KSDK 1.3.0 no clock to TPM timers
838 次查看
keithgw
I am upgrading from KSDK 1.2.0 TO 1.3.0, but now none of my TPM timers count. I have set them up as PWM. There appears to be some problem setting up the clockto the TPM.
I use 1.2.0 again, no problem. TPM_DRV_SetClock() changed its clock source enum and this seems to be part of the problem.
742 次查看
Hello Keith,
The KSDK1.3 is very different from KSDK1.2 , so i recommend you recreate new project on
KSDK1.3, and under the install directory there is TPM sample code , for the example for the  FRDM-KL25:
Freescale\KSDK_1.3.0\examples\frdmkl25z\driver_examples\tpm
Hope it helps
Alice
