How to: install KSDK 2.0
Hello KSDK team!
I created helpful tutorial, how to install new version of KSDK.
1) Go to www.nxp.com/ksdk and click to Download button
2) Now choose the Kinetis SDK v2 & v1.3 click Download button
3) At the moment you are redirected to the Kinetis Expert Site, please go to Build an SDK
4) Please, sign in and click Sign in
5) Select MCU for the work and click Select Configuration
6) Selected MCU is supported by KSDK 2.0, you can download the package, choose the toolchain and Operation System.
(Also you can add µC/OS-II and µC/OS-III to your package), click on Build SDK Package
7) Done, check Software Vault tab
8) Please, go to Preferences
9) Please, fill the Preferences and don´t forget Save
10) After successful filling Preferences you are able to see the package in the window
11) Read the Software Terms and Conditions and agree with them
12) Save the package and you can start with KSDK 2.0
SDK API Documentation v.2.0 is located Kinetis SDK 2.0 API Reference Manual: Introduction
Enjoy KSDK 2.0!
All feedbacks are very welcome!
Iva
标记 (1)
评论
Is there any plan to add Processor Expert support?
no, there will be a replacement by another tool.
-Iva
I understand that some developer might not want to download all the processor versions, and this makes a smaller download.
But, some of us do, needing to support multiple parts and packages.
To get support for multiple parts (or packages), the current method is causing me to download the entire package for each part.
Comparing the downloads, for the most part, only the devices and boards has any differences. Sometimes there is more "middleware" included.
Every time, I'm also downloading the tool suite, libraries, etc.
Would you please add the ability to select multiple, or all, devices to the tool? Or at least the entire family?
-Steve
Steve -
This feedback has been communicated with the engineering team behind the package builder.
thank you. My problem has been solved.
Jason,
We're at the point in our project where we've got a window to look into converting from 1.3 to 2.0.
I'm concerned with setting up version control, and having to have separate areas for single processors.
I looked into merging multiple packages manually, and it's not trivial, especially with the manifest.
Any update on when, or even if, NXP will support multiple processors in a single package?
Thank,
Steve
Hi Steve,
unfortunately not. There is no easy way how to comfortably migrate the project from 1.3 to 2.0 because of a lot of changes.
It is recommended to create new KSDK 2.0 project  and copy your code into this new project. Then is needed setup the pins and clocks through hardware_init(). Not sure, what is your project about.
At the moment there is still option for downloading only 1 package per 1 device.
If I will know the update about this, I will let you know.
Thank you for your feedback.
Have a nice day!
Iva
Technical Support Engineer
Any updates regarding downloading support for multiple processors in the same package?  Or a release supporting all processors?  I'm currently forced to merge and maintain a pseudo repository kinetis-sdk2 / mcuxpresso-sdk (or whatever the new name is) to support parts.  Would be handy of Freescale/NXP/Qualcomm followed a model of releasing an upstream repository via git or similar.
I am unable to get KDS to recognize my KSDK 2.0 download. The toolchain is set to Kinetis Design Studio but when I go to download it I see
This MCUXpresso SDK configuration is available for direct download
I can't seem to find a tutorial that matches what I actually see when I try to run through the setup of a project.
Same here. The SW seems flaky. I have also tried to follow tutorials just to get a "Blinky" project up and running, but it falls short on the loading of the 2.2 SDK:
Tutorial: Blinky with NXP Kinetis SDK V2.0 and Processor Expert | MCU on Eclipse
Does not work with the SDK exported from
Iva,
I have just upgraded to KDS 3.2.0 and am trying to install KSDK 2.0, using your instructions.
When I click on the [Download] button in step 2) my browser intercepts the download with the warning:
> The security certificate presented by this website was issued for a different
> website's address.
> Security certificate problems may indicate an attempt to fool you or intercept any
> data you send to the server.
> We recommend that you close this webpage and do not continue to this website.
Is it possible your site has been hacked?  Explorer refuses to let me access it.
