KSDK C++ Support
已解决
KSDK C++ Support
跳至解决方案
1,940 次查看
kalden_srcinc
I have posted before that the header files of the KSDK do not mesh well with cpp source files compiled against them.  Is there any chance of this getting corrected in the next release?
I was able to put together a patch that resolves at least the issues I have run into.  I haven't compiled in every source file, so I'm sure this is not complete.  The KSDK code has carriage returns in it, so you need to use --binary when running patch.
Original Attachment has been moved to: ksdk_cpp.patch.zip
标签 (1)
1 解答
1,758 次查看
ivadorazinova
Hi Kevin,
I got the information that the issue was resolved in coming KSDK release.
Iva
在原帖中查看解决方案
2 回复数
1,758 次查看
ivadorazinova
Hi Kevin,
Iva
1,758 次查看
ivadorazinova
Hi Kevin,
thank you for the interest and your solution. I transmit it to SDK development team.
Have a nice day,
Iva
