Freemaster with MKM34
1,541 次查看
dhruvonline
Hi Martin,
I have to use the UART3 for Freemaster for Energy, Current and Voltage and Reading in the 3-Phase Energy Meter.
As per the MKM reference design, UART2 is used for that. Can you suggest the changes required at Meter side and PC side?
Regds,
Dhruv
1,360 次查看
xiangjun_rong
Hi, Dhruv,
Pls refer to the application note an4752, it is helpful to understand how to change the uart module.
https://www.nxp.com/docs/en/application-note/AN4752.pdf
Xiangjun rong
1,360 次查看
dhruvonline
Hi xiangjun.rong,
Thanks for the suggestion. I will check it.
Regds,
Dhruv
