KSDK 2.1 Time Management
1,258 次查看
anbui
What is the equivalent time management functions like OSA_TimeDelay() ?
935 次查看
xiangjun_rong
Hi, AnBui,
I think the OSA_TimeDelay()  api function is the function of SDK1.3, if you use SDK2.1 with FreeRtos, you can use the function vTaskDelay();
This page describes the RTOS vTaskDelay() FreeRTOS API function which is part of the RTOS task control API. FreeRTOS is a professional grade, small footprint, open source RTOS for microcontrollers.
Example usage:
 void vTaskFunction( void * pvParameters )  {  /* Block for 500ms. */ const TickType_t xDelay = 500 / portTICK_PERIOD_MS;       for( ;; )      {          /* Simply toggle the LED every 500ms, blocking between each toggle. */         vToggleLED();          vTaskDelay( xDelay );      } }
Hope it can help you
xiangjun Rong
