IAR7.70 and 7.40 can not debug
2,017件の閲覧回数
zhaoqinsu
My IAR7.70 and 7.40 can not open the project file. Tried many times, even during this time can be opened once, but the program can not be opened, but my project file can be opened and used on someone else's computer. This problem is very tangled.
4 返答(返信)
1,847件の閲覧回数
Kan_Li
Hi Z.q. Su,
Would you please specify which KSDK version and which project file you are referring to? Thanks for your patience!
B.R
Kan
1,847件の閲覧回数
zhaoqinsu
  Version number is IAR Embedded Workbench for ARM 7.40 ;The project files are  S32k144_PMC_DUT_Code.Now the project file can not open, in the left side of the workspace did not ask the project file
1,847件の閲覧回数
Kan_Li
Hi Z.q. Su,
Thanks for the information! I just checked with our AUTO AE team, and they recommended using S32 Design Studio IDE to open S32 projects, please kindly refer the above link for details.
Hope that helps,
Kan
1,847件の閲覧回数
zhaoqinsu
Hi Kan_Li
Thanks for your advice.S32 Design Studio IDE just can open S32 projects . When I debug and test procedures used is IAR ,but it still can not ok; Otherwise,I put the project file in the other path, reopen it with IAR ,everything is ok! Idid not know why ?
