB%E5%8A%A0%E4%BA%86%E7%A1%AC%E7%BC%96%E7%A0%81%E9%93%BE%E6%8E%A5%E3%80%82%E7%8E%B0%E5%9C%A8%E6%88%91%E7%9A%84%20makefile.defs%20%E6%96%87%E4%BB%B6%E5%A6%82%E9%99%84%E4%BB%B6%E6%89%80%E7%A4%BA%E3%80%82%E8%BF%99%E4%B8%AA%E6%96%B9%E6%B3%95%E7%9B%AE%E5%89%8D%E5%8F%AF%E8%A1%8C%EF%BC%8C%E4%BD%86%E9%9A%8F%E7%9D%80%E9%A1%B9%E7%9B%AE%E7%9A%84%E6%89%A9%E5%A4%A7%EF%BC%8C%E5%8F%AF%E8%83%BD%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E3.%E6%88%91%E5%AF%B9%20KDS%E3%80%81KSDK%E3%80%81PE%20%E5%92%8C%20MQX%20%E7%9A%84%E7%BB%84%E5%90%88%E7%89%B9%E5%88%AB%E6%84%9F%E5%85%B4%E8%B6%A3%E3%80%82%E4%B8%8D%E9%9C%80%E8%A6%81%E4%B8%80%E4%B8%AA%E9%9D%9E%E5%B8%B8%E5%A4%8D%E6%9D%82%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%B0%B1%E4%BC%9A%E9%81%87%E5%88%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E9%BC%93%E5%8A%B1%22%E5%9B%A2%E9%98%9F%22%20%E8%80%83%E8%99%91%E6%9B%B4%E5%A5%BD%E5%9C%B0%EF%BC%88%E6%B0%B8%E4%B9%85%E6%80%A7%E5%9C%B0%EF%BC%89%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E5%A6%82%E6%9E%9C%E4%BB%8E%E6%80%BB%E4%BD%93%E4%B8%8A%E5%8F%AF%E4%BB%A5%E6%8E%A5%E5%8F%97%EF%BC%8C%E6%B7%BB%E5%8A%A0%E8%BF%99%E4%B8%AA%E6%96%87%E4%BB%B6%E4%B9%9F%E6%98%AF%E5%8F%AF%E8%A1%8C%E7%9A%84%EF%BC%8C%E4%BD%86%E5%BF%85%E9%A1%BB%E6%9C%89%E5%A4%84%E7%90%86%E5%BA%93%E7%9A%84%E6%96%B9%E6%B3%95%E3%80%82%E5%89%8D%E9%9D%A2%E6%8F%90%E5%88%B0%E7%9A%84%E5%8F%A6%E4%B8%80%E7%A7%8D%E6%96%B9%E6%B3%95%E4%B9%9F%E8%A1%8C%E5%BE%97%E9%80%9A%E3%80%82%E8%BF%99%E5%B0%86%E6%98%AF%E5%9C%A8%E4%B8%8E%E7%94%A8%E6%88%B7%E4%BB%A3%E7%A0%81%E8%BF%9B%E8%A1%8C%E6%9C%80%E7%BB%88%E9%93%BE%E6%8E%A5%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%B0%86%20PE%20%E6%8F%90%E4%BE%9B%E7%9A%84%E6%96%87%E4%BB%B6%E7%BC%96%E8%AF%91%E5%B9%B6%E9%93%BE%E6%8E%A5%E5%88%B0%E5%AE%83%E8%87%AA%E5%B7%B1%E7%9A%84%E5%BA%93%E4%B8%AD%E3%80%82%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%EF%BC%8C%E6%88%91%E5%AF%B9%20Eclipse%20%E7%9A%84%E5%B7%A5%E4%BD%9C%E6%96%B9%E5%BC%8F%E5%A4%AA%E9%99%8C%E7%94%9F%E4%BA%86%EF%BC%8C%E6%97%A0%E6%B3%95%E8%87%AA%E5%B7%B1%E8%BF%9B%E8%A1%8C%E8%B0%83%E6%9F%A5%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E5%8F%88%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%E5%85%A8%E5%A5%97%E5%B7%A5%E5%85%B7%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E6%AC%A1%E6%84%9F%E8%B0%A2%E4%BD%A0%E5%B8%AE%E6%88%91%E6%B8%A1%E8%BF%87%E9%9A%BE%E5%85%B3%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380928%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E9%87%8C%E6%9C%89%E4%B8%80%E4%B8%AA%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E7%9A%84%E5%A5%BD%E5%8A%9E%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E5%9C%A8%E9%A1%B9%E7%9B%AE%E6%A0%B9%E7%9B%AE%E5%BD%95%E4%B8%8B%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%20makefile.defs%20%E7%9A%84%E6%96%87%E6%9C%AC%E6%96%87%E4%BB%B6%E3%80%82%E8%AF%A5%E6%96%87%E4%BB%B6%E5%9C%A8%E8%87%AA%E5%8A%A8%E7%94%9F%E6%88%90%E7%9A%84%20makefile%20%E7%9A%84%20include%20%E8%AF%AD%E5%8F%A5%E4%B8%AD%E5%BC%95%E7%94%A8%EF%BC%8C%E4%BE%9B%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E5%BD%B1%E5%93%8D%E8%87%AA%E5%8A%A8%E7%94%9F%E6%88%90%E7%9A%84%20make%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3Eifneq%20(%24(strip%20%24(S_UPPER_DEPS))%2C)%3C%2FP%3E%3CP%3E-%E5%8C%85%E6%8B%AC%20%24(S_UPPER_DEPS)%3C%2FP%3E%3CP%3Eendif%3C%2FP%3E%3CP%3Eendif%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-include%20..%2Fmakefile.defs%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%20%E5%B0%86%E8%BF%99%E4%BA%9B%E5%B7%A5%E5%85%B7%E8%B0%83%E7%94%A8%E7%9A%84%E8%BE%93%E5%85%A5%E5%92%8C%E8%BE%93%E5%87%BA%E6%B7%BB%E5%8A%A0%E5%88%B0%E7%89%88%E6%9C%AC%E5%8F%98%E9%87%8F%E4%B8%AD%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%20%E6%89%80%E6%9C%89%E7%9B%AE%E6%A0%87%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E6%AD%A4%E6%96%87%E4%BB%B6%20makefile.defs%E3%80%81%E5%B0%86%E6%89%80%E6%9C%89%E5%B7%B2%E7%BC%96%E8%AF%91%E7%9A%84%E5%AF%B9%E8%B1%A1%E6%96%87%E4%BB%B6%E5%92%8C%E5%BA%93%E5%A4%8D%E5%88%B6%E5%88%B0%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%20ObjectList%20%E7%9A%84%E6%96%87%E4%BB%B6%E4%B8%AD%E3%80%82%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%20makefile%20%E8%84%9A%E6%9C%AC%E6%98%AF%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%24(shell%20rm%20ObjectList)%3C%2FP%3E%3CP%3E%24(foreach%20obj%2C%20%24(OBJS)%2C%20%24(shell%20echo%20%24(obj)%26gt%3B%26gt%3B%20ObjectList))%3C%2FP%3E%3CP%3E%24(shell%20echo%20%24(USER_OBJS)%26gt%3B%26gt%3B%20ObjectList)%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%AF%E8%83%BD%E6%9C%89%E6%AF%94%E8%BF%99%E6%9B%B4%E6%9C%89%E6%95%88%E7%9A%84%E8%84%9A%E6%9C%AC%EF%BC%8C%E4%BD%86%E6%88%91%E4%B8%8D%E6%98%AF%E8%84%9A%E6%9C%AC%E4%B8%93%E5%AE%B6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%80%E5%90%8E%EF%BC%8C%E7%BC%96%E8%BE%91%E9%A1%B9%E7%9B%AE%E9%93%BE%E6%8E%A5%E5%99%A8%E8%AE%BE%E7%BD%AE%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%88%A0%E9%99%A4%E5%AF%B9%20%24%EF%BC%88INPUTS%EF%BC%89%E7%9A%84%E5%BC%95%E7%94%A8%EF%BC%8C%E5%B9%B6%E5%B0%86%E5%85%B6%E6%9B%BF%E6%8D%A2%E4%B8%BA%20%40ObjectList%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F48657i750D39D8EDC8F34A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380927%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%89%BE%E5%88%B0%E4%BA%86%E3%80%82%E6%88%91%E5%BF%98%E4%BA%86%E5%9C%A8%20C%2B%2B%20%E9%A2%84%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%AD%E6%B7%BB%E5%8A%A0%20CPU%20%E7%B1%BB%E5%9E%8B...