problems about Lin official example for FRDM-KEAZ128
2,841 次查看
elder_atom
I build the official example Lab10_LIN_Master_KEA128 from FRDM-KEA-QSP-V8 in S32DS, but there are two errors occured.
Is there anyone knowing how to solve this problem?
Thanks for everyone replying!
2,676 次查看
kerryzhou
Hi Li Yinwei,
    Please download the newest S32DS IDE 2018 version from this link:
S32 Design Studio IDE for Arm® based MCUs|NXP
 Then import the project again, please note, the workspace use a new folder, don't use your older IDE's workspace.
I have tested it on my side with the newest IDE, and test the same project with you, I build without problem.
You can find I also can enter the debug mode:
Wish it helps you!
Kerry
2,676 次查看
elder_atom
I reinstall S32DS ARM1.3 and build the example, the warnings are disappeared but the errors are still existing.
Anyone knows how to solve this problem?
Thanks for everyone replying.
2,677 次查看
kerryzhou
Hi Li Yinwei,
Wish it helps you!
Kerry
2,676 次查看
elder_atom
Hello   Kerry
   Your suggestion help me solve this problem successfully.Thanks a lot.
