Flash program example in KSDK 2.2
1,503 次查看
mastupristi
Senior Contributor II
I use Kinetis K64
in the old KSDK 1.3 there was some source file about programming flash using swap (C90TFS in KSDK_1.3.0/platform/drivers/src/flash/C90TFS/drvsrc).
I wonder if in KSDK2.2 yhere is something similar
best regards
max
1,190 次查看
danielchen
Hi Massimiliano Cialdi
From KSDK 2.x,  we merged all original KSDK 1.3 flash source filess in fsl_flash.c
For example, for Frdm-K64f, this file is under the below folder
SDK_2.2_FRDM-K64F\devices\MK64F12\drivers\fsl_flash.c
I guess below two flash APIs are what your are looking for.
FLASH_SwapControl()
FLASH_Swap