%20(%22CPU_MK64FN1M0VMD12%22).%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%AF%95%E8%BF%87%E4%BA%86%3C%2FP%3E%3CP%3E%E6%96%B0%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%9C%A8%E9%93%BE%E6%8E%A5%E5%99%A8%E8%B7%AF%E5%BE%84%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%20ksdk_platform_lib.a%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%8B%E5%8A%A8%E6%B7%BB%E5%8A%A0%E4%BA%86%E6%89%80%E6%9C%89%20KSDK%2Fplatform%20%E6%96%87%E4%BB%B6%EF%BC%88%E4%BB%85%20.h%20%E6%96%87%E4%BB%B6%E5%B0%86%E6%89%80%E6%9C%89%E6%96%87%E4%BB%B6%E6%94%BE%E5%9C%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E6%96%87%E4%BB%B6%E5%A4%B9%E4%B8%AD%EF%BC%88Hal%20%E5%92%8C%20Driver%EF%BC%89%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%8C%85%E5%90%AB%E7%9A%84%E6%96%87%E4%BB%B6%E5%B0%B1%E5%B0%91%E4%BA%86%E3%80%82%E5%9C%A8%20C%20%E5%92%8C%20C%2B%2B%20%E7%BC%96%E8%AF%91%E5%99%A8%E8%AE%BE%E7%BD%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E6%B7%BB%E5%8A%A0%E4%BA%86%E6%89%80%E6%9C%89%E5%BF%85%E8%A6%81%E7%9A%84%E8%B7%AF%E5%BE%84%EF%BC%8C%E4%BD%86%E5%BD%93%E6%88%91%E7%BC%96%E8%AF%91%20cpp%20%E6%96%87%E4%BB%B6%E6%97%B6%EF%BC%8C%E5%8D%B4%E5%87%BA%E7%8E%B0%E4%BA%86%E8%BF%99%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIn%20file%20included%20from%20C%3A%5CUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSources%5CIncludes%5CHal%2Ffsl_pit_hal.h%3A33%3A0%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20from%20C%3A%5CUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSources%5CInit%2FCpu.h%3A82%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20from%20C%3A%5CUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSourcesInit%2FUART3.h%3A69%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E6%9D%A5%E8%87%AA%20..%2FSources%2FSBUS.h%3A24%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E4%BB%8E%20..%2FSources%2FFutaba_sbus%2FFUTABA_SBUS.h%EF%BC%9A4%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%E6%9D%A5%E8%87%AA%20..%2FSources%2FFutaba_sbus%2FFUTABA_SBUS.cpp%3A1%EF%BC%9A%3C%2FP%3E%3CP%3EC%3A%5CUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSources%5CIncludes%5CHal%2Ffsl_pit_hal.h%EF%BC%9A%E5%9C%A8%E5%87%BD%E6%95%B0%20%22bool%20PIT_HAL_GetIntCmd(uint32_t%EF%BC%8Cuint32_t)%20%22%E4%B8%AD%EF%BC%9A%3C%2FP%3E%3CP%3EC%3AUsers%5Cjack%5CDropbox%5CMBD%5CProgetti%5CTwingTec%5CFirmware%5Cworkspace%5Cfirmware%5CSources%5CIncludes%5CHal%2Ffsl_pit_hal.h%3A287%3A22%3A%20error%3A%20'FSL_FEATURE_PIT_TIMER_COUNT'%20was%20not%20declared%20in%20this%20scope%3C%2FP%3E%3CP%3E%20%20%20%20%20assert(channel%26lt%3B%20FSL_FEATURE_PIT_TIMER_COUNT)%EF%BC%9B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%89%BE%E4%B8%8D%E5%88%B0%20fsl_pit_features.h%20%E4%B8%AD%E7%9A%84%20FSL_FEATURE_PIT_TIMER_COUNT%20%23define%E4%B8%8E%20fsl_pit_hal.h%20%E4%BD%8D%E4%BA%8E%E5%90%8C%E4%B8%80%E7%9B%AE%E5%BD%95%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E6%83%B3%E6%B3%95%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380925%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E7%8E%B0%E5%9C%A8%E5%8F%AF%E4%BB%A5%E8%BF%90%E8%A1%8C%E4%BD%86%E6%98%AF%E7%8E%B0%E5%9C%A8%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E9%94%99%E8%AF%AF%EF%BC%9A%E4%B8%8D%E5%BB%BA%E8%AE%AE%E5%9C%A8%E4%B8%8D%E6%8C%87%E5%AE%9A%E4%BD%8D%E6%8E%A9%E7%A0%81%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%86%99%E5%85%A5%20APSR%EF%BC%8C%E4%BD%86%E6%96%87%E4%BB%B6%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E5%AE%9E%E9%99%85%E4%B8%8A%E6%88%91%E6%9C%89%EF%BC%88%E5%B0%B1%E5%83%8F%E8%BF%99%E9%87%8C%E6%89%80%E8%AF%B4%E7%9A%84%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fthread%2F325709%22%20target%3D%22_blank%22%3EMqxLite%20for%20M0%2B%20(%3C%2FA%3EMKL25Z128VLK4)%20%E6%97%A0%E6%B3%95%E6%9E%84%E5%BB%BA%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%23ifdef__GNUC__%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20msr%20APSR_nzcvq%EF%BC%8Cr1%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%23else%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20msr%20APSR%EF%BC%8Cr1%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