%3CLINGO-SUB%20id%3D%22lingo-sub-1113178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8CKSDK%E5%9B%A2%E9%98%9F%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E6%9C%89%E7%94%A8%E7%9A%84%E6%95%99%E7%A8%8B%EF%BC%8C%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20KSDK%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E1%EF%BC%89%E8%AE%BF%E9%97%AE%3CEM%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fwww.nxp.com%2Fksdk%22%20target%3D%22test_blank%22%3Ewww.nxp.com%2Fksdk%3C%2FA%3E%3C%2FEM%3E%E5%B9%B6%E7%82%B9%E5%87%BB%3CSTRONG%3E%E4%B8%8B%E8%BD%BD%3C%2FSTRONG%3E%E6%8C%89%E9%92%AE%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135065_135065.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135065_135065.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117882i114E369643D1E648%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135065_135065.png%22%20alt%3D%22135065_135065.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135065_135065.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_1.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35672iA33982A1A151E6C7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_1.png%22%20alt%3D%22KSDK_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E2%EF%BC%89%E7%8E%B0%E5%9C%A8%E9%80%89%E6%8B%A9Kinetis%20SDK%20v2%E5%92%8Cv1.3%EF%BC%8C%E5%8D%95%E5%87%BB%3CSTRONG%3E%E2%80%9C%E4%B8%8B%E8%BD%BD%E2%80%9D%3C%2FSTRONG%3E%E6%8C%89%E9%92%AE%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135066_135066.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135066_135066.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117883iDC9234D819D83593%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135066_135066.png%22%20alt%3D%22135066_135066.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135066_135066.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_2.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_2.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35722iA31BDAC38B74D141%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_2.png%22%20alt%3D%22KSDK_2.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E3%EF%BC%89%E6%AD%A4%E6%97%B6%E6%82%A8%E5%B0%86%E8%A2%AB%E9%87%8D%E5%AE%9A%E5%90%91%E5%88%B0%20Kinetis%20%E4%B8%93%E5%AE%B6%E7%BD%91%E7%AB%99%EF%BC%8C%E8%AF%B7%E8%BD%AC%E5%88%B0%3CSTRONG%3E%E6%9E%84%E5%BB%BA%20SDK%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135067_135067.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135067_135067.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117884iCE1D088CA6E189A5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135067_135067.png%22%20alt%3D%22135067_135067.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135067_135067.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_3.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_3.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35813iE1D0694D730AED6A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_3.png%22%20alt%3D%22KSDK_3.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E4)%20%E8%AF%B7%E7%99%BB%E5%BD%95%E5%B9%B6%E7%82%B9%E5%87%BB%3CSTRONG%3E%E2%80%9C%E7%99%BB%E5%BD%95%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135068_135068.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135068_135068.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117885i52780747E92321C8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135068_135068.png%22%20alt%3D%22135068_135068.