open SDA
5,691件の閲覧回数
nesrinemhiri
I have a FRDM-KL46Z kit,I use Embeded IAR,my problem that i can't connect to my device:untitled3.bmpss.bmpaa.bmp
5,352件の閲覧回数
nesrinemhiri
yes Iva the problem is in the USB drivers but i show the Article and i dont find any thing that can help me :smileysad:.
Nesrine
6 返答(返信)
5,352件の閲覧回数
gblack
Make sure you have the latest OpenSDA firmware installed. Also try uninstalling and reinstalling the driver from P&E Microcomputer Systems
5,352件の閲覧回数
nesrinemhiri
Nesrine
5,352件の閲覧回数
ivadorazinova
Hi nesrine mhiri,
please, check if you see it in your Computer.
If yes, look into the storage. There is info.htm and you see in the file information about versions.
It looks that you have not installed PEMicro OpenSDA Debug Driver.
You may to install new software from PEmicro sites. Please, look here
OpenSDA on the Freedom KL25Z Board | MCU on Eclipse
I hope it helps,
Iva
5,352件の閲覧回数
ivadorazinova
Hi nesrine mhiri,
It looks like problem with fixing usb drivers.
please, check jungo driver. Our colleague created great article about it. http://mcuoneclipse.com/2012/10/12/fixing-the-usb-drivers/
I hope it helps,
Iva
5,352件の閲覧回数
omolin
Make sure you have loaded the Pemicro debug application in OpenSDA.
There is no way to tell if you have done this because you don't show the Pemicro device in device manager. The Serial port there is a general OpenSDA device so you could have no debug application loaded, or have CMSIS-DAP loaded possibly.
5,352件の閲覧回数
nesrinemhiri
really i don't find the problem,when i work with tower i usally use the JTAG pins but with FRDM kits am obliged to use the SDA ,please help me to connect to my kit
