I wrote a program using the FTM timer to configure a PWM clock and associate it
to a specific GPIO.
As described in the Reference Manual (section K64 Signal Multiplexing an PIn Assignments),
I used the GPIO PTA0 multipexed and set to FMT0_CH5 (ALT3).
The program is quite simple and linked to this message (main.c)
In the interrupt function, I made the red led blink. It looks ok, but if I plugged
an oscilloscope to the PTA0 pin, I have no signal output generated.
I probably made something wrong ...
Thanks for your support again
Nadine
Original Attachment has been moved to: main.c.zip