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135068_135068.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_4.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_4.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35856iF45A6E316B2ECC7B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_4.png%22%20alt%3D%22KSDK_4.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_4.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E5%EF%BC%89%E9%80%89%E6%8B%A9%E8%A6%81%E5%B7%A5%E4%BD%9C%E7%9A%84MCU%EF%BC%8C%E7%82%B9%E5%87%BB%3CSTRONG%3E%E9%80%89%E6%8B%A9%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135069_135069.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135069_135069.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117886iBE83605D4EC22B45%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135069_135069.png%22%20alt%3D%22135069_135069.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135069_135069.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_5.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35904iB52E7393CF4EB550%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_5.png%22%20alt%3D%22KSDK_5.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_5.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E6%EF%BC%89%E6%89%80%E9%80%89MCU%E5%8F%97KSDK%202.0%E6%94%AF%E6%8C%81%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E4%B8%8B%E8%BD%BD%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%8C%E9%80%89%E6%8B%A9%E5%B7%A5%E5%85%B7%E9%93%BE%E5%92%8C%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FP%3E%3CP%3E%EF%BC%88%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%B0%86%20%C2%B5C%2FOS-II%20%E5%92%8C%20%C2%B5C%2FOS-III%20%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%82%A8%E7%9A%84%E5%8C%85%E4%B8%AD%EF%BC%89%EF%BC%8C%E7%82%B9%E5%87%BB%3CSTRONG%3EBuild%20SDK%20Package%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135070_135070.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135070_135070.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117887i586CDD3DB6A91DE8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135070_135070.png%22%20alt%3D%22135070_135070.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135070_135070.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_6.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_6.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35954i5884B9C02FC04AD8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_6.png%22%20alt%3D%22KSDK_6.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_6.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E7)%20%E5%AE%8C%E6%88%90%EF%BC%8C%E6%A3%80%E6%9F%A5%3CSTRONG%3E%E2%80%9CSoftware%20Vault%E2%80%9D%3C%2FSTRONG%3E%E9%80%89%E9%A1%B9%E5%8D%A1%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135071_135071.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135071_135071.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117888iAB3C55FA906D7DD5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135071_135071.png%22%20alt%3D%22135071_135071.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135071_135071.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_7.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36001i655884B4D168F67D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_7.png%22%20alt%3D%22KSDK_7.