mkv31, safety PWM state while rebooting
alexeyusoltsev
 Well, i got a power converter solution built upon mkv31f128.
But there is a problem-while booting pins that controlls H-brige ringing. That causes periodically the system blow and about 20$ loss to repair it. And of course we can't sell such a product.
 So i have a question: are there any fuses/registers that controls states of pins in the boot time before been configured? (at least I can remember such tool on other vendors)
P.S.: Now we solves that problem by introducing time delay before power up power stage but it cost additional money.
Alexey.
xiangjun_rong
Hi, Alexey,
As you know that the PWM signals output logic are indeterminate during and after reset, I suggest you connect a pull-down resistor on the PWM output pins so that the PWM can output low logic before you initialize the PWM(FTM ) module.
Most of the PWM pins are input or disabled(float) during and after Reset, so they will become low if you connect pull-down resistor.
Hope it can help you
Xiangjun Rong
