where are TWR-KW24512 docs
已解决
跳至解决方案
1,558 次查看
JonathanHess
Got my tower system module with KW24 and have read the quick start guide but… where is the rest of the documentation?
Something that talks about what all the jumpers are and a schematic?
Where is the tower configuration spreadsheet for the module?
And… since I think I inadvertently wiped the program that was provided with it, where can I download the default program so I can reload it?
Very little appears to be on the OpenSDA partition on the device itself.
1 解答
1,414 次查看
Wlodek_D_
Senior Contributor II
Hello Jonathan,
Please see answer (where are TWR-KW24D512 docs ) to your repeated question posted in another place and follow Paul's advice .
Thank you and regards,
Wlodek_D.
在原帖中查看解决方案
1 回复
1,415 次查看
Wlodek_D_
Hello Jonathan,
Wlodek_D.