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_7.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%E8%AF%B7%E5%89%8D%E5%BE%80%3CSTRONG%3E%E2%80%9C%E5%81%8F%E5%A5%BD%E8%AE%BE%E7%BD%AE%E2%80%9D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135072_135072.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135072_135072.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117889iC1CA75224D1896C4%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135072_135072.png%22%20alt%3D%22135072_135072.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135072_135072.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_8.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_8.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36047iB4C9F163FAC909E7%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_8.png%22%20alt%3D%22KSDK_8.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_8.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E9)%20%E8%AF%B7%E5%A1%AB%E5%86%99%E9%A6%96%E9%80%89%E9%A1%B9%EF%BC%8C%E5%B9%B6%E4%B8%8D%E8%A6%81%E5%BF%98%E8%AE%B0%3CSTRONG%3E%E4%BF%9D%E5%AD%98%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135073_135073.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135073_135073.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117890i392CC555E2ABA542%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135073_135073.png%22%20alt%3D%22135073_135073.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135073_135073.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_10.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36096iFE7159920F95B36C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_10.png%22%20alt%3D%22KSDK_10.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_10.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E10%EF%BC%89%E6%88%90%E5%8A%9F%E5%A1%AB%E5%86%99%E9%A6%96%E9%80%89%E9%A1%B9%E5%90%8E%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%E7%9C%8B%E5%88%B0%E8%AF%A5%E5%8C%85%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135074_135074.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135074_135074.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117891iF87A4C4A01D5767E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135074_135074.png%22%20alt%3D%22135074_135074.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135074_135074.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_11.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35905iCEBDAF1C22B0AB03%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_11.png%22%20alt%3D%22KSDK_11.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_11.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E11%EF%BC%89%E9%98%85%E8%AF%BB%E8%BD%AF%E4%BB%B6%E6%9D%A1%E6%AC%BE%E5%92%8C%E6%9D%A1%E4%BB%B6%E5%B9%B6%3CSTRONG%3E%E5%90%8C%E6%84%8F%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135075_135075.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135075_135075.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117892iD4201023D6820A7F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135075_135075.png%22%20alt%3D%22135075_135075.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135075_135075.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_12.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_12.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36097i3A9547EC1F4840C9%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_12.png%22%20alt%3D%22KSDK_12.