sequence trigger ADC by PDB0 with FTM0 in MBDT KV5x
1,453 次查看
CauTran
I already followed by example in KV3x how to use synch FTM0 and ADC through by PDB0. But, it 's not run. Can anyone provide my a simple example for this one?
Thank you so much.
I follow the example PDB0 but not use Delayed interrupt like example.
1,432 次查看
PabloAvalos
Hi @CauTran
Thank you so much for using our community. I appreciate that you were patient, thank you so much.
Regarding your request, I got kind of confused, you said that you tried to synchronize the FTM0 and ADC through the PDB0 to get the trigger of the ADC and then use the FTM0 to do another task on a KV3x ? It is unclear to me what are you trying to do?
I would like to help you of course. I will stay tuned to your reply to help you more precisely.
Please let me know if you have more questions or any update.
Thanks in advance.
Best Regards.
Pablo Avalos.
