How to reset PHY in software?
1,731 次查看
durgasivakrishn
Dear sir,
            i am using SDK_2.0_MK60DN512 stack provided by the NXP for Ethernet. I found that reset signal is required for PHY module to run it in FLASH mode. Can any one suggest, how to reset PHY in software.
With Regards,
Durga sivakrishna
标记 (5)
1,485 次查看
IvanRuiz
Please refer to your PHY's datasheet in which you'll find a section of register description. You can communicate to the registers through the management interface (MDIO). There is a field for software reset in it.
Ivan.
