FRDM-K82F qspi demo problem!
zahomz
Follow the demo(KSDK_1.3.0_K81\examples\frdmk82f\demo_apps\hello_world_qspi), I've run the hello_world_qspi in qspi flash. I want to add rtos base in this demo now, but it doesn't work. I found that hardware_init() didn't call the function BOARD_ClockInit(), but when I add this in hardware_init function, the hello_world_qspi couldn't work well.
Any suggestions for how to find/fix the problem?
konradgräfe
Did you find a solution to this?
ivadorazinova
Hi Zahom,
please, can you share your code here?
Thank you.
Iva
