EmbSys Viewer will not Install on Luna 4.4
8,077 次查看
bcstewart
I have tried to install EmbSys Viewer on KDS 3.2 with Luna 4.4.
I followed the methods described in this forum and on mcuoneclipse.com
When I try to specify the device (K22F), NXP or Freescale is not listed in the vendor listing.
Any suggestions?
7 回复数
7,864 次查看
BlackNight
Are the NXP/Freescale SVD files present in your data files/collection for EmbSysRegView?
Depending on your EmbSysRegView, this might be different, see Adding CMSIS-SVD Files to EmbSysRegView 0.2.6.r192 and Eclipse | MCU on Eclipse
I hope this helps,
Erich
7,859 次查看
bcstewart
OK.  I see it in the ADV(CMSIS) folder.  But KDS is not recognizing it.
7,859 次查看
BlackNight
I think you mean the 'SVD(CMSIS)' folder. Not sure why it does not list it for you. But in any case, you can pick and choose any folder name or move files into a folder of your choice inside the data.
7,859 次查看
bcstewart
Yes, it's installed.
But if you look at the package, NXP is missing!  (note:  I temporarily
renamed the .jar to .zip)
Very strange...
--Brad
7,859 次查看
BlackNight
Can you check the SVD folder in that zip file?
7,859 次查看
bcstewart
Working now.
Simply need to select SVD(CMSIS) under Architecture in the EmbSysReg
section and then select Freescale.  A bit different approach from the
article since I didn't create a KDS directory and copy the files.  This
is not easy if you don't have Winzip Pro.  So I simply left it as is.
7,859 次查看
BlackNight
You don't need WinZip Pro. Any zip tool (as 7-Zip) can do this.
