Bareboard equivalent to MQX Shell?
1,642件の閲覧回数
lucianomoretti
Does the KSDK have a bareboard equivalent to the MQX Shell? I see the fsl_debug_console, but that does not appear to provide structure for an actual shell.
タグ(3)
1,336件の閲覧回数
ivadorazinova
Hi Luciano,
Please, what do you use for MCU?
We have created example for RTCS Shell, please take a look at C:\Freescale\KSDK_1.3.0\middleware\tcpip\rtcs\examples\shell\build\kds
The example shows features RTCS TCP/IP stack and allows performing initialization and configuration of network interfaces - DHCP, DNS, FTP, TFTP, Telnet, SMTP and others.
In addition to example Adding TAD shell in KSDK, you can follow steps here Adding TAD shell in KSDK shell demo
I hope this helps you,
Iva