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_12.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E12%EF%BC%89%3CSTRONG%3E%E4%BF%9D%E5%AD%98%3C%2FSTRONG%3E%E8%BD%AF%E4%BB%B6%E5%8C%85%EF%BC%8C%E5%8D%B3%E5%8F%AF%E4%BB%8EKSDK%202.0%E5%BC%80%E5%A7%8B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135076_135076.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135076_135076.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117893i7A0F4AAAD3FF0B13%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135076_135076.png%22%20alt%3D%22135076_135076.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135076_135076.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_13.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_13.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36200i87852107A2139491%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_13.png%22%20alt%3D%22KSDK_13.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_13.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESDK%20API%20%E6%96%87%E6%A1%A3%20v.2.0%20%E4%BD%8D%E4%BA%8E%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fkex.freescale.com%252Fapidoc%252F2.0%252F%22%20target%3D%22_blank%22%3EKinetis%20SDK%202.0%20API%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%9A%E7%AE%80%E4%BB%8B%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135078_135078.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22135078_135078.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117894i1FAF47644C7F2DB6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22135078_135078.png%22%20alt%3D%22135078_135078.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E135078_135078.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_14.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KSDK_14.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F36296iD499DDB37C7B7804%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22KSDK_14.png%22%20alt%3D%22KSDK_14.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EKSDK_14.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BA%AB%E5%8F%97KSDK%202.0%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E6%AC%A2%E8%BF%8E%E6%89%80%E6%9C%89%E5%8F%8D%E9%A6%88%EF%BC%81%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3EIva%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1113178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A6%82%E8%BF%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113189%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EIva%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E5%8D%87%E7%BA%A7%E5%88%B0%20KDS%203.2.0%EF%BC%8C%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%E6%82%A8%E7%9A%84%E8%AF%B4%E6%98%8E%E5%AE%89%E8%A3%85%20KSDK%202.0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%9C%A8%E6%AD%A5%E9%AA%A4%202)%20%E4%B8%AD%E5%8D%95%E5%87%BB%20%5B%E4%B8%8B%E8%BD%BD%5D%20%E6%8C%89%E9%92%AE%E6%97%B6%EF%BC%8C%E6%88%91%E7%9A%84%E6%B5%8F%E8%A7%88%E5%99%A8%E4%BC%9A%E6%8B%A6%E6%88%AA%E4%B8%8B%E8%BD%BD%E5%B9%B6%E5%8F%91%E5%87%BA%E8%AD%A6%E5%91%8A%EF%BC%9A%3CBR%20%2F%3E%20%26gt%3B%3CBR%20%2F%3E%20%26gt%3B%20%E8%AF%A5%E7%BD%91%E7%AB%99%E6%8F%90%E4%BE%9B%E7%9A%84%E5%AE%89%E5%85%A8%E8%AF%81%E4%B9%A6%E6%98%AF%E4%B8%BA%E4%B8%8D%E5%90%8C%E7%9A%84%3CBR%20%2F%3E%26gt%3B%20%E7%BD%91%E7%AB%99%E5%9C%B0%E5%9D%80%E3%80%82%3CBR%20%2F%3E%26gt%3B%3CBR%20%2F%3E%20%26gt%3