Hi Hassam Javed
We don't recommend to do this migration of code. There are too many difference between MK60_10 and MK60_12, and the migration is too complicated. You could check the following application note, it describes new, updated and enhanced modules in this MCUs:
http://cache.freescale.com/files/microcontrollers/doc/app_note/AN4526.pdf
One option that you could use is MQX, it support Ethernet stack in MK60_12 MCUs. Sorry for the inconveniences that this may cause you.
Jorge Alcala
