peak and hold driver
atick
I'm designing a peak and hold fuel injector driver for a direct injector of 65volts, i have found the MC33816AE chip but I'm not sure what MCU to use. can you guy please recommend the best MCU that suits best for MC33816AE chip. thank you very much
xiangjun_rong
Hi,Atiq
As you know that the MC33816 is used in auto application, so i suggest you use auto processor for example MPC56xx/MPC57xx.
Pls refer to the doc:
AUT-N1829 PT2000 Solenoid Driver for Direct Fuel Injection and Other Next-generation Powertrain Appl...
If you still have question, pls post your question to MPC forum.
Hope it can help you
Xiangjun Rong