B%20%E5%AE%89%E5%85%A8%E8%AF%81%E4%B9%A6%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E8%A1%A8%E6%98%8E%E6%9C%89%E4%BA%BA%E8%AF%95%E5%9B%BE%E6%AC%BA%E9%AA%97%E6%82%A8%E6%88%96%E6%8B%A6%E6%88%AA%E4%BB%BB%E4%BD%95%3CBR%20%2F%3E%26gt%3B%20%E6%82%A8%E5%8F%91%E9%80%81%E5%88%B0%E6%9C%8D%E5%8A%A1%E5%99%A8%E7%9A%84%E6%95%B0%E6%8D%AE%E3%80%82%3CBR%20%2F%3E%26gt%3B%3CBR%20%2F%3E%20%26gt%3B%20%E6%88%91%E4%BB%AC%E5%BB%BA%E8%AE%AE%E6%82%A8%E5%85%B3%E9%97%AD%E6%AD%A4%E7%BD%91%E9%A1%B5%E5%B9%B6%E4%B8%94%E4%B8%8D%E8%A6%81%E7%BB%A7%E7%BB%AD%E8%AE%BF%E9%97%AE%E8%AF%A5%E7%BD%91%E7%AB%99%E3%80%82%3CBR%20%2F%3E%26gt%3B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%82%A8%E7%9A%84%E7%BD%91%E7%AB%99%E6%9C%89%E5%8F%AF%E8%83%BD%E8%A2%AB%E9%BB%91%E5%AE%A2%E5%85%A5%E4%BE%B5%E4%BA%86%E5%90%97%EF%BC%9FExplorer%20%E6%8B%92%E7%BB%9D%E8%AE%A9%E6%88%91%E8%AE%BF%E9%97%AE%E5%AE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E5%90%8C%E6%A0%B7%E5%9C%A8%E8%BF%99%E9%87%8C%E3%80%82SW%20%E7%9C%8B%E8%B5%B7%E6%9D%A5%E4%B8%8D%E5%A4%AA%E7%A8%B3%E5%AE%9A%E3%80%82%E6%88%91%E4%B9%9F%E6%9B%BE%E5%B0%9D%E8%AF%95%E6%8C%89%E7%85%A7%E6%95%99%E7%A8%8B%E6%9D%A5%E5%90%AF%E5%8A%A8%E5%92%8C%E8%BF%90%E8%A1%8C%E2%80%9CBlinky%E2%80%9D%E9%A1%B9%E7%9B%AE%EF%BC%8C%E4%BD%86%E5%9C%A8%202.2%20SDK%20%E7%9A%84%E5%8A%A0%E8%BD%BD%E4%B8%8A%E5%8D%B4%E5%AD%98%E5%9C%A8%E4%B8%8D%E8%B6%B3%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2016%2F05%2F20%2Ftutorial-blinky-with-nxp-kinetis-sdk-v2-0-and-processor-expert%2F%22%20title%3D%22https%3A%2F%2Fmcuoneclipse.com%2F2016%2F05%2F20%2Ftutorial-blinky-with-nxp-kinetis-sdk-v2-0-and-processor-expert%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3E%E6%95%99%E7%A8%8B%EF%BC%9AEclipse%20%E4%B8%8A%E7%BB%93%E5%90%88%20NXP%20Kinetis%20SDK%20V2.0%20%E5%92%8C%20Processor%20Expert%20%7C%20MCU%20%E7%9A%84%20Blinky%3C%2FA%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E9%80%82%E7%94%A8%E4%BA%8E%E4%BB%8E%E4%BB%A5%E4%B8%8B%E4%BD%8D%E7%BD%AE%E5%AF%BC%E5%87%BA%E7%9A%84%20SDK%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113187%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E6%97%A0%E6%B3%95%E8%AE%A9%20KDS%20%E8%AF%86%E5%88%AB%E6%88%91%E7%9A%84%20KSDK%202.0%20%E4%B8%8B%E8%BD%BD%E3%80%82%E5%B7%A5%E5%85%B7%E9%93%BE%E8%AE%BE%E7%BD%AE%E4%B8%BA%20Kinetis%20Design%20Studio%EF%BC%8C%E4%BD%86%E5%BD%93%E6%88%91%E4%B8%8B%E8%BD%BD%E5%AE%83%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%AD%A4%20MCUXpresso%20SDK%20%E9%85%8D%E7%BD%AE%E5%8F%AF%E7%9B%B4%E6%8E%A5%E4%B8%8B%E8%BD%BD%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E8%BF%90%E8%A1%8C%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%E6%97%B6%EF%BC%8C%E6%88%91%E4%BC%BC%E4%B9%8E%E6%89%BE%E4%B8%8D%E5%88%B0%E4%B8%8E%E6%88%91%E5%AE%9E%E9%99%85%E7%9C%8B%E5%88%B0%E7%9A%84%E5%86%85%E5%AE%B9%E7%9B%B8%E5%8C%B9%E9%85%8D%E7%9A%84%E6%95%99%E7%A8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113186%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%89%E5%85%B3%E4%BA%8E%E5%9C%A8%E5%90%8C%E4%B8%80%E5%8C%85%E4%B8%AD%E4%B8%8B%E8%BD%BD%E5%AF%B9%E5%A4%9A%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%E6%94%AF%E6%8C%81%E7%9A%84%E6%9B%B4%E6%96%B0%E5%90%97%EF%BC%9F%E6%88%96%E8%80%85%E6%98%AF%E6%94%AF%E6%8C%81%E6%89%80%E6%9C%89%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%E7%89%88%E6%9C%AC%EF%BC%9F%E6%88%91%E7%9B%AE%E5%89%8D%E8%A2%AB%E8%BF%AB%E5%90%88%E5%B9%B6%E5%B9%B6%E7%BB%B4%E6%8A%A4