which kinetis controller useful for USB printer host project
2,172 次查看
sudhakarp
hi,
i want to send some data to Printer device (Printer Host) through USB. so which Kinetis controller can i use..? So which development board easy to use? if USB printer example code  there its most useful to me.
please give some suggestion.
regards,
sudhakar
1,918 次查看
ivadorazinova
Hi Sudhakar,
I see your post how to implement USB printer host class in FRDMK64
Please, is this query still open? Or did you already select FRDM-K64F?
Thank you.
Have a great day.
Iva
1,918 次查看
sudhakarp
hi,
yes i selected FRDM-K64F. you can suggest some other best controller also.
