How to crossing to KDS? OnLowVoltageINT
2,405件の閲覧回数
profprogrammer
Hello.
i used codeWirrior and now i transfer to KDS.
I want to apply interruption of OnLowVoltageINT.
OnLowVoltageINT is called when Low Voltage interrupt had occured.
How to generate this interrupt in KSDK?
3 返答(返信)
2,125件の閲覧回数
Hello Prof,
You can still use the Processor Expert without KSDK, it have this interrupt .
When you create project only select PE:
Then you can see :
Hope it helps
Alice
2,125件の閲覧回数
profprogrammer
Hello, Alice.
I generated the project as you showed.
that not so with my project
https://community.freescale.com/servlet/JiveServlet/download/390244-1-377367/tmp6.7z.zip
2,125件の閲覧回数
Hello Prof,
I have not in the KSDK+PE project , there isn't this selection .
In the PE project without KSDK, there is , about the PE project , when you
create project , please select the "Processor Expert", do not select "kinetis SDK"
Alcie
