FRDM-K64F compatible with FRDM-KW41Z
jonver
Hi!
Is FRDM-K64F compatible with FRDM-KW41Z?
I'm trying out example 11.4 from the "Kinetis Thread Stack Demo Application User's guide.pdf", and I wonder what boards are supported to run this demo.
Thanks!
Tags (2)
gerardo_rodriguez
Hi Jonathan,
Unfortunately, there are no examples where the FRDM-K64F communicates with a FRDM-KW41Z.
The example described in section 11.4 External routing via Ethernet on FRDM-K64F – ND6 host mode and OpenWrt is meant for a FRDM-K64F with a FRDM-CR20A shield. The software for this example can be found in the Kinetis MKW2xD and MCR20A Connectivity Software.
Let me know if you have any question.
Gerardo
