maintenance mode
maintenance mode
1,684件の閲覧回数
anju1
hi all,
I have a FRDM k64 board, and I want to practice  Mbed projects on my board. the problem is when I connect the board to the PC simply and also connect it by reset button pressed both shows maintenance mode. what should i do to work it normally? anyone please help?
1,627件の閲覧回数
jingpan
Hi ANJU,
It seems you FRDM board only has MBED bootloader, but hasn't debug application. Please download application from OpenSDA Serial and Debug Adapter | NXP . Then just copy the firmware to 'maintenance'. You can select one of CMSIS-DAP/P&E/Jlink.
Jing
