memory
glengreenwood
  I went through the data sheet but if the following could be confirmed for the MK60FN1M0VLQ15 I would greatly appreciate it.
Also does the MK60FN1M0VLQ15 have an external Flexbus?
Flash            1 MB total (Block0&1 =512KB)          0x0_000-0x07_FFFF  0x08_0000-0x0F_FFFF
Eprom                 None
SRAM          128 KB total (Upper&Lower =64KB)
    : Lower SRAM              0xFFF_0000-0x1FFF_FFFF
    : Upper SRAM              0x2000_0000-0x2000_FFFF
External (Flexbus) memory 256KX16(MR2A16A)           0x - 0x3_FFFF (17 bit) Remapped internally (256KX16)
Thanks in advance,
  1. Glen.
Tags (2)
hectorsanchez
Hi Glen,
You can find everything you asked here: http://cache.freescale.com/files/microcontrollers/doc/data_sheet/K60P144M150SF3.pdf?&Parent_nodeId=&...
As you can see in the first page :
Hope this helps,
Hector Sanchez
hectorsanchez
Hi Glen,
Hope this helps,
Hector Sanchez