%E4%B8%80%E4%B8%AA%E4%BC%AA%E5%AD%98%E5%82%A8%E5%BA%93%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fkylemanna%2Fkinetis-sdk2%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ekinetis-sdk2%20%2F%20mcuxpresso-sdk%3C%2FA%3E%20%EF%BC%88%E6%88%96%E4%BB%BB%E4%BD%95%E6%96%B0%E5%90%8D%E7%A7%B0%EF%BC%89%E6%9D%A5%E6%94%AF%E6%8C%81%E5%90%84%E4%B8%AA%E9%83%A8%E5%88%86%E3%80%82%E5%A6%82%E6%9E%9C%20Freescale%2FNXP%2FQualcomm%20%E9%81%B5%E5%BE%AA%E9%80%9A%E8%BF%87%20git%20%E6%88%96%E7%B1%BB%E4%BC%BC%E6%96%B9%E5%BC%8F%E5%8F%91%E5%B8%83%E4%B8%8A%E6%B8%B8%E5%AD%98%E5%82%A8%E5%BA%93%E7%9A%84%E6%A8%A1%E5%9E%8B%EF%BC%8C%E5%B0%86%E4%BC%9A%E5%BE%88%E6%96%B9%E4%BE%BF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113185%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Steve%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%E5%B9%B8%E7%9A%84%E6%98%AF%E6%B2%A1%E6%9C%89%E3%80%82%E7%94%B1%E4%BA%8E%E5%AD%98%E5%9C%A8%E5%BE%88%E5%A4%9A%E5%8F%98%E5%8C%96%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%B2%A1%E6%9C%89%E7%AE%80%E5%8D%95%E7%9A%84%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E8%BD%BB%E6%9D%BE%E5%9C%B0%E5%B0%86%E9%A1%B9%E7%9B%AE%E4%BB%8E%201.3%20%E8%BF%81%E7%A7%BB%E5%88%B0%202.0%E3%80%82%3C%2FP%3E%3CP%3E%E5%BB%BA%E8%AE%AE%E5%88%9B%E5%BB%BA%E6%96%B0%E7%9A%84%20KSDK%202.0%20%E9%A1%B9%E7%9B%AE%E5%B9%B6%E5%B0%86%E4%BB%A3%E7%A0%81%E5%A4%8D%E5%88%B6%E5%88%B0%E8%BF%99%E4%B8%AA%E6%96%B0%E9%A1%B9%E7%9B%AE%E4%B8%AD%E3%80%82%E7%84%B6%E5%90%8E%E9%9C%80%E8%A6%81%E9%80%9A%E8%BF%87hardware_init()%E8%AE%BE%E7%BD%AE%E5%BC%95%E8%84%9A%E5%92%8C%E6%97%B6%E9%92%9F%E3%80%82%E4%B8%8D%E7%A1%AE%E5%AE%9A%E4%BD%A0%E7%9A%84%E9%A1%B9%E7%9B%AE%E6%98%AF%E5%85%B3%E4%BA%8E%E4%BB%80%E4%B9%88%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%AF%8F%E5%8F%B0%E8%AE%BE%E5%A4%87%E4%BB%8D%E7%84%B6%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E5%8F%AA%E4%B8%8B%E8%BD%BD%201%20%E4%B8%AA%E5%8C%85%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E7%9F%A5%E9%81%93%E6%9C%89%E5%85%B3%E6%AD%A4%E4%BA%8B%E7%9A%84%E6%9C%80%E6%96%B0%E6%B6%88%E6%81%AF%EF%BC%8C%E6%88%91%E4%BC%9A%E5%91%8A%E8%AF%89%E4%BD%A0%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%8F%8D%E9%A6%88%E3%80%82%3C%2FP%3E%3CP%3E%E7%A5%9D%E4%BD%A0%E4%BB%8A%E5%A4%A9%E8%BF%87%E5%BE%97%E6%84%89%E5%BF%AB%EF%BC%81%3C%2FP%3E%3CP%3EIva%3C%2FP%3E%3CP%3E%E6%8A%80%E6%9C%AF%E6%94%AF%E6%8C%81%E5%B7%A5%E7%A8%8B%E5%B8%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113184%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9D%B0%E6%A3%AE%EF%BC%8C%3CBR%20%2F%3E%E5%9C%A8%E6%88%91%E4%BB%AC%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%A4%84%E4%BA%8E%E4%B8%80%E4%B8%AA%E7%A0%94%E7%A9%B6%E4%BB%8E%201.3%20%E8%BD%AC%E6%8D%A2%E5%88%B0%202.0%20%E7%9A%84%E9%98%B6%E6%AE%B5%E3%80%82%3CBR%20%2F%3E%E6%88%91%E5%85%B3%E5%BF%83%E7%9A%84%E6%98%AF%E8%AE%BE%E7%BD%AE%E7%89%88%E6%9C%AC%E6%8E%A7%E5%88%B6%EF%BC%8C%E4%BB%A5%E5%8F%8A%E5%BF%85%E9%A1%BB%E4%B8%BA%E5%8D%95%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%E8%AE%BE%E7%BD%AE%E5%8D%95%E7%8B%AC%E7%9A%84%E5%8C%BA%E5%9F%9F%E3%80%82%20%3C%2FP%3E%3CP%3E%E6%88%91%E7%A0%94%E7%A9%B6%E4%BA%86%E6%89%8B%E5%8A%A8%E5%90%88%E5%B9%B6%E5%A4%9A%E4%B8%AA%E5%8C%85%EF%BC%8C%E4%BD%86%E8%BF%99%E5%B9%B6%E4%B8%8D%E7%AE%80%E5%8D%95%EF%BC%8C%E5%B0%A4%E5%85%B6%E6%98%AF%E5%AF%B9%E4%BA%8E%E6%B8%85%E5%8D%95%E8%80%8C%E8%A8%80%E3%80%82%3CBR%20%2F%3E%E6%9C%89%E5%85%B3%E4%BA%8E%20NXP%20%E4%BD%95%