%20%20%23endif%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380924%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E4%B8%8D%E4%BC%9A%E6%9C%89%E5%A4%AA%E5%A4%A7%E5%B8%AE%E5%8A%A9%EF%BC%8C%E5%8F%AA%E4%BC%9A%E6%8E%A8%E8%BF%9F%E9%94%99%E8%AF%AF%E7%9A%84%E5%8F%91%E7%94%9F%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%80%E4%B8%AA%E5%8A%9E%E6%B3%95%E6%98%AF%E4%BD%BF%E7%94%A8%E6%BC%94%E7%A4%BA%E7%A8%8B%E5%BA%8F%E6%89%80%E4%BD%BF%E7%94%A8%E7%9A%84%E5%BA%93%EF%BC%8C%E4%BD%86%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E5%91%A2%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E9%97%AE%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%9C%89%E6%B2%A1%E6%9C%89%3CSTRONG%3E%E4%B8%8D%E9%9C%80%E8%A6%81%20%3C%2FSTRONG%3E%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%93%E5%AE%B6%E4%B9%9F%E8%83%BD%E4%BD%BF%E7%94%A8%20KSDK%20%E7%9A%84%E6%95%99%E7%A8%8B%3CSTRONG%3E%EF%BC%9F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3CP%3EGiacomo%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ECodeWarrior%20%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E4%B8%8D%E5%90%8C%E7%9A%84%20gcc%20%E5%92%8C%E4%B8%8D%E5%90%8C%E7%9A%84%E7%BC%96%E8%AF%91%E7%B3%BB%E7%BB%9F%EF%BC%8C%E6%97%A0%E6%B3%95%E4%B8%8E%20KDS%20%E7%9B%B8%E6%8F%90%E5%B9%B6%E8%AE%BA%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%AF%95%E8%AF%95%E4%B8%8A%E9%9D%A2%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E7%BC%A9%E7%9F%AD%20%22Generated_Code%20%22%E7%9A%84%E8%B7%AF%E5%BE%84%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E8%8A%82%E7%9C%81%E5%BE%88%E5%A4%9A%E5%AD%97%E7%AC%A6%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9F%83%E9%87%8C%E5%B8%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%97%A8%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8A%8A%E9%A1%B9%E7%9B%AE%E7%A7%BB%E5%88%B0%E4%BA%86%20c%3A%5Cworkspce%20%E4%B8%AD%EF%BC%8C%E4%BD%86%E8%BF%98%E6%98%AF%E5%87%BA%E7%8E%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9E%84%E5%BB%BA%E7%9B%AE%E6%A0%87%EF%BC%9ATest.elf%3C%2FP%3E%3CP%3E'%E8%B0%83%E7%94%A8%EF%BC%9A%E8%B7%A8ARM%20C%2B%2B%E9%93%BE%E6%8E%A5%E5%99%A8'%3C%2FP%3E%3CP%3Earm-none-eabi-g%2B%2B-mcpu%3Dcortex-m0plus-mthumb-O0-fmessage-length%3D0-fsigned-char-ffunction-sections-function-faction-g%2B%2B-mcpu%3Dcortex-m0plus-mthumb-O0-fmessage-length%3D0-fsigned-char-ffunction-sections-functions-g%2B%2B%20%22%20%22-Xlinker%20-gc-sections%20-L%22C%3A%2FWorkspace%2FTest%2FTest%2FProject_Settings%2FLinker_Files%22%20-Wl%2C-Map%2C%22Test.map%22%20-nanolibc%20-o%22Test.elf%22%20.%2FSources%2FEvents.o.%2FSources%2Fmain.o.%2FSources%2Fmqx_tasks.o%20.%2FSources%2Fsa_mtb.o%20.%2FSensors%2FGas_Sensor.o%20.%2FSensors%2FHTU21D.o%20.%2FSensors%2FMaster_Sensor.o%20.%2FSdCard%2FSD1.o.%2FSdCard%2FSD_kinetis.o%20.%2FSdCard%2FSPI_kinetis.o%20.%2FRTC%2FPCF_85063.o%20.%2FPower_Supply%2FPowerSupply.o%20.%2FPage%2FBluetooth.o.%2FPage%2FClockTempBar.o%20.%2FPage%2FDataPage.o%20.%2FPage%2FGasMeasurePage.o%20.%2FPage%2FHomePage.o%20.%2FPage%2FInformationPage.o%20.%2FPage%2FIntervalPage.o%20.%2FPage%2FLanguagePage.o%20.%2FPage%2FOraPage.o%E3%80%82%2Fpage%2FsettingPage.o%E3%80%82%2Fpage%2Fstartpage.o%E3%80%82%2Fpage%2FstoricoPage.o%E3%80%82%2FmqxLite%2Fpsp%2FCortex_m%2FCore%2Fm0%2Fboot.O.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fcore%2FM0%2Fdispatch.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fcortex.o.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_gkis.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_inst.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_kisr.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_pvta.o%20%E3%80%82.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_unx.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_vtab.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fint_xcpt.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fmem_zero.o%20..%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_iinit.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_supp.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_tiad.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_tinm..%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_tipr.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fpsp_tisu.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fsc_irdyq.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fstack_bu..%2FMQXLITE%2Fpsp%2Fcortex_m%2Fstack_de.o%20.%2FMQXLITE%2Fpsp%2Fcortex_m%2Fstack_st.o%20.%2FMQXLITE%2Fkernel%2Fidletask.o%20.%2FMQXLITE%2Fkernel%2Fint.o%20.%2FMQXLITE%2Fkernel%2Fklog..%2FMQXLITE%2Fkernel%2Flwlog.o%20.%2FMQXLITE%2Fkernel%2Flwmem.o%20.%2FMQXLITE%2Fkernel%2Flwmsgq.o%20.%2FMQXLITE%2Fkernel%2Flwsem..%2FMQXLITE%2Fkernel%2Flwtimer.o%20.%2FMQXLITE%2Fkernel%2Fmqx_utils.o%20.%2FMQXLITE%2Fkernel%2Fmqxlite.o%20.