need help plz
need help plz
2,392 次查看
mitsali
Hi all,
i am new here, i bought chip - MKL16Z64VLH4 for my fly sky i6 transmitter. chip was short vdd and vss. now i replace with new chip "MKL16Z64VLH4" and try to flash it does nothing, i know about arduino chip it need to burn bootloader 1st then flash, but i dont know anything about "MKL16Z64VLH4" plz let me know if there needed boot loader 1st.. and how to do it if anyone know
thank you
2,380 次查看
Pavel_Hernandez
you may first download MCU Bootloader package from the below link:
MCU Bootloader | NXP Semiconductors
and then porting code to KL16 base on the example code in this package, say KL25.
also you can refer to the guide in this package "Getting Started with the Kinetis Flashloader" to learn how to porting it.
Pavel
2,380 次查看
Pavel_Hernandez
Pavel
2,368 次查看
mitsali
Hi Pavel_ glade to see your reply. thank you so much
i downloaded "NXP_Kinetis_Bootloader_2.0.0 package." in this package no exe file to run on windows 10, just like other IDE, and where can i find pin connection. if i am using usbasb or usb ftdi, i could 'd find docs, where mention all instruction for beginner, if you show me full detail or reffer some docs it would be great to me,
thank you