E6%97%B6%EF%BC%88%E6%88%96%E8%80%85%E6%98%AF%E5%90%A6%E4%BC%9A%EF%BC%89%E5%9C%A8%E5%8D%95%E4%B8%AA%E5%B0%81%E8%A3%85%E4%B8%AD%E6%94%AF%E6%8C%81%E5%A4%9A%E4%B8%AA%E5%A4%84%E7%90%86%E5%99%A8%E7%9A%84%E6%9C%80%E6%96%B0%E6%B6%88%E6%81%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%EF%BC%8C%3CBR%20%2F%3E%E5%8F%B2%E8%92%82%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113183%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%E5%B7%B2%E7%BB%8F%E8%A7%A3%E5%86%B3%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113182%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3ESteve%20-%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%AF%A5%E5%8F%8D%E9%A6%88%E5%B7%B2%E4%B8%8E%E5%8C%85%E8%A3%85%E6%9E%84%E5%BB%BA%E5%99%A8%E8%83%8C%E5%90%8E%E7%9A%84%E5%B7%A5%E7%A8%8B%E5%9B%A2%E9%98%9F%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B2%9F%E9%80%9A%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113181%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%E6%9C%89%E4%BA%9B%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E5%8F%AF%E8%83%BD%E4%B8%8D%E6%83%B3%E4%B8%8B%E8%BD%BD%E6%89%80%E6%9C%89%E5%A4%84%E7%90%86%E5%99%A8%E7%89%88%E6%9C%AC%EF%BC%8C%E8%BF%99%E6%A0%B7%E5%8F%AF%E4%BB%A5%E5%87%8F%E5%B0%91%E4%B8%8B%E8%BD%BD%E9%87%8F%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E4%BB%AC%E4%B8%AD%E7%9A%84%E4%B8%80%E4%BA%9B%E4%BA%BA%E7%A1%AE%E5%AE%9E%E9%9C%80%E8%A6%81%E6%94%AF%E6%8C%81%E5%A4%9A%E4%B8%AA%E9%83%A8%E4%BB%B6%E5%92%8C%E5%8C%85%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%B8%BA%E4%BA%86%E8%8E%B7%E5%BE%97%E5%AF%B9%E5%A4%9A%E4%B8%AA%E9%83%A8%E5%88%86%EF%BC%88%E6%88%96%E5%8C%85%EF%BC%89%E7%9A%84%E6%94%AF%E6%8C%81%EF%BC%8C%E5%BD%93%E5%89%8D%E6%96%B9%E6%B3%95%E8%A6%81%E6%B1%82%E6%88%91%E4%B8%8B%E8%BD%BD%E6%AF%8F%E4%B8%AA%E9%83%A8%E5%88%86%E7%9A%84%E6%95%B4%E4%B8%AA%E5%8C%85%E3%80%82%3C%2FP%3E%3CP%3E%E6%AF%94%E8%BE%83%E4%B8%8B%E8%BD%BD%E5%86%85%E5%AE%B9%EF%BC%8C%E5%A4%A7%E5%A4%9A%E6%95%B0%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E5%8F%AA%E6%9C%89%E8%AE%BE%E5%A4%87%E5%92%8C%E4%B8%BB%E6%9D%BF%E6%9C%89%E5%B7%AE%E5%BC%82%E3%80%82%E6%9C%89%E6%97%B6%E4%BC%9A%E5%8C%85%E5%90%AB%E6%9B%B4%E5%A4%9A%E2%80%9C%E4%B8%AD%E9%97%B4%E4%BB%B6%E2%80%9D%E3%80%82%3CBR%20%2F%3E%E6%AF%8F%E6%AC%A1%EF%BC%8C%E6%88%91%E8%BF%98%E4%BC%9A%E4%B8%8B%E8%BD%BD%E5%B7%A5%E5%85%B7%E5%A5%97%E4%BB%B6%E3%80%81%E5%BA%93%E7%AD%89%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E4%B8%BA%E8%AF%A5%E5%B7%A5%E5%85%B7%E6%B7%BB%E5%8A%A0%E9%80%89%E6%8B%A9%E5%A4%9A%E4%B8%AA%E6%88%96%E6%89%80%E6%9C%89%E8%AE%BE%E5%A4%87%E7%9A%84%E5%8A%9F%E8%83%BD%EF%BC%9F%E6%88%96%E8%80%85%E8%87%B3%E5%B0%91%E6%98%AF%E6%95%B4%E4%B8%AA%E5%AE%B6%E5%BA%AD%EF%BC%9F%3C%2FP%3E%3CP%3E-Steve%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113180%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8D%EF%BC%8C%E5%B0%86%E4%BC%9A%E6%9C%89%E5%8F%A6%E4%B8%80%E7%A7%8D%E5%B7%A5%E5%85%B7%E6%9B%BF%E4%BB%A3%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E-Iva%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1113179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E5%A6%82%E4%BD%95%E5%AE%89%E8%A3%85KSDK%202.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1113179%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E8%AE%A1%E5%88%92%E6%B7%BB%E5%8A%A0%20Processor%20Expert%20%E6%94%AF%E6%8C%81%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎02-01-2016 04:06 AM
更新人:
