structure - unaligned memory? hard fault
mjg8t
Hi There,
I think I may be having an unalignment memory hard fault occurring.  I am using some code which has run fine on the KL devices, but is giving the K22 a hard fault.  I have narrowed down the issue to writing to a structure variable.
I have been happily naive about memory alignment and it appears it is time to learn more details about it in fixing my issue here.  I have attached the project which is running on the frdm-k22f board.  The main loop has a write to the structure and which seems to be casuing the issue.
Can someone explain what is wrong with the structure defenition?  How I can avoid this in the future?  And how to fix it?
Thanks!
Original Attachment has been moved to: test_sd.zip
jingpan
I read you code and found that pdev is a pointer. But I didn't see you initializing it. A pointer must point to a entity before you use it.
jingpan
mjg8t
Thank you for having a look!  Very glad it was a something so simple.
