How to crossing to KDS? OnLowVoltageINT
1,708 次查看
profprogrammer
Hello.
i used codeWirrior and now i transfer to KDS.
I want to apply interruption of OnLowVoltageINT.
OnLowVoltageINT is called when Low Voltage interrupt had occured.
How to generate this interrupt in KSDK?
1,428 次查看
Hello Prof,
You can still use the Processor Expert without KSDK, it have this interrupt .
When you create project only select PE:
Then you can see :
Hope it helps
Alice
1,428 次查看
profprogrammer
Hello, Alice.
I generated the project as you showed.
that not so with my project
https://community.freescale.com/servlet/JiveServlet/download/390244-1-377367/tmp6.7z.zip
1,428 次查看
Hello Prof,
I have not in the KSDK+PE project , there isn't this selection .
In the PE project without KSDK, there is , about the PE project , when you
create project , please select the "Processor Expert", do not select "kinetis SDK"
Alcie