%2FMQXLITE%2Fkernel%2Fmutex.o%20.%2FMQXLITE%2Fkernel%2Fqu_test..%2FMQXLITE%2Fkernel%2Fsched.o%20.%2FMQXLITE%2Fkernel%2Ftask.o%20.%2FMQXLITE%2Fkernel%2Ftime_ticks.o%20.%2FMQXLITE%2Fconfig%2Ftask_template_list.o%20.%2FInitialization%2FInit.o%20.%2FI2C%2FI2C.o.%2FI2C%2FIntI2cLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FBT_ACTIVE.o.%2FGenerated_Code%2FGenerated_Code%2FBT_RDYN.o%20.%2FGenerated_Code%2FGenerated_Code%2FBT_REQN.o%20.%2FGenerated_Code%2FGenerated_Code%2FBT_RESET.o%20.%2FGenerated_Code%2FGenerated_Code%2FBUTT_POWER.o%20.%2FGenerated_Code%2FGenerated_Code%2FBattSensGND.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd10.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd11.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd12.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd13.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd14.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd15.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd18.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd19.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd2.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd20.o%20..%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd21.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd22.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd23.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd24..%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd25.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd26.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd27.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd28..%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd29.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd3.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd30.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd4..%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd5.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd6.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd7.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd8.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitIoLdd9.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitsIoLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitsIoLdd2.o%20.%2FGenerated_Code%2FGenerated_Code%2FBitsIoLdd3..%2FGenerated_Code%2FGenerated_Code%2FCap1.o%20.%2FGenerated_Code%2FGenerated_Code%2FCaptureLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FCpu.o%20.%2FGenerated_Code%2FGenerated_Code%2FDB_high_1.o%20..%2FGenerated_Code%2FGenerated_Code%2FDB_high_2.o%20.%2FGenerated_Code%2FGenerated_Code%2FDB_low.o%20.%2FGenerated_Code%2FGenerated_Code%2FIO1_SCK.o%20.%2FGenerated_Code%2FGenerated_Code%2FIO2_MOSI.o%20..%2FGenerated_Code%2FGenerated_Code%2FIO3_MISO.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_BKL.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_CS.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_DATA.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_RD..%2FGenerated_Code%2FGenerated_Code%2FLCD_RST.o%20.%2FGenerated_Code%2FGenerated_Code%2FLCD_WR.o%20.%2FGenerated_Code%2FGenerated_Code%2FLTC_BUCK_ON.o%20.%2FGenerated_Code%2FGenerated_Code%2FLTC_BUCK_STDBY..%2FGenerated_Code%2FGenerated_Code%2FLTC_CHARGE.o%20.%2FGenerated_Code%2FGenerated_Code%2FLTC_ON.o%20.%2FGenerated_Code%2FGenerated_Code%2FLTC_PGOOD.o%20.%2FGenerated_Code%2FGenerated_Code%2FMQX1.o%20..%2FGenerated_Code%2FGenerated_Code%2FPE_LDD.o%20.%2FGenerated_Code%2FGenerated_Code%2FPIT.o%20.%2FGenerated_Code%2FGenerated_Code%2FPwmLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FRTC_INT.o%20.%2FGenerated_Code%2FGenerated_Code%2FRef_EN..%2FGenerated_Code%2FGenerated_Code%2FSDCard_ON.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD1.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD2.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD3.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD4.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD5.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_AD6.o%20.%2FGenerated_Code%2FGenerated_Code%2FSNS_IOA.o%20.%2FGenerated_Code%2FGenerated_Code%2FSystemTimer1.o%20.%2FGenerated_Code%2FGenerated_Code%2FTU1.o%20..%2FGenerated_Code%2FGenerated_Code%2FTU2.o%20.%2FGenerated_Code%2FGenerated_Code%2FTU3.o%20.%2FGenerated_Code%2FGenerated_Code%2FTimeDateLdd1.o%20.%2FGenerated_Code%2FGenerated_Code%2FTmDt1.o%20.%2FGenerated_Code%2FGenerated_Code%2FUSB_ID.o%20.%2FGenerated_Code%2FGenerated_Code%2FUSB_LDD.o%20.%2FGenerated_Code%2FGenerated_Code%2FVectors..%2FGenerated_Code%2FGenerated_Code%2FWAIT.o%20.%2FGenerated_Code%2FGenerated_Code%2FXmin.o%20.%2FGenerated_Code%2FGenerated_Code%2FYmin.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_class.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_dci.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_descriptor.o%20..%2FGenerated_Code%2FGenerated_Code%2Fusb_device.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_driver.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_framework.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_msc.o%20.%2FGenerated_Code%2FGenerated_Code%2Fusb_msc_scsi.o%20.%2FGenerated_Code%2FBT_ACTIVE.o.%2FGenerated_Code%2FBT_RDYN.o%20.%2FGenerated_Code%2FBT_REQN.o%20.%2FGenerated_Code%2FBT_RESET.o%20.%2FGenerated_Code%2FBUTT_POWER.o%20.%2FGenerated_Code%2FBattSensGND.o%20.%2FGenerated_Code%2FBitIoLdd1.o%20.%2FGenerated_Code%2FBitIoLdd10.o%20.%2FGenerated_Code%2FBitIoLdd11.o%20.%2FGenerated_Code%2FBitIoLdd12.o%20.%2FGenerated_Code%2FBitIoLdd13.o%20.%2FGenerated_Code%2FBitIoLdd14.o%20.%2FGenerated_Code%2FBitIoLdd17.o%20.%2FGenerated_Code%2FBitIoLdd18.o%20.%2FGenerated_Code%2FBitIoLdd19.o%20.%2FGenerated_Code%2FBitIoLdd2.o%20.%2FGenerated_Code%2FBitIoLdd20.o%20.%2FGenerated_Code%2FBitIoLdd21.o%20.%2FGenerated_Code%2FBitIoLdd22.o%20.%2FGenerated_Code%2FBitIoLdd23.o%20.%2FGenerated_Code%2FBitIoLdd24.o%20.%2FGenerated_Code%2FBitIoLdd25.o%20.%2FGenerated_Code%2FBitIoLdd26.o%20.%2FGenerated_Code%2FBitIoLdd27.o%20.%2FGenerated_Code%2FBitIoLdd28.o%20.%2FGenerated_Code%2FBitIoLdd29.o%20.%2FGenerated_Code%2FBitIoLdd3.o%20.%2FGenerated_Code%2FBitIoLdd30.o%20.%2FGenerated_Code%2FBitIoLdd4.o%20.%2FGenerated_Code%2FBitIoLdd5.o%20.%2FGenerated_Code%2FBitIoLdd6.o%20%E3%80%82.%2FGenerated_Code%2FBitIoLdd7.o%20.%2FGenerated_Code%2FBitIoLdd8.o%20.%2FGenerated_Code%2FBitIoLdd9.o%20.%2FGenerated_Code%2FBitsIoLdd1.o%20.%2FGenerated_Code%2FBitsIoLdd2.o%20.%2FGenerated_Code%2FBitsIoLdd3.o%20.%2FGenerated_Code%2FCap1..%2FGenerated_Code%2FCaptureLdd1.o%20.%2FGenerated_Code%2FCpu.o%20.%2FGenerated_Code%2FDB_high_1.o%20.%2FGenerated_Code%2FDB_high_2.o%20.%2FGenerated_Code%2FDB_low.o%20.%2FGenerated_Code%2FIO1_SCK.o%20..%2FGenerated_Code%2FIO2_MOSI.o%20.%2FGenerated_Code%2FIO3_MISO.o%20.%2FGenerated_Code%2FLCD_BKL.o%20.%2FGenerated_Code%2FLCD_CS.o%20.%2FGenerated_Code%2FLCD_DATA.o%20.%2FGenerated_Code%2FLCD_RD.o%20.%2FGenerated_Code%2FLCD_RST.o%20..%2FGenerated_Code%2FLCD_WR.o%20.%2FGenerated_Code%2FLTC_BUCK_ON.o%20.%2FGenerated_Code%2FLTC_BUCK_STDBY.o%20.%2FGenerated_Code%2FLTC_CHARGE.o%20.%2FGenerated_Code%2FLTC_ON..%2FGenerated_Code%2FLTC_PGOOD.o%20.%2FGenerated_Code%2FMQX1.o%20.%2FGenerated_Code%2FPE_LDD.o%20.%2FGenerated_Code%2FPIT.o%20.%2FGenerated_Code%2FPwmLdd1..%2FGenerated_Code%2FRTC_INT.o%20.%2FGenerated_Code%2FRef_EN.o%20.%2FGenerated_Code%2FSDCard_ON.o%20.%2FGenerated_Code%2FSNS_AD1.o%20.%2FGenerated_Code%2FSNS_AD2..%2FGenerated_Code%2FSNS_AD3.o%20.%2FGenerated_Code%2FSNS_AD4.o%20.%2FGenerated_Code%2FSNS_AD5.o%20.%2FGenerated_Code%2FSNS_AD6.o%20.%2FGenerated_Code%2FSNS_IOA.o%20.%2FGenerated_Code%2FSystemTimer1.o%20.%2FGenerated_Code%2FTU1.o%20.%2FGenerated_Code%2FTU2.o%20.%2FGenerated_Code%2FTU3.o%20.%2FGenerated_Code%2FTimeDateLdd1.o%20..%2FGenerated_Code%2FTmDt1.o%20.%2FGenerated_Code%2FUSB_ID.o%20.%2FGenerated_Code%2FUSB_LDD.o%20.%2FGenerated_Code%2FVectors.o%20.%2FGenerated_Code%2FWAIT.o%20.%2FGenerated_Code%2FXmin..%2FGenerated_Code%2FXmin.o%20.%2FGenerated_Code%2FYmin.o%20.%2FGenerated_Code%2Fusb_class.o%20.%2FGenerated_Code%2Fusb_dci.o%20.%2FGenerated_Code%2Fusb_descriptor.o%20.%2FGenerated_Code%2Fusb_device..%2FGenerated_Code%2Fusb_driver.o%20.%2FGenerated_Code%2Fusb_framework.o%20.%2FGenerated_Code%2Fusb_msc.o%20.%2FGenerated_Code%2Fusb_msc_scsi.o%20.%2FFatFs%2Fccsbcs.o.%2FFatFs%2Fdisk.o.%2FFatFs%2Fff.o%20.%2FErrors%2FError.o%20.%2FDriver_LCD%2FCalibri14.o%20.%2FDriver_LCD%2FCalibri28.o%20.%2FDriver_LCD%2FDriver_ILI9340.o%20.%2FDriver_LCD%2FTFT_base.o%20.%2FDriver_LCD%2FTFT_font.o%20.%2FDriver_LCD%2FTFT_image.o%20.%2FDriver_LCD%2FTFT_object.o%20.%2FDriver_LCD%2FTouchscreen.o%20.%2FBluetooth%2Faci_queue.o.%2FBluetooth%2Faci_setup.o%20.%2FBluetooth%2Facilib.o%20.%2FBluetooth%2Fdfu.o%20.%2FBluetooth%2Fhal_aci_tl.o%20.%2FBluetooth%2Flib_aci.o%20.%2FBluetooth%2Fmain_ble.o%20.%2FADC%2FADC.o%20%20%3C%2FP%3E%3CP%3E%E8%BF%9B%E7%BA%BF%E5%A4%AA%E9%95%BF%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%BF%EF%BC%9A***%20%5BTest.elf%5D%E9%94%99%E8%AF%AF%20255%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20codewarrior%20%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380921%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E8%BE%BE%E5%B0%BC%E5%9F%83%E8%8E%B1%E3%80%81%3C%2FP%3E%3CP%3EKDS%20v2.0.0%20%E6%B2%A1%E6%9C%89%E4%B8%8D%E5%90%8C%E7%9A%84%E7%BC%96%E8%AF%91%E5%B7%A5%E5%85%B7%E6%88%96%E7%BC%96%E8%AF%91%E5%B7%A5%E5%85%B7%E9%9B%86%E6%88%90%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%AD%A4%20Windows%20%E9%99%90%E5%88%B6%E4%BB%8D%E7%84%B6%E9%80%82%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E8%87%B3%E4%BA%8E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E6%9C%AC%E5%B8%96%E5%89%8D%E9%9D%A2%E6%8F%90%E5%88%B0%E7%9A%84%E5%87%A0%E7%82%B9%EF%BC%88%E7%BC%A9%E7%9F%AD%E5%91%BD%E4%BB%A4%E8%A1%8C%E3%80%81%E4%BD%BF%E7%94%A8%E5%AD%90%E7%A8%8B%E5%BA%8F%E3%80%81%E4%BD%BF%E7%94%A8%E5%BA%93%EF%BC%89%E4%BB%8D%E7%84%B6%E9%80%82%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9F%83%E9%87%8C%E5%B8%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380920%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Ekds%202.0.0%20%E4%B9%9F%E6%9C%89%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E6%9C%89%20%EF%BC%9A%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Earm-none-eabi-g%2B%2B-mcpu%3Dcortex-m0plus-mthumb-O0-fmessage-length%3D0-fsigned-char-ffunction-sections-functions-function-sections-functions-functions-%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%BF%9B%E7%BA%BF%E5%A4%AA%E9%95%BF%E3%80%82(%22%E8%BE%93%E5%85%A5%E8%A1%8C%E5%A4%AA%E9%95%BF%22)%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%BD%BF%EF%BC%9A***%20%5BTest.elf%5D%E9%94%99%E8%AF%AF%20255%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9F%83%E9%87%8C%E5%B8%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E4%B8%BE%E4%BE%8B%E8%AF%B4%E6%98%8E%E5%A6%82%E4%BD%95%E9%80%90%E6%AD%A5%E5%B0%86%20MQX%20%E7%94%A8%E4%BD%9C%E5%BA%93%E5%B9%B6%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%20PE%EF%BC%9F%E6%88%91%E4%BB%AC%E4%BB%8D%E5%9C%A8%E5%8A%AA%E5%8A%9B%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380918%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%88%9A%E7%9C%8B%E4%BA%86%E4%B8%80%E4%B8%8B%E5%91%BD%E4%BB%A4%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%BC%BA%E5%A4%B1%E7%9A%84%E5%AD%97%E7%AC%A6%E6%AD%A3%E5%A5%BD%E4%BD%8D%E4%BA%8E%E5%8F%82%E6%95%B0%E5%AD%97%E7%AC%A6%E4%B8%B2%E7%9A%84%208192%20%E4%BD%8D%E7%BD%AE%EF%BC%88%E6%B2%A1%E6%9C%89%E5%91%BD%E4%BB%A4%20%22%20arm-none-eabi-g%2B%2B%20%22%EF%BC%89%20%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%88%9B%E5%BB%BA%E7%9A%84%E5%8F%82%E6%95%B0%E5%AD%97%E7%AC%A6%E4%B8%B2%E5%A4%A7%E4%BA%8E%208k%20%E5%AD%97%E8%8A%82%EF%BC%8C%E5%88%99%E4%BC%BC%E4%B9%8E%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E8%A7%81%E6%96%AF%E6%99%AE%E6%9E%97%E6%A0%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380917%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%9F%83%E9%87%8C%E5%B8%8C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E4%B8%8D%E5%8F%AF%E8%83%BD%E5%B0%86%20MQX%20%E6%9E%84%E5%BB%BA%E4%B8%BA%E5%BA%93%E5%B9%B6%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%20PE%E3%80%82%E8%BF%99%E6%A0%B7%E5%81%9A%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%98%AF%E5%90%A6%E6%9C%89%E5%8A%9E%E6%B3%95%E8%AE%A9%E5%B7%A5%E5%85%B7%E8%87%AA%E5%8A%A8%E7%94%9F%E6%88%90%E7%94%A8%E4%BA%8E%E5%90%91%E9%93%BE%E6%8E%A5%E5%99%A8%E4%BC%A0%E9%80%92%E6%96%87%E4%BB%B6%E5%88%97%E8%A1%A8%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380916%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%AC%91%E4%B8%80%E7%AC%91%3C%2FP%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E5%BE%88%E9%AB%98%E5%85%B4%E7%9F%A5%E9%81%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E8%A7%81%EF%BC%8C%E8%B4%BE%E7%A7%91%E8%8E%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E4%B8%AA%E6%96%B9%E6%B3%95%E5%9C%A8%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E4%B9%9F%E5%BE%88%E6%9C%89%E6%95%88%E3%80%82%E5%B8%8C%E6%9C%9B%E5%AF%B9%E8%AF%A5%E5%B7%A5%E5%85%B7%E6%9C%89%E6%9B%B4%E5%A4%9A%E4%BA%86%E8%A7%A3%E7%9A%84%E4%BA%BA%E8%83%BD%E6%8F%90%E4%BE%9B%E5%B8%AE%E5%8A%A9%EF%BC%8C%E7%BB%99%E6%88%91%E4%BB%AC%E4%B8%80%E4%B8%AA%E7%9C%9F%E6%AD%A3%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%8E%A5%E5%BE%97%E7%9C%9F%E5%A5%BD%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Re%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%BF%99%E5%8F%AF%E8%83%BD%E5%8F%AA%E8%83%BD%E8%B5%B7%E5%88%B0%E4%B8%80%E7%82%B9%E4%BD%9C%E7%94%A8%EF%BC%8C%E4%BD%86%E8%BF%99%E9%87%8C%E6%9C%89%E4%B8%80%E4%BA%9B%E5%87%8F%E5%B0%91%E5%91%BD%E4%BB%A4%E8%A1%8C%E9%95%BF%E5%BA%A6%E7%9A%84%E5%B0%8F%E7%AA%8D%E9%97%A8%EF%BC%9A%3C%2FP%3E%3CP%3Ea)%20%E4%BD%BF%E7%94%A8%E7%9F%AD%E8%B7%AF%E5%BE%84%2F%E6%96%87%E4%BB%B6%E5%A4%B9%E5%90%8D%E7%A7%B0%EF%BC%88%E5%BD%93%E7%84%B6%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3Eb)%20%E7%BC%A9%E7%9F%AD%20Processor%20Expert%20%E7%94%9F%E6%88%90%E4%BB%A3%E7%A0%81%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%9A%E9%A1%B9%E7%9B%AE%E5%B1%9E%E6%80%A7%E4%B8%AD%E6%9C%89%E4%B8%80%E9%A1%B9%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20801px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F46873i143945F644EE5557%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Ec)%20%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E4%B8%8D%E8%A6%81%E4%BD%BF%E7%94%A8%22%24%7BProjDirPath%7D%20%2FProject_Settings%2FLinker_Files%2FProcessorExpert.ld%22%20%EF%BC%88%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E5%B0%86%E6%89%A9%E5%B1%95%E4%B8%BA%E5%AE%8C%E6%95%B4%E8%B7%AF%E5%BE%84%EF%BC%89%EF%BC%8C%E8%80%8C%E5%BA%94%E8%BF%99%E6%A0%B7%E5%81%9A%EF%BC%9A%3C%2FP%3E%3CP%3E%E4%BD%BF%E5%BA%93%E6%90%9C%E7%B4%A2%E8%B7%AF%E5%BE%84%E7%9B%B8%E5%AF%B9%E5%8C%96%EF%BC%88%E7%9B%B8%E5%AF%B9%E4%BA%8E%20Debug%2Foutput%20%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_2.png%22%20style%3D%22width%3A%20578px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F47111iFAFDEB2EEADCEA72%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_2.png%22%20alt%3D%22pastedImage_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%82%A8%E5%8F%AA%E9%9C%80%E6%8C%87%E5%AE%9A%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FP%3E%3CP%3E%3CIMG%20alt%3D%22%22%20class%3D%22jiveImage%22%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2F%22%20style%3D%22max-width%3A%201200px%3B%20max-height%3A%20900px%3B%22%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%9C%AC%E8%BA%AB%E5%B9%B6%E4%B8%8D%E8%83%BD%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BD%86%E4%B9%9F%E8%AE%B8%E8%83%BD%E4%BD%BF%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%8A%E7%9A%84%E5%AD%97%E7%AC%A6%E6%95%B0%E8%B6%B3%E5%A4%9F%E7%9F%AD%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8F%A6%E4%B8%80%E7%A7%8D%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E6%98%AF%E4%BD%BF%E7%94%A8%20MQX%20%E5%BA%93%EF%BC%88%E5%A6%82%E5%89%8D%E6%89%80%E8%BF%B0%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%96%E8%80%85%E4%BD%BF%E7%94%A8%E6%96%87%E4%BB%B6%E5%B0%86%E6%96%87%E4%BB%B6%E4%BC%A0%E9%80%92%E7%BB%99%E9%93%BE%E6%8E%A5%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%9F%83%E9%87%8C%E5%B8%8C%3C%2FP%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380913%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8D%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E4%BB%BB%E4%BD%95%20C%2B%2B%20%E6%BA%90%E4%BB%A3%E7%A0%81%EF%BC%8C%E8%AF%B7%E7%9C%8B%E6%88%91%E5%88%9A%E5%88%9A%E5%9C%A8%E8%AE%BA%E5%9D%9B%E4%B8%8A%E6%B7%BB%E5%8A%A0%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E8%A7%81%E6%96%AF%E6%99%AE%E6%9E%97%E6%A0%BC%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%8E%9F%E6%96%87%E4%BF%A1%E6%81%AF%E5%A4%84%E7%90%86%E4%BA%BA%EF%BC%9ADavid.fx12%20%3C%2FP%3E%3CP%3ERe%EF%BC%9A%20%20-%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%20(06-Nov-2014%2015%3A12)%3C%2FP%3E%3CP%3E%E5%8F%91%E4%BB%B6%E4%BA%BA%EF%BC%9A%20giacomopetrini%3C%2FP%3E%3CP%3E%E6%94%B6%E4%BB%B6%E4%BA%BA%EF%BC%9AArwed%20Springer%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EKSDK%20%E9%93%BE%E6%8E%A5%E5%99%A8%E9%94%99%E8%AF%AF%20-%20%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%A4%AA%E9%95%BF%3C%2FP%3E%3CP%3E%E6%9D%A5%E8%87%AA%20giacomopetrini%20%E5%9C%A8%20Kinetis%20%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E5%8C%85%E4%B8%AD%E7%9A%84%E5%9B%9E%E5%A4%8D%20-%20%E6%9F%A5%E7%9C%8B%E5%AE%8C%E6%95%B4%E8%AE%A8%E8%AE%BA%E5%86%85%E5%AE%B9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E5%9C%A8%E7%BC%96%E8%AF%91%20C%2B%2B%20%E6%BA%90%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E5%A4%8D%E5%88%B6%20%E2%80%9C%E9%A1%B9%E7%9B%AE%E5%B1%9E%E6%80%A7%E2%80%9D%20%E4%B8%AD%E7%9A%84%E5%8C%85%E5%90%AB%E8%B7%AF%E5%BE%84-%26gt%3B%20C%2FC%2B%2B%20%E7%89%88%E6%9C%AC-%26gt%3B%20%E8%AE%BE%E7%BD%AE-%26gt%3B%20Cross%20Arm%20C%20%E7%BC%96%E8%AF%91%E5%99%A8-%26gt%3B%20%E5%8C%85%E5%90%AB%E5%B9%B6%E7%B2%98%E8%B4%B4%E5%88%B0%20Cross%20Arm%20C%2B%2B%20%E7%BC%96%E8%AF%91%E5%99%A8-%26gt%3B%20Includes%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E4%B8%BA%E5%9C%A8%E7%94%9F%E6%88%90%E4%BB%A3%E7%A0%81%E6%97%B6%EF%BC%8CPE%20%E4%B8%8D%E4%BC%9A%E6%9B%B4%E6%96%B0%20C%2B%2B%20Includes%E3%80%82%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FP%3E%3CP%3E%E5%86%8D%E8%A7%81%EF%BC%8C%E8%B4%BE%E7%A7%91%E8%8E%AB%3C%2FP%3E%3CP%3E%E4%BD%A0%E7%9A%84%E9%97%AE%E9%A2%98%E5%BE%97%E5%88%B0%E5%9B%9E%E7%AD%94%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E8%AF%B7%E7%82%B9%E5%87%BB%E7%A4%BE%E5%8C%BA%E4%B8%BB%E9%A2%98%E4%B8%AD%E7%9A%84%20%22%E6%AD%A3%E7%A1%AE%E7%AD%94%E6%A1%88%20%22%E8%A1%A8%E7%A4%BA%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E5%9B%9E%E5%A4%8D%E6%AD%A4%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%EF%BC%8C%E6%88%96%E8%BD%AC%E5%88%B0%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%A4%BE%E5%8C%BA%E4%B8%8A%E7%9A%84%E6%B6%88%E6%81%AF%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%E7%94%B5%E5%AD%90%E9%82%AE%E4%BB%B6%E6%88%96%E5%9C%A8%E9%A3%9E%E6%80%9D%E5%8D%A1%E5%B0%94%E7%A4%BE%E5%8C%BA%E5%9C%A8%20Kinetis%20%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E5%8C%85%E4%B8%AD%E5%BC%80%E5%A7%8B%E6%96%B0%E7%9A%84%E8%AE%A8%E8%AE%BA%3C%2FP%3E%3CP%3EKSDK%20%E9%93%BE%E6%8E%A5%E5%99%A8%E9%94%99%E8%AF%AF%20-%20%E8%BF%99%E4%BA%9B%E6%95%B0%E6%8D%AE%E6%B5%81%E4%B8%AD%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%A4%AA%E9%95%BF%EF%BC%9A%E6%94%B6%E4%BB%B6%E7%AE%B1%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380912%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%EF%BC%8C%E4%BB%8E%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%AD%97%E7%AC%A6%E4%B8%B2%E4%B8%AD%E5%88%A0%E9%99%A4%E7%9A%84%E5%AD%97%E7%AC%A6%E5%8F%AA%E6%9C%89%E4%B8%80%E4%B8%AA%EF%BC%8C%E8%80%8C%E4%B8%94%E6%80%BB%E6%98%AF%E5%9C%A8%E5%90%8C%E4%B8%80%E4%BD%8D%E7%BD%AE%EF%BC%81%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%B7%AF%E5%BE%84%E5%AD%97%E7%AC%A6%E4%B8%B2%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%89%E4%B8%AA%E8%99%9A%E5%AD%97%E7%AC%A6%EF%BC%8C%E7%BB%93%E6%9E%9C%E5%86%8D%E4%B9%9F%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BA%86%E3%80%82%E7%BB%93%E6%9E%9C%E6%98%BE%E7%A4%BA%EF%BC%8C%E5%AD%97%E7%AC%A6%E7%BC%BA%E5%A4%B1%E7%9A%84%E4%BD%8D%E7%BD%AE%E7%A7%BB%E5%8A%A8%E4%BA%86%E4%B8%89%E4%B8%AA%EF%BC%81%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E6%88%91%E5%9C%A8%E5%B1%9E%E6%80%A7%E8%AE%BE%E7%BD%AE%20%26gt%3B%20Cross%20ARM%20C%2B%2B%20%E9%93%BE%E6%8E%A5%20%26gt%3B%20%E6%9D%82%E9%A1%B9%E4%B8%AD%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%B8%80%E4%B8%AA%E5%BE%88%E9%95%BF%E7%9A%84%E7%A9%BA%E6%9D%A1%E7%9B%AE%EF%BC%8C%E4%BD%86%E6%89%BE%E4%B8%8D%E5%88%B0%E7%8E%B0%E5%9C%A8%E9%93%BE%E6%8E%A5%E5%8F%88%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E8%A7%81%E5%9B%BE%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%EF%BC%8C%E8%BF%99%E5%8F%AA%E6%98%AF%E4%B8%80%E4%B8%AA%E5%BF%AB%E9%80%9F%E9%BB%91%E5%AE%A2%EF%BC%8C%E4%BD%86%E5%9C%A8%E9%94%99%E8%AF%AF%E4%BF%AE%E5%A4%8D%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%AE%83%E6%9A%82%E6%97%B6%E8%BF%98%E8%83%BD%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kds.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22kds.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F46136i91004DB792AACBF6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22kds.jpg%22%20alt%3D%22kds.jpg%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3Ekds.jpg%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380911%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%82%A8%E5%9C%A8%E7%BC%96%E8%AF%91%20C%2B%2B%20%E6%BA%90%E4%BB%A3%E7%A0%81%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E6%98%AF%EF%BC%8C%E5%88%99%E9%9C%80%E8%A6%81%E5%A4%8D%E5%88%B6%20%E2%80%9C%E9%A1%B9%E7%9B%AE%E5%B1%9E%E6%80%A7%E2%80%9D%20%E4%B8%AD%E7%9A%84%E5%8C%85%E5%90%AB%E8%B7%AF%E5%BE%84-%26gt%3B%20C%2FC%2B%2B%20%E7%89%88%E6%9C%AC-%26gt%3B%20%E8%AE%BE%E7%BD%AE-%26gt%3B%20Cross%20Arm%20C%20%E7%BC%96%E8%AF%91%E5%99%A8-%26gt%3B%20%E5%8C%85%E5%90%AB%E5%B9%B6%E7%B2%98%E8%B4%B4%E5%88%B0%20Cross%20Arm%20C%2B%2B%20%E7%BC%96%E8%AF%91%E5%99%A8-%26gt%3B%20Includes%20%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E4%B8%BA%E5%9C%A8%E7%94%9F%E6%88%90%E4%BB%A3%E7%A0%81%E6%97%B6%EF%BC%8CPE%20%E4%B8%8D%E4%BC%9A%E6%9B%B4%E6%96%B0%20C%2B%2B%20Includes%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%B8%8C%E6%9C%9B%E5%AF%B9%E6%82%A8%E6%9C%89%E6%89%80%E5%B8%AE%E5%8A%A9%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%86%8D%E8%A7%81%EF%BC%8C%E8%B4%BE%E7%A7%91%E8%8E%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380910%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%B8%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E6%98%A8%E5%A4%A9%E5%B7%B2%E7%BB%8F%E7%A1%AE%E5%AE%9A%EF%BC%8C%E9%97%AE%E9%A2%98%E5%B9%B6%E4%B8%8D%E5%8F%AA%E6%98%AF%E5%91%BD%E4%BB%A4%E8%A1%8C%E5%A4%AA%E9%95%BF%E8%BF%99%E4%B9%88%E7%AE%80%E5%8D%95%E3%80%82%E6%88%91%E4%BB%AC%E6%9C%89%E5%8F%A6%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%AE%83%E4%BA%A7%E7%94%9F%E7%9A%84%E5%91%BD%E4%BB%A4%E8%A1%8C%E8%BE%83%E9%95%BF%EF%BC%8C%E4%BD%86%E9%93%BE%E6%8E%A5%E6%AD%A3%E7%A1%AE%E3%80%82%E4%BB%8A%E5%A4%A9%E4%B8%8A%E5%8D%88%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E5%B0%9D%E8%AF%95%E5%9C%A8%E5%8F%A6%E4%B8%80%E5%8F%B0%E7%AC%94%E8%AE%B0%E6%9C%AC%E7%94%B5%E8%84%91%E4%B8%8A%E6%9E%84%E5%BB%BA%E8%AF%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BB%A5%E9%AA%8C%E8%AF%81%E8%AF%A5%E9%97%AE%E9%A2%98%E4%B8%8E%E6%9C%BA%E5%99%A8%E6%97%A0%E5%85%B3%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%B9%9F%E5%AD%A6%E5%88%B0%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KSDK%20Linker%20Error%20-%20Command%20line%20too%20long%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BB%8E%E6%98%A8%E5%A4%A9%E5%BC%80%E5%A7%8B%EF%BC%8C%E6%88%91%E5%B0%B1%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%B7%B2%E7%9F%A5%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
