self reset?
self reset?
1,488件の閲覧回数
cerr
Can a Kinetis mcu reset itself to boot from protected flash in order to start a bootloader (for a firmware upgrade) or does that need to be initiated by a hardware reset?
タグ(3)
1,315件の閲覧回数
BlackNight
That depends if you need to reset the registers/peripherals to the power-on reset.
Something I used to do is to let the watchdog timer to expire: this will perform a CPU reset